Question about Intel Motherboard
I have a gigabyte 965p-ds3 motherboard problem
I have that motherboard, a intel 3.0 mhz. new dual core cpu, 4gb ddr2 800 memory sticks, and an antec power supply with a pny 7800 series video card. when i start the computer, i have only the fans running. the computer doesnt post. i have no video, and no post beeps. what can this be?
  • repon905 Nov 09, 2008
    power provilm
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 89 Answers
What you may have to do is check if the HDD is operating. When the pc is started, listen in for the operation of the HDD. If it goes through the process of posting and no display but the HDD spinning. The motherboard may have a chance. Minimize what you have installed, or just enough to have it run and make sure the connections are on proper. I'd start with reseting the BIOS, or do what you can to make it show display. You can try to reflash the BIOS,there may be several ways, one you can try the floppy with needed file(s) and try that proceedure. If the BIOS chip on the motherboard is socketed and not surface mounted, find a replacement BIOS chip. I had a similar incident in where i flashed a gigabyte BIOS with @BIOS, restarted the pc, and then never came back on. Similar with what you've described with no post, quiet enough to determine since all i heared were just the fans. The motherboard was dead. Before you do this, make sure the PSU is working, that may be the problem.
Posted on Nov 06, 2008
  • 849 Answers
It should be power supply problem, check it.
Posted on Nov 03, 2008
GIGABYTES GA-965P-DS3 motherboard cost features
Ref:
GIGABYTE Motherboard Socket 775 GA 965P DS3 rev 1 0
May want to look on the board to find out what version it is and select the right one in the link.
Jul 07, 2014 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
I have already own a cooler master cac-t05-uw case,gigabyte ga-965p-ds3 motherboard, and seagate st3400620as hard disk drive.. I'm looking for: power supply, cpu, cooling device, ram, and video adapter...
Hi, welcome to FixYa.
Currently, your motherboard only support Intel Core 2 family (not the newest Core i, even the Core i Sandy Bridge series). Here's the list of the supported CPU that your motherboard support.
http://www.gigabyte.com/support-downloads/cpu-support-popup.aspx?pid=2456
For the memory, I recommend you that a very good brand such Team Elite, Corsair, or else. Here's the list of supported memory:
http://download.gigabyte.asia/FileList/Memory/motherboard_memory_ga-965p-ds3_3.3.pdf
For power supply, you can take ThermalTake or CoolerMaster power supply, I recommend you take at least 500W as your power supply.
As for the VGA (video), it's up to your need, but I recommend you to take HIS as their cooling devices is very good.
Sorry I can't give you the model number, there's a lot of it.
Thanks for using FixYa!
Jul 06, 2011 | Cooler Master CAC-T05-UW ATX Mid-Tower...
What cpu is compatible with motherboard GIGABYTE GA-965P-DS3
Go to http://www.gigabyte.com/support-downloads/download-center.aspx?kw=GA-965P-DS3
and click on revision 1.0 - 3.3 as there may be additional CPUs supported in Rev 3.3 vs 1.0, you have to determine what specific Revision you have.
Dec 01, 2010 | Gigabyte 965P-DS3 (GA965PDS3) Motherboard
WHAT IS THE APPROPRIATE CPU FOR GIGABYTE GA-965P-DS3
This is a socket LPA 775 motherboard, it will accept almost all core 2 / quad core intel cpu's, here is the full list from gigabyte.
(you may need to unpate the bios for some CPU's)
http://ee.giga-byte.com/products/mb/cpulist/ga-965p-ds3_20.html
Sep 01, 2010 | Gigabyte 965P-DS3 (GA965PDS3) Motherboard
Hi my mother board is working but after 5 mintues it turn's off why its got 2.00gig of ram and anew power supply please help. Thank-You John
1. make sure that all motherboard fans are working especially the CPU fan. the motherboard shutsdown when it reaches a max temperature.
2. maybe your power supply is defective.
3. make sure that the CPU heatsink is properly seated in the processor
Jun 24, 2010 | Gigabyte GA-965P-DS3 (0818313003027)...
I have gigabyte series g31 m-es2L i want use memory pc 5300.... it's support with this mainboard ???? tx pls reply to : it_mid@yahoo.com
First, clarification: the closest Gigabyte model is GA-G31M-ES2L... there is no "g31 m-es2L"
For this kind of question the easiest way to find the answer is from the manufacturer: Gigabyte
A quick search of their products results in:
http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ClassValue=Motherboard&ProductID=2889&ProductName=GA-G31M-ES2L
which states that up to 800mhz DDR2 (PC6400) is supported
( 667mhz (PC5300) is also supported. )
Generally with motherboards, if a higher speed of memory is supported, the lower speeds are also supported.
PS: mhz times 8 yields the PCxxxx number, PCxxxx divided by 8 yields the mhz number
Feb 09, 2009 | Gigabyte Matx Intel G31 775 DDR2-800...
