Question about Hasselblad 503CW Medium Format Camera
Unsharpness I use a Hasselblad 503CW in combination with a leaf digital back. The camera is used on a copystand, lightning is cool light from Kaiser. Lenses are 120mm, 50mm and 80 mm. In the first testing images were sharp. But now there is always unsharpness except with the 80mm lens. Are there ideas how to solve this problem?
  • 36 Answers
If you can acquire sharp image with your 80mm, but not the 50mm and 120mmmm, there is no problem with your camera body, i.e. lens-flange to film plane. but how come you can not manage to get a sharp spot anywhere from the full turn of focusing rings with your 50mm and 120mm, unless the lens units inside these 2 lenses shifted. i doubt this happened to both lenses simultaneously?
if you are sure that your lenses have problem, send them for focusing test, since they are good and expensive lenses.
pc-cook
Posted on Jan 26, 2008
I can't seem to get the knob for film advancing off the camera body
There should be a small slide-switch on the wind knob itself. If you slide it back, the knob will rotate backward slightly and pop off the body.
Jun 15, 2011 | Hasselblad 503CW Medium Format Camera
When I shoot anything that has a light source in the image (interiors with lamps; windows; tubes in show cabinets; computer screens etc) on my 50mm.lens with my Leaf Valeo 22W back, on anything longer than...
You can set up the back light correction feature available on the camera menu , reduce the aperture and increase the shutter speed , Additionally the use of correct filters can also help , try not to focus with a back light flashing, avoid the direct but angle it out.
Sep 28, 2010 | Hasselblad Cameras
Download a user guide to the functions on a hasselblad h3d II
Here's where you can download a brochure describing your camera. This is also the website where you can download the owner's manual but you have to register with your e-mail address. http://www.hasselbladusa.com/downloads/product-brochures.aspx
Feb 05, 2010 | Hasselblad H3D Digital Camera
Adapt a Hassie 500el/m to a Imacon ixpress back V 4.7
The Hasselblad ELM does not need adapting to use the Imacon or hasselblad digital back  the following backs fit on the ELM and can be triggered with a cable that should be supplied with the back.
Hasselblad V96c 16mp square format back  Hasselblad CFV 16mp square format back with CF slot Hasselblad CFVII 16mp square format back with CF slot + larger screen
the following backs will work but need to have a V adapter plate fitted to the back
96c 16mp square format back  132c 22mp 645 format back  528c 22mp 645 format back with Multishot option CF-22 22mp 645 format back with CF slot CF-22 MS 22mp 645 format back with CF slot & Multishot option CF-39 39mp 645 format back with CF slot CF-39 MS 39mp 645 format back with CF slot & Multishot option
When fitting and digital back to an older camera the best advice is to get the camera body serviced to ensure that the back mount is correct as the digital backs require a better fit than the film backs did. If the mount is off it will cause back or front focus.
Mar 16, 2009 | Hasselblad 503CW Medium Format Camera
Whats the diff between the 503cw and the 503cxi?
The only real difference between the two is that the 503cxi have a too short, vignetting, mirror. The 503cw have a long, non-vignetting mirror. The vignetting is only noticeable in the viewfinder, and when using lenses 150mm or longer.
Both bodies will accept winder CW, and both have TTL flash metering.
/Chris
Jan 10, 2009 | Hasselblad 503CXI Medium Format Camera
Hasselblad 555ELD
I would check the top latch plate first. They do have a tendency to become loose. The latch points at the base could be slightly bent too.
Jul 24, 2008 | Hasselblad 555ELD Medium Format Camera
503CW with leaf back
Can you shoot rear curtain flash modes?
If not, try this:
Advance the camera.
Open up the shutter(set mirror lock-up). You'll have to remove the Winder CW to do this.
Push black Tap up to open up the shutter. Don't worry, lens is still closed.
You'll not see anything from the viewfinder, just black.
Trip the shutter button.
Now, check the images.
What do you get?
Try shooting under one second in low light.
Battery is new and not over 5 years old?
71% related to digital back
24% related to battery
4% related to electronic/mech problems & human errors
1% related to camera's back to digital back
atdlee@netzero.com
Feb 25, 2008 | Hasselblad 503CW Medium Format Camera
Which Hasselblad?
There were several versions of the 500C/M as production was over many years. The 501C had all the latest revisions of the 500 C/M series to make it the better choice. You'll get more $ for the 501 for this reason. Later versions of the 500C/M had a much better coil spring to control the mirror for starters. Unless you are going to use this camera for daily professional use, either would be a reliable camera. A good way to check the amount of use on any Hasselblad is to look at the back of the camera where the film magazine mounts. A good solid black with no shiny spots on the plate would indicate little use. There are raised lines around the aux. shutter opening that will wear as film back are removed and replaced.
Nov 12, 2007 | Hasselblad 203FE Medium Format Camera
Hasselblad 503CW Medium Format Camera Logo
202 people viewed this question
Top Hasselblad Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Hasselblad Photography Expert? Answer questions, earn points and help others
