Question about Motorola Talkabout T5720 (7 Channels) 2-Way Radio
Motorola Talkabout 5700, 60 second timeout?
I have a set of Motorola Talkabout 5700. They come with a 60 timeout if the PTT/talk button is held on for 60 seconds. Is there anyway to bypass this or change it so that it could be left transmitting continuously? I was hoping to use it as a baby monitor where one radio always transmits. Thanks
  • Motorola Master
  • 1,654 Answers
The 60 second timeout is a feature which is necessary to keep from burning up the final amplifier in the unit. It keeps the user from ruining their radio. Most radios, including business radios have this feature. Continually holding down the PTT will also run the battery down very quickly.
It would be best to try getting a regular baby monitor.
Posted on Oct 31, 2008
I have old motorola talkabouts..and don't remember to change the channel. can you help? They are Yellow and have no screen on them...I can't find any model number on them. the date is Dec 1998 it...
Hold the push to talk(PTT) button while turning the unit on, it will talk to you. press PTT to change channel, push monitor to switch to codes, press PTT to change codes. When you have the correct settings press monitor and it will confirm settings.
Jun 13, 2011 | Motorola Talkabout FRS 250 (14 Channels)...
To turn the tlk confirmation tone off... it does not work holding the - sign and turning it on now what?
Just read your message a second time. Is the sound following the release of the PTT button? If so, it is indeed the Roger Beep (aka talk confirmation tone). If holding in the minus button while turning the radio on does not turn it off, there might be something wrong with the radio, such as a one of the other buttons being slighty stuck. Or you have your keypad locked. To unlock the keypad hold the menu button in for 3 seconds until the lock icon disappears.
Another thing which will make a noise during or after transmitting is the low battery beep. You might check your batteries. Old, bad, poorly charged or defective batteries can cause this.
fyi: Some users might think the Call Tones are the Roger Beep.
Lastly, there is a PTT Timeout beep which will occur if you hold the PTT in for more than 60 sec while talking.
Hope one of these items is of help to you.
http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf
Best regards.
Oct 13, 2010 | Motorola Talkabout T6500 (7 Channels)...
DOES IT HAVE A CALL BUTTON?
It has a PTT (push-to-talk) button. But if you are talking about a button to make a call tone (ringing sound) come out the other radios, the answer is no.
Best regards.
Apr 10, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
Bearlyhere26 I bought a pair of Motorola
Commonly called the TalkAbout Basic. With the radio turned on hold in the monitor button. It should announce the current setting. Use the PTT button to change the setting. Press the monitor button to lock in your selection. When done shut the radio off and then turn it back on.
Jul 28, 2009 | Motorola Radio Communications
I recieved a talkabout 250 and i have no clue how to use it please help
You would need two or more radios to be able to communicate with others. Then you simply press the push-to-talk (PTT) button when you want to talk (transmit) and release it so others can reply (receive). The radios must be set to the same settings to be able to communicate.
Apr 11, 2009 | Motorola Talkabout FRS 250 (14 Channels)...
One radio not sending
hold the the ptt button for a minute in both handsets
Mar 07, 2009 | Motorola Talkabout FR50 (14 Channels)...
Talk about frequency change
To change channel & code press talk and monitor while turning radio on. Radio will speak current channel. Release both talk and monitor. Press talk to change to next channel or press monitor to keep current channel. Press monitor when desired channel is selected, radio will speak current code. Press talk to change to next code or press monitor to keep current code. Press talk to change code as desired then press monitor when done. Will speak channel and code selected. Set all units in same manner to communicate.
Oct 15, 2008 | Motorola Talkabout T5800 (22 Channels)...
What will i do to connect Motorola T5720 and T5728
Set both the frequency and the interference eliminator code to match one another. (The big number and the small number) Here is a link to the owners manual: http://www.motorola.com/mdirect/manuals/T56XX_57XX_User%20_Manual_E.pdf
Basic instructions:
Press the Menu Button
The freq number will flash
Use the + or - button to select the frequency.
Press the PTT button to save the channel setting.
To set the code:
Press the menu button until the code starts to flash (the small number)
Press the + or - to select the code.
Press the PTT to save the code setting.
Once you have both radios matching on frequency and code, they should communicate together.
Aug 21, 2008 | Motorola Talkabout T5720 (7 Channels)...
No activation
Check if you are using the same channel and same squelch code in both radios. I´m not sure if you are talking about the PTT button, if is so, try using a audio accesory with ptt external just to be sure that your internal ptt is working or not.
Feb 03, 2007 | Motorola Talkabout T5500 (7 Channels)...
Motorola Talkabout T5720 (7 Channels) 2-Way Radio Logo
201 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