Will my motherboard support a Core 2 Duo processor: GA-8S649MF (Gigabyte Motherboard)
Every system needs a rock-solid foundation, and that's just what you get with this Gigabyte GA-8S649MF motherboard. It features Socket 775 compatibility and support for Intel Pentium 4 or Pentium Dual-Core processors with 800 MHz front side bus speeds. Two DIMM slots support up to 2 GB of DDR400 system memory.
Dec 21, 2008 | Intel Motherboard
New Computer
Hi im David,
1. To start to buying a computer, you need a Standard ATX case, they sell only ATX cases so you can choose one at the shop that suits you. Then you might want to get a power supply because the pne that comes with the case will not supply enought power. You would want at least 550W. I recomment the Coolermaster 660W.
2. You will then need to think what Brand CPU your going to use. These days AMD is not making the best CPU's So i recommend Intel. Based on what you want to do and what the shop has, i would get the Dual Core E7200 (2.53 GHz 3MB Cache) or the E8400 (3.0GHz 6MB Cache). There is no point for buying a Quad core as it is expensive and not many games can use the full extent of the CPU.
3. Once chosen teh brand on the CPU you have to buy a Motherboard that supports the CPU, they only sell One type of Intel CPU and that the LGA 775 so any Intel Motherboard will work with your CPU. I would get Gigabyte GA-EP43-DS3 at $125. Dont bother buying anything higher than $155 unless you got the money and really need it. I psersonally use GA-EP43-DS3 because it has all the features i need like Dual Graphics (not SLI), 3 firewire connections, 12 USB ports, 7.1 Surround Sound, 6 SATA Ports and 4 ram slots.
4. Once gotten your motehrboard you will need RAM. They sell Kingstom and Corsair DDR2 Ram at speed of 800MHz. Corsair is a much better brand but you wont notice much difference between the two of them. 2GB is more than enought if your going to run XP but you will need 4GB for Vista. get 4X1GB and you will get faster speeds than 2X2GB.
5. Getting a Hard Drive. Depending what you are going to store on your Hard drive, you can get different sizes. The bigger the size the cheaper it is per gigabyte. I would get a 500GB. Western Digital and Samsung is quieter than Segate but isnt as fast in speed but you wont notice the difference. Make sure you get 3.5" or if u want you can get a 2.5" but it wont fit anywhere in your case so you will have to rest it soemwhere. It still can be plugged it to your motherboard. I use a 2.5: with my Desktop PC because it reduces noise.
6. Getting an optical Drive. Make sure you get a DVD Burner, they are only $40. YOu may consider getting a Blu-Ray Drive so you can watch Blu-ray movies on your cmputer or use your Computer as a Blu-ray player and plug it in your LCD TV. Blu ray will cost $175 for LG or $215 for Pioneer. Pioneer is better.
7. Next you will need a PCI-Express graphics card. For your games the minimum i would buy would be Gigabyte Nvidia 8400GS. I recommend Gigabyte Nvidia 9600GT 512MB.
8. You may want to buy a monitor, you can choose since its just a monitor.
You can choose any preheripals such as mouse and keuboard. Wireless mouse is recommend but theres no point for wireless keyboard unless you plan to sit a few meters away from the computer.
Once bought you can get the shop to buid it for you or you can buid it yourself.
When building yourself, make sure you wear a Electrostatic Discharge Wrist band to prevent damage. Or simply touch the metal of the case to get rid of the static. Do not touch any electrical compunet pins such as CPU pins and CPU socket Pins.
Once made you will need to install an operating system. You can buy one or Download a pirated version.
Oct 10, 2008 | Computers & Internet
Mortherboard
CPU:
Supports Intel Pentium 4 Socket 478 processors with 800/533/400 MHz FSB
Supports Intel Hyper-Threading Technology Chipset: Intel 865PE / ICH5-R
Supports Dual Channel DDR 400 Memory
Supports Advanced Configuration and Power Management Interface (ACPI) Memory: Six 184-pin DIMM sockets
Supports Single/Dual Channel DDR 400 memory (Max. 4GB). Audio: High quality 6-channel AC'97 audio with S/P-DIF function with JAck Sensing IDE/SCSI: Dual Ultra DMA 66/100 IDE controllers integrated in ICH5R- up to four Ultra ATA drives
Serial ATA/150 controller integrated in ICH5R- Up to 150MB/sec transfer speeds
2 channels Serial ATA 150MB/s data transfer rate via Silicon Image PCI controller
GigaRAID IDE RAID Controller I/O Connectors: PS/2 Keyboard and mouse, 1 x Parallel, 2 x Serial, 4+4 x USB2.0, 1 x RJ45, 1 x Audio Expansion Slots: 1 x AGP (3.0) , 5 x PCI (2.3), 1 x DPS Additional Features: GIGABYTE Patented Technology Dual Power System 2 (DPS 2)
GIGABYTE Xpress3 Series Software
from the above configuration for the board you can see that it supports up to 4GB ddr max
hope this helps pls appreciate by rating as fixyaa
Oct 05, 2008 | Intel Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
