Question about Kodak EasyShare C330 Digital Camera
My lens wont come out
I didn't know if there was anyway to get the camera fixed before i had to invest in another one it really is a great camera
  • 104 Answers
Very cafeully clean lens assembly-it sounds like dirt in shutter. If shutter does noropen it cannot go to next step wich is lens projecting from housing.
Posted on Oct 31, 2008
Lens problem on my dsc-w1 sony digital camera
You might not believe and I don't think that this happens with all the same cameras, but I have the same camera and what I did was connect the cable to my printer (hp psc 1315 all-in-one). After I connected it, it was working fine, but I still thought that I wouldn't be able to take pictures...But I turned it on and it worked perfectly! It's amazing! I did this 3 weeks ago to see what happened and I fix my camera without even trying to do so! The only thing that bothers me is that it keeps saying that the batteries are low, although they are recharged...but you can take pictures and do what ever you want!
Mar 02, 2009 | Opteka (HD245XW1KT) for Sony DSC-W1 0.45x...
Lens will not focus, "access" screen, lens reluctant to retract
i guess that u shud change the focus oart of camera and that is no esay u jst give it toa repair guy!!
Aug 14, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
"access" screen, lens has trouble retracting, lens will not focus
try these two things i cant promise they will work
first turn on take hold of the lense and gently pull and twist you may hear it click dont force it then trun off and on again. this should fix the access and lense problem
then also try
Press Menu button
togle across from REC Mode to setup
togle down thrice from camera to setup 1
togle across into sub menu
togle down from four times to Initialize
togle across again to the sub-menu
togle up from cancel to OK
press center button to accept the OK choice
Screen changes and so press okay again
It should restart the camera
Opening on the 'Clock Set' screen
togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
If it is working then don't forget to set your Clock.
Dead
Have read of same problem from numerous users on the internet. One person said this may be caused by a twisted/jammed lens. Apparently the "telescoping" lens mechanism can sometimes jam due to a drop and/or from dirt that gets in the telescoping hardware. The solution that someone gave that I read about involved telling the user to try to gently twist and/or wiggle the extended lens parts counterclockwise to try to "unjam" them. Of course that would also require having fully charged batteries, etc, before you try that, since from my experience, low battery charge results sometimes in the lens not retracting (or extending) properly also. It's worth a try anyway, since apparently your camera isn't functioning properly anyway now with its lens extended. I have a problem w/my On/Off switch not working properly, and in checking w/the Canon USA website, they wanted a minimum of $87 to "start" to attempt to fix it (whatever the problem is), and required that I pay them that much "up-front", and that I agree to whatever it then would cost in toral. I backed out and went and bought some new cameras instead, since I felt that was way too much to invest in my A70, that's already 5 years old now. Good luck w/your extended lens problem.
Jul 25, 2008 | Canon PowerShot A70 Digital Camera
I droped my camera on the grond and it wont turn on.it fell the side of the lens
Theres a very good chance you are going to have it repaired by a Camera Repair person. I would really need to know the brand and model.
If it is a canon then it will most def. need a new lens assembly. they have metal pins which guide the lens and when they are droped the pins break out of place.
If it is a Nikon or Sony or Casio alot of times I have been able to push the lens straight and it will re-align itself and work perfect again. But that said I wouldnt be too forceful unless the camera is not worth fixing. In that case you really arnt risking anything other than the possibility of fixing it.
Jun 26, 2008 | Olympus Cameras
Zoom error
worked on allot of fuji's. first detease, a gear is slipping in the lens retract assembly due to a crack or wear or jam
2nd guest .. zoom errors means its really stuck tight
the gears can be ordered and replaced and one more possibility is that the motor that drives the gear is bad
Also if dropped or zoom lens jammed hard... lens assembly needs total realignment or replacing..
May 23, 2008 | Fuji FinePix F460 Digital Camera
Lens cover will not full open up help needed
Mine wont open at all. You can hear the lens trying to push it's way out but the cover doesnt move.
Dec 27, 2007 | Olympus Stylus 800 / ? 800 Digital Camera
Kodak EasyShare C330 Digital Camera Logo
37 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
