Question about Panasonic Palmcorder PV-D209 Camcorder
Dew Detected indicator comes on. Battery was removed for 8 hours and the problem still exists. Camera has not been exposed to any moisture.
SOURCE: DEW indicator / battery
this is the worse camera i have ever owned. Sharp wont support it because they know its a crap camera. I will never buy any sharp product ever again. I dont usually check the internet when i buy electronics for problems before i buy, but know i check everything on the net before i buy.
Posted on Jun 05, 2007
SOURCE: Dew detected on DV-203
"Solution" suggested by mace biglow really works !!! After couple of hits the "Dew detected" message went away. Thanks
Posted on Nov 11, 2007
  • 3 Answers
SOURCE: Panasonic camcorder (NV-DS65) - Dew Indicator Problem
I found this on another site, but it WORKED great for me, and was a VERY easy fix, so I suggest everyone to try it before you go disassembling your camera. I know this sounds very stupid, but it actually somehow fixed my problem, so everyone should give it a go:
1) Turn the camera on.
2) When the dew icon is displayed, take off the battery and then hit/smack the spot on the camera where the battery goes a couple of times (not overly hard, but with some force).
3) Put the battery back and see if it's fixed. If it isn't, repeat the whole procedure. It took me about four tries but now miraculously my camera seems to be working, for the first time in about 3-4 years!!!
NOTE: I don't know what the exact "fixing" spot is, so I just hitted different places of the battery spot (both the upper and lower region). Take it easy first and don't hit too hard, see if it works and try again putting more force if necessary. I still can't believe this solved the problem, wish I'd tried it back when the problem first occured!
NOTE #2: I think this fix will probably also work on some other Panasonic cameras with the same dew problem - in fact, I think the guy who originally came up with this solution actually had a different camera model than I do.. I know it's a late reply, but hopefully this helps at least someone!
Posted on Sep 08, 2008
SOURCE: Dew Detected
Hi. I've had this problem a few times myself when I was tent camping or outside for a long time.
Remove the battery, and see what happens. If it keeps happening, I let it sit out of the bag for a couple of hours in the car with the battery removed.
I would not suggest hitting the camera.
Posted on Sep 15, 2008
SOURCE: Warning Dew Detected
Help.........evertime I turn on my camcorder I get the message 'WARNING DEW DETECTED' Then is shuts off after 10 sec. There is no dew!! I bought this camera new and have hardly used it.
Posted on Sep 24, 2008
When I turn the camcorder on, DEW shores on the screen, then it moves from the right to left of screen and camcorder shuts down
Moisture is an enemy of any tape based system. The moisture can cause the tape to "stick" to the rotating heads damaging both the tape and heads. This is why there is a "dew" sensor inside the tape compartment. The screen message indicates that the sensor has detected an excess mount of moisture and won't let the unit load a tape until the problem is cleared. Try leaving the unit open and pointing a hair dryer at it from a distance of about 12"-18". The warm dry air should remove any moisture that exists. Should this not resolve the problem, there is a defect in the sensor and it might need to be replaced.
Dan
May 29, 2011 | Sharp Viewcam VL-Z1 Mini DV Digital...
Dew detected show on lcd
The camera is telling you that there is moisture inside the unit, place the camera in a warm dry space for 24 - 48 hours to dry out, it should be fine after that.
Regards
Aug 01, 2009 | Panasonic PV-GS300 Mini DV Digital...
Dew lamp lights up and camera shuts down
http://ataplow.googlepages.com/sharp-dew-problem
Nov 17, 2008 | Sharp Viewcam VL-Z1 Mini DV Digital...
Dew detected
Leave the camcorder turned off in a place with constant dry temperature with the door open. Take the battery off and wait a few hours like at least 3.
This should work unless it is really damp inside then it may take longer. This happens when the camera is moved from heat to cold or cold to hot temperature. Both tape and camera need to be climatized to prevent this from happening.
Oct 03, 2008 | Quasar VM-L459 Camcorder
DEW DETECTED / EJECT TAPE
I know that this sounds odd but the fix is to remove the battery and hit the camcorder on the back (where the battery was) with the palm or your hand. Put the batter back and it will work. I found this soluation a a CNET web site solution. I don't know why it works.
Jun 05, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
Dew detected
This may sound stupid, but it worked for me.
Turn your camera on. When you get the dew detected warning, take your battery off and just hit the spot where your battery was a few times with your palm, not too hard, but not really soft. Put the battery back on and it should be fixed unless you actually do have a dew problem!
If that doesn't work, try drying it out with a hair dryer.
Dec 28, 2007 | Panasonic PV-L680 VHS-C Analog Camcorder
Sharp Viewcam z
either it has moisture in it (let it dry), or the dew sensor is bad and needs to be replaced.
Nov 29, 2007 | Sharp Viewcam VL-Z3U Mini DV Digital...
In your owners manual on page 52 you will find a list of authorized service centers. Give the one in your area a call. Give them the brand name and model number of the camcorder. Tell them you are having a problem with the dew warning coming on while using the camera with the battery. They should be able to help find a answer to this problem.You can also call the panasonic customer support telephone number at 1-800-211-7262 between the hours of 9am-7pm EST. Give them the brand name and model number of the camcorder and ask them for help with the problem of dew indicator coming on while in use with the battery. I hope this information helps you with your camcorder problem.
Nov 20, 2007 | Quasar VM-L450 Camcorder
Dew detected eject tape
I have the same problem with my PV-DV103. Panasonic wants more to TRY and fix it than the camera cost new. MY advise can the camera and buy one without the DEW option.
Thats what I am searching for presently . If the manufacturer says the camera has a dew indicator in the circuit - buy elseware.
Nov 13, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
I bought my 203 2 years ago-same problem. I FOUND THE SOLUTION! Might sound stupid, but I found it online, tried it and it works! When you get the "Dew Detected" sign on the screen, remove the battery, give it a good palm hit on the bottom where the battery sits. Hit it a couple good times, put the battery back in and voila it will work guaranteed! I thought it was dumb at first, tried it and it works, hell it works everytime. The blow dryer, plastic bag trick dont work because its an electrical error, not actual dew.
Sep 09, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Panasonic Palmcorder PV-D209 Camcorder Logo
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
