1) Adjust the reed swithc, see the diagram attached, clean, and tight the connector. 2) Tight the ribbon cable from keypad ,tight the display board connector vs lower board. 3) After you did this, run the software calibration for diagnose, troubleshootign in according with the instruction manual.
Hello This sometimes happens in Samsung Cellphones that while connecting to internet via WIFI, DNS failed To solved it follow the given procedure:
Go to browser
Then go to setting
Then clear cache, empty
cookies and delete history
Now restart your Samsung S5620 cellphone, then
connect to desire wifi connection, then browse after setting up your
browser profile
If it doesn't solved then contact to Samsung Service providers and consult with providers of WIFI connection, But i hope it will work. Don't forget to do Rating by Clicking on Four Thumbs which are given below to this solution if it is HELPFUL Thanks and keep Using FixYa
we do not have the codes required for this that is only given by the network provider. that is proprietory info and none of us has that authorization. it would be best if you contact your service provider for the authorization code.. good luck
hello coenrycn,
please make sure that your service provider has provided you that service.
check out for your menu in the phone then go to settings and then go for call settings then find out for caller id settings enter into it and change it to ON .
IF THE PROBLEM STILL PERSISTS AFTER SOLVING BOTH OF THE GIVEN ABOVE SOLUTIONS THEN TRY A PRACTICAL CHECK UP TAKE YOUR MOBILE AND MAKE SURE THAT YOUR MOBILE ALLOWS ITS NUMBER TO BE SEEN BY ALL AND THEN RING TO YOUR PHONE.
PLEASE NOTE THE NUMBER IN YOUR ADRESS BOOK OF YOUR PHONE AND THEN SEE
this happens due to the firmware problem(this occurs due to virus attack) ....
try giving the restore factory settings in your phone ...
if you still persist the problem then you just update the firmware of the phone that solves your problem ....
you can update the firmware with the normal datacable only ...
you can update to the latest firmware for your phone from the software called" Nokia Software Updater "... you can download this for free from the website of nokia directly given below :
http://europe.nokia.com/A4579163 (your pc must be connected to net to download the latest firmware) butremember dont disconnect the cell while updating the firmware is inprocess if you do so your phone will be severely damaged you can neveruse your phone ... even the manufacture can t help with this if you interrupted during the firmware update ....
after you update the firmware all your problems will be solved ...
any doubts you can reply me i am always here to assist you thank you bye rate my solution
