Question about Canon PC-1060 Black and White Copier
L-50 machine gets Rec.paper jam slide platen left
Please help the error code wont go away
rec.paper jamslide platen left
  • 318 Answers
Slide the uper unit to the left by pulling handle on the left,open cover on the right,remove drum unit by pulling on the handle,remove paperjam.
Posted on Oct 31, 2008
The copier says rec paper jam slide left platen? what do i do ?
On the slide there is a handle. This releases the top reader port of the copier, move it to the left. Raise right side cover and remove the drum cartridge unit. You should see the jammed paper there, at the right lower access door, or in the fuser where the paper should come out. Just reverse the procedure to reset the jam. If the copier still indicates the jam then it must be in the fuser. You will have to have a technician remove the fuser assembly from the copier and take apart the unit to remove the jam. Hope this helps.
Jun 12, 2011 | Canon PC-1060 Black and White Copier
I'm getting a message stating Rec. paper jam slide platen left. Can you please help me someone donated this copy machine to the church however I need to repair it. Thank You!
after yoy slide, open up the cover and then you will see the cartridge (black color) then you pull out the cartridge (there is a holder steel).
and you will see the paper jammed.
take it all, do not be left one bit.
and then replace all like a before.
May 29, 2011 | Canon imageRUNNER 1370F All-In-One Laser...
Prompt says, "REC. Paper jam slide platen left". We have done as instructed and looked for paper jams with every opening. We have also rebooted the copier but turning off, then on and also by unplugging...
Hi With this copier I find the paper jam is always in the fuser area. Its very hard to get to. You need a a flash light and tweezers to get it. You need to look where the paper comes out. Thank you, Steven 805-520-3003
Oct 14, 2010 | Canon imageCLASS D661 Digital Printer
Rec. Paper Jam slide platen left
There may still be a small sliver of paper somewhere along the paper path. It only takes one small piece to interfere with the mechanism that detects jams and causes the copier to stop working. Since the copier gives you an indication of where the jam is occurring, I would focus my attention in that area, removing trays, using a small flashlight to get a really good look inside.
Jan 07, 2010 | Canon SmartBase PC1270D All-In-One Laser...
Paper jam will not clear
you have a stuck or broken sensor
Jul 02, 2009 | Canon Office Equipment & Supplies
Display says rec.paper jam,slide platen left
in service mode manually recheck all paper transport sensors...
Mar 17, 2009 | Canon Office Equipment & Supplies
I am receiving an error of canon ir 1210- rec.
no canon ir 1210 never falt signal
Your lower cassate paper senson is open or sensor liver is broken you quary it and solve it
My cell phone is 01819879575
Mar 15, 2009 | Canon imageRUNNER 1210 Copier
Paper jam
make sure that the exit sensor is realese down.generaly u ca check the sensors not to have pull out
Nov 11, 2008 | Canon Office Equipment & Supplies
Cannot find paper jam ...
We have a D780, which is probably very similar to your unit. Have you removed your toner cartridge and inspected to see if any paper is in the paper path? 95% of the time that is where the paper jam is.
Oct 21, 2008 | Canon ImageClass D880 Copier
Ir 1600
That code indicates a laser problem. You can check the door switches on the front of the machines as well as the left lower door.
Jan 25, 2008 | Canon imageRUNNER C3200 Copier
Canon PC-1060 Black and White Copier Logo
820 people viewed this question
old marine
old marine
