Question about Maytag MDB7100AWB Dishwasher
Maytag MDB7100AWB - Won't turn off or wash
About 6 months ago our Maytag (model MDB7100AWB) did not seem to turn off after its cycle is done. Initially blinking lights on the panel (cannot remember which ones) go off until you open the door. We then had to manually drain it through the drain cycle.
Now, it seems to fill, but does not go beyond that. Upon drain, it drains and sounds like the water is spraying. After timer counts down, it still hums.
We have been washing dishes by hand for 6 months now...please help!
    Sergeant:
    Champion:
  • 324 Answers
Sounds like a bad wash motor.
Posted on Oct 31, 2008
How much water does a dishwasher use per cycle
auto clean 4 to 10 gal
heavy wash 10 gal
normal wash 4 to 8 gal
light wash 4 to 6 gal
rinse only 2 gal
Jun 14, 2014 | Maytag MDB7100AWB Dishwasher
My Maytag dishwasher model MDB7100AWB stopped somewhere in the cycle & is making a soft clicking noise. It's full of water & I don't know if it did the wash or not. I turned it off & tried to restart but...
More than likely the control panel is defective. Contact the company at the link for troubleshooting help[ and also the parts that you may need.
https://www.repairclinic.com/
Jun 27, 2017 | Maytag MDB7100AWB Dishwasher
Maytag, model MDB7100AWB, acts spuratic!? 4 days ago it hummed most fo the evening, I just thought it was the fridge. There was water sitting in the bottom when I opened the door - and the humming...
probably the drain pump, access is underneath and to the right of pump housing, the drain hose connects to main housing and the drain motor is right and just behind where hose connects. open door part way for easier access. and use shop vac to remove as much water as possible, then have 2 or 3 bath towels to clean up if you try on your own. local parts house will have drain pump if you take model # with you
Dec 20, 2011 | Maytag MDB7100AWB Dishwasher
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
MAYTAG JET CLEAN DISHWASHER MODEL # MDB7100AWB, WILL NOT RUN THROUGH CLEANING CYCLES, TRICKLES WATER UP FRONT DRAINS VERY BRIEFLY, REPEATS THIS FOR A PERIOD NEVER KICKS INTO THE WASH CYCLE, THEN COMES UP...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101 ;';
Aug 24, 2010 | Maytag MDB7100AWB Dishwasher
Maytag MDB7100AWB dishwasher. 'High Current' during wash cycle. What do I need to do? Thanks
What problem is the "high current' you mention causing?
Many dishwashers continue to heat the water to a higher temperature to wash and rinse the dishes with. They turn the heat strip on to do this, which causes the dishwasher to pull more current.
Dec 16, 2009 | Maytag MDB7100AWB Dishwasher
Maytag Dishwasher not working right after storm/power loss
With the unit switched on , switch off power at the wall switch for a few minutes , this should reset the computer , if not you will need a service call.
May 03, 2017 | Maytag MDB7100AWB Dishwasher
Dishwasher doesnt drain on wash cycle,ok on rinse cycle
Change the circuit board, timer/progrsmer.
Take it out and clean contacts,
Look for burnt circuit line and solder a fine bead carefully on the circuit board, difficult. Use the pot and pan program.
Vitally
May 03, 2009 | Maytag MDB7100AWB Dishwasher
Maytag MDB7100AWB Dishwasher Logo
423 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
