Question about Danby DKC645BLS Compact Beverage Cooler
HABCO ESM12 blowing warm air
Hi!
I have had this cooler in our garage unplugged for the past 3 years. I plugged it in the other day and it blows warm air and will not get cooler no even if I turn the adjustment to full (it remains at 80 degrees F). Prior to the past 3 years it was working perfectly. Do you have any suggestions or ideas on what I should do/look for? Thank you for your time.
  • game_na1 Oct 31, 2008
    Thanks for the quick response. How will I know if the compressor is working? Is it like a fridge where I have to listen for the "popping" sounds? And if it overloaded, what will I have to do [besides have the compressor replaced]? Thanks.
  • 120 Answers
First see if compressor is running at all if is not it might just be a realy or overload
Posted on Oct 31, 2008
  • Rosendo Madero
    Rosendo Madero Nov 01, 2008
    well open the back cover touch the compressor to see if is running if it is then is might be a leak or restriction if you know how to use a meter check amperage on compressor if is 0.3 amps is leak or restriction . if is not running the relay in the little box with wires by compressor repl that and it should run again
  • trout_hunter
    trout_hunter Mar 05, 2012
    If the compressor is running and not tripping on overload it is the evaporator fan motor on the back of the cassette. Just worked on one and that was the issur.
Honeywell 97-4118/5-89
probably low on freon. i assume compressor is running?
Jan 25, 2014 | Honeywell ER150B Air Conditioner
Yes I have a True 95 38 Beverage cooler and I bought it new 4 years ago , I have used it for 3 and 1 year it just sat not running , well I plugged it in the other day and it is only blowing warm inside and...
Could be many things... A bad thermostat, bad compressor, bad compressor start relay, refrigerant leak, moisture in the system, or even a blocked capillary tube. You would need a lot more information... mostly only the kind a technician can get by getting his hands on it. Sorry.
Sep 11, 2010 | True TD-95-38-LT Beverage Cooler
This frigidaire (side by side) only blows warm air on both sides
Good day,
First, I would unplug the machine, and then unplug the ice maker. Wait 20 minutes and plug in refrigerator. See if it cools without the ice maker in the equation.
Sounds more like starting components on the compressor, or a compressor starting to fail.
Post back with results.
Thank you.
Feb 12, 2010 | Frigidaire FRS3R5EMB Side by Side...
The heater in my 2006 Dodge Grand Caravan only blows warm air while on low. If the dial is turned to high it blows cold air. What is the problem?
It sounds like the heater valve is not operating. Find the valve on the engine firewall passenger side and manually open the valve. Find it by following the 3/4 inch heater hose to the firewall where it is connected to the valve. Most likely the cable ( or vaccum hose)from the temperature dial to the valve needs replacing.
Dec 31, 2009 | 2006 Dodge Grand Caravan
2 year old Kenmore freezer won't keep cold. It
Check underneath the unit and make sure the compressor is running and that the compressor fan is turning.
Oct 15, 2009 | Freezers
LAST NIGHT WORKING FINE ~ THIS MORNING NOT BLOWING COLD AIR
check one of the following stop the cooling
a- condenser need cleaning
b- condenser fan not operating
1 -check correct voltage comes to the fan motor if ok
2- check capacitor if ok
3-check motor winding
c-low suction pressure
need check for leak before charging.
Sep 12, 2009 | Dometic Rooftop RV Air Conditioner
Blows warm air, unpluged it for 2 days plugged back in blew very
Either the start relay and start capacitor or the Adaptive Defrost control is burned out. If you have a voltage meter we can test a few things like the compressor and the capasitor. The part number for the Adaptive defrost is 241508001 and found inside the fresh food compartment behind the control panel. I can help you locate the problem if you like. Let me know, Thanks, Sea Breeze
Jul 18, 2009 | Frigidaire FRS3R5EMB Side by Side...
I have 550 CFM cooler and the air is blowing but
you need to open up and clean the pump unless gravity fed but still need to cleaned. or new pump.
Jul 11, 2009 | AdobeAir Adobe Air 550 CFM Portable...
No heat just warm air
I think you are on top of your problem,,you dont need any one elses advice.
Complete rebuild of the cooling and heating system,, simple.
Jan 19, 2009 | 2001 Oldsmobile Alero
Danby DKC645BLS Compact Beverage Cooler Logo
1,523 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
