Question about Kitchen Ranges
Westinghouse 658 Freestyle Multi Function Oven
Hi
Could you tell me where I could find a manual for a Westinghouse 658 Freestyle Multi Function Oven?
2 Suggested Answers
SOURCE: I have a Westinghouse Freestyle
Ok. I actually just kept pressing the buttons until numbers started scrolling up and down. Once the numbers appeared without the bell symbol you are then setting the clock time.
thanks
Posted on Apr 30, 2008
Could you please help me find a manual for this oven? Westinghouse 411 Freestyle.
since you do not post a make , sorry to tell you but we can offer nothing .
Aug 28, 2015 | Kitchen Ranges
How to adjust flame on Westinghouse freestyle gas oven
The flame is regulated by the thermostat you don't say if it's too high or too low. Suggest you buy an oven thermometer available for a few dollars at most homeware shops, compare the temperatures then you will see if the thermostat is working or not.
Apr 22, 2014 | Cooktops
My Westinghouse multi function oven has an A flashing on the clock and no number of combinations can turn it off the oven wont work while its there
Try unplugging it for a couple of minutes. Assuming there's no major problems with it, that should reset it.
Feb 17, 2013 | Ovens
I have a westinghouse oven freestyle 662 and i was wondering how to replace the light bulb inside the oven
I had the same problem. I found the glass cover was just too tight to move by hand so after isolating the oven, I used an old cloth and adjustable pliers that could apply more pressure. This worked straight away.
try not to screw it on too tight.
cheers
Jan 19, 2011 | Westinghouse Microwave Ovens
Im after a manual for westinghouse freestyle fridge RJ422T-R
You can go visit onlinand Google.www.manual for westinghouse freestyle fridge RJ422T-R
Oct 23, 2010 | Refrigerators
Need an instruction manual for Westinghouse freestyle 745 wall oven, preferably in PDF, having trouble setting the clock. Can you help please?
instructions-manuals.com/search.php?...WESTINGHOUSE%20FREESTYLE...FREESTYLE%20920%20DISHWASHER
safemanuals.com/index_upload.php
www.manualsnguides.com/search.php?...WESTINGHOUSE%20FREESTYLE......
You can copy and paste any of the above links in your internet address bar under a new tab to bring you to your manual
Nov 12, 2009 | Ovens
Westinghouse Freestyle 668 oven not doing anything , just blinkin
Yes I can help.Hold down the buttoms on the far left at the same and then set the time using the + and - buttons.Cheers
Apr 20, 2009 | Ovens
Westinghouse Freestyle 476 Cooktop Oven
After getting an electrician out, apparently the time needs to be set on the oven. As we're in a rental & don't have a manual/ couldn't download one, we got it to work after holding the first two buttons in (the timer buton + the one that looks like a hot pot) along with the + button at the far right, which made the tim tick on, so it could be set.
The oven works now! : )
Aug 20, 2008 | Ovens
I have a Westinghouse Freestyle Multi-Function Wall Oven - 667. How do I set the clock?
thanks
Apr 30, 2008 | Kitchen Ranges
I hate my Westinghouse Fan forced oven Model Freestyle 688. The temperature control is so unreliable. It cooks about 100 degrees above what the temperature should be. It has been like this since new. I...
in the owners manual with most of the ovens it will tell you haow that you can vary the temprature of the thermastat 50 degrees up or down but not 100 you can try that and if it does not fix the issue then you will have to replace the oven sensor
Apr 27, 2008 | Kitchen Ranges
Kitchen Ranges Logo
492 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
