Question about Hitachi 60V500 60" Rear Projection HDTV-Ready Television
Noisy TV (Hitachi)
TV produces a loud humming sound as if there's a cooling fan that's working extra hard. The problem is sporadic in the sense that it can run for several hours without making any noise and then it can also produce the noise when it has just been running for a few minutes. The temperature light has not come on at all, but the noise is getting more frequent. Is it a cooling fan and if so, is it separate or is it part of the engine assembly(meaning all inclusive)? Any easy solution or is this going to require a professional technician?
PS....we're on our second lamp (replaced over six months ago), the noise problem has surfaced in just the last 3 weeks.
    Problem Solver:
  • 15 Answers
The noise in question relates to capacitors, which are (unfortunately) largely dependant upon environmental elements. You most probably find that when outdoors is wet and humid, there is no issue, but the moment the sun is out and it drys out, your problem rears its ugly head again. This is a basic fault and should be able to be solved by a standard TV tech shop, as its in short, humidity dependant. To explain caps, are moisture based electric storage devices; under normal circumstances the chemicals react ideally to provide the expected volts and or current. Alter the environment subastantially and the cheaper versions will not adapt and they will put the unit 'out of spec' as a dryer environment will produce less volts/current and more humid environment will make it perform closer to spec. Its a sod of a feature but thats earth. :) Higer class ie Class 'A' components tend not to suffer dramatic changes and produce more reliable results.
To sum up, the loud humming is caused by out of spec components or for that matter dried up used up components, the fact it runs for hours at a time is most likely weather dependant and if not its likely to be a dry joint somewhere on the board. These are also unfortunately largely dependant upon environmental conditions. Best of luck. :o)
Posted on Dec 26, 2008
Knocking sound in tv pls. give solution
What kind of knocking sound?
What kind of TV?
Some TVs have small fans inside them to keep them cool which can get noisy when old or if something has got into them.
Or could it be coming from a speaker?
Not many things in a TV can produce a knocking sound.
Jul 17, 2017 | Televison & Video
When we shut the fridge door a loud continuous humming noise comes from the fridge. This seems to be activated by the door light switch at the top. Thank you
There are 2 possibilities I can think of for the hum. When you activate that door switch it activates 2 fans and the compressor. There is one fan located on the compressor and one located in the vent system in the fridge. The second fan is used to circulate cool air evenly through the fridge. I would recommend holding your finger on the door switch and listen carefully whether the noise is coming from inside the back of the fridge or from the lower bottom. Lower bottom could indicate compressor cooling fan or compressor. They would need to be inspected. If it sounds more like the other fan mentioned above it would again need to be inspected. The compressor cooling fans can get stuck or become noisy due to bearing failure. The vent fan can get stuck or noisy but also in some cases if the defrost circuit is not working can chock up with ice and create a buzzing noise as the fan blades strike the ice.
Jan 13, 2017 | Refrigerators
Noisy sounds like a fan and the picture starts to flickers multiple colors and picture is scambled.
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
Nov 16, 2010 | Samsung HLN5065W 50" Rear Projection...
Loud humming sound; stops when door is opened.
sounds like your cooling fan if to noisy replace if not leave it alone
Sep 14, 2010 | Dacor Epicure EF42BNDB Side by Side...
Maytag admiral refrigerator, the fan inside the refrigerator is making a loud sound when on and the cooling in the refrigerator is freezing
Makes sense, you are not moving enough air. Do not over fill the refrigerator. Fix the problem with the fan, if it is noisy I am 99% sure it is not moving enough air. To make noise something mechanical is hitting, it could be either the fan blade (cheaper to fix) or the motor.
Good Luck,
Gilshultz
Dec 01, 2009 | Maytag Admiral Top-Freezer Refrigerator
Making a lot of noise
Sounds like a bearing in the cooling Fan
Thanks for using FIXYA
Sep 21, 2009 | Samsung DLP HL-P5663W 56" TV
Hi, we have a humming sound that is really loud,
Yes, its fan noise and you need to replace noisy fan.
Let me know exact model of your Sony TV and need to know what fan is producing noise to provide you part number and parts shop info to buy that fan.
Jul 31, 2009 | Sony Grand WEGA KF-50WE620 Television
Loud cooling fan hum
If the fan was not that noisy before , this can only be cause by a dirty fan and you may need to clean it up to reduce the hum coming out from it...
Dec 28, 2008 | Acer Extensa Laptop
Sporadic Hum on HLP4663W
I would guess that its the fan for the lamp, as the color wheel will power down as soon as the power is cut. the cooling fans will continue to run
Jun 12, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
114 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
