Question about Westinghouse L1975NW Monitor
Monitor has wrong resolution suddenly
I have a laptop, but the backlight burned out so I bought a L1975NW to use as the main monitor for another year, at which point I planned on buying a new computer. Everything was working fine, but today when I turned on my computer the display looked zoomed in and when i moved my mouse to the edges of the screen, it would scroll in order to be able to display that part of the screen. I checked the display settings for my computer and they were as they were before (1280 x 800). Then I looked at what the monitor itself was set to and it was 1024 x 768 for some reason. I can't change this at all.
The weird thing is that when my computer is turning on and is at the loading screen, the monitor is at 1280 x 800, but right before it gets to the user account screen it turns black for a few seconds and switches to 1024 x 768. I have an ATI Mobility Radeon 9600 graphics card by the way. Like I said, everything was working fine yesterday.
  • u2blah Oct 31, 2008
    I should've mentioned that my computer uses Windows XP, and I'm sure that it isn't because of an option made by the computer such as a magnifier tool.
  • Anonymous Jan 23, 2009
    I have the same res. dump problem. I even bought a new graphics card to try and fix it. Are there drivers for this monitor?
Set cpu hertz at 60hz
Posted on Nov 03, 2008
  • 488 Answers
Probably the accessibilty options are being used..look at this article:
in XP they are called "Accessibility Options
hope it helps!
Posted on Oct 31, 2008
Mac monitor resolution
Click on the apple icon in the upper left corner and select "System Preferences" from the menu to open the preference panel. Then click "displays" on the panel (it should be listed under hardware and will have a monitor icon). There you can see all of the resolution options.
Aug 17, 2012 | Westinghouse L1975NW Monitor
How can I fix an "Out of Range" display?
Please reduce display resolution of computer/ laptop to solve "out of range" error because laptop is producing high resolution video signal and monitor hardware is unable to show that much higher display resolution so causing that error message.
Let me know what Windows version (XP, Vista, 7) is running in laptop to provide you more info or check Display Properties in control panel and change it to lower resolution to get picture in monitor.
Feb 09, 2011 | Westinghouse L1975NW Monitor
L1975NW Monitor: My monitor is very dark; too dark to even see how ...
More likely the backlight is not on, check the caps (leaking/bulging tops) in the power supply first, then check the fuse in the inverter circuits, when the caps went out it may have taken out the MOSFET for the inverter transformer with it. See failed WESTINGHOUSE and other monitors due to bad caps.
May 16, 2010 | Westinghouse L1975NW Monitor
IBM Thinkpad R51 screen blacked out
try to plug in a extrernal monitor and see if that works if it does your backlight went out
Jul 21, 2009 | Computers & Internet
How to check if its just burned out & not tech. problems
It sounds like you have a monitor with a common problem, this series ofWestinghouse monitors are known to have this issue. After a few yearssome LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. When thecapacitors blow out they also damage the driver MOSFETs. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site You can take the back cover off your monitor and look for the bad parts, replace any that look like the picturesand your monitor should work fine. The capacitors do need to beinstalled with the correct + and - connections, note the stripe on theold one and insert the new one the same way. I am putting together astep by step repair guide for this series of LCD monitors, it should beup by 07/11, check my web site for the guide. Repair parts kits are also available for $16.95 If you don't want to trythe repair yourself we offer a repair servicefor $35 plus shipping. If you are not going to repair it we will buy it from you for parts, we pay $30 for dead/as-is units.
I hope this helps, if so please rate my solution.
Corporate Computer
Over 21 years of computer and printer support/repair
Mar 26, 2009 | Westinghouse L1975NW Monitor
Wrong plug-n-play display selected.
double adapter output display adapters generally need a multible monitor driver to run correctly,
see here
Oct 17, 2008 | Westinghouse L1975NW Monitor
New resolution problem
The resolution of your monitor depends on the driver. If your driver supports for the resolution which you want you can set it otherwise its not possible to change.
Mar 23, 2008 | Westinghouse L1975NW Monitor
Westinhouse L1975NW Monitor
You can check your monitor .Restart your system and press F8 till it appears "safe mode" then select safe mode and press enter if display comes.then run your system on that LCD monitor.When desktop appears right click on desktop blank area then select property option.then press setting tab and select advanced option.Then select monitor tab in next window and select minimum frequency(ex-60 hertz).
Feb 29, 2008 | Westinghouse L1975NW Monitor
New widescreen Monitor
You should download latest graphic card drivers from this link below
Feb 27, 2008 | Westinghouse L1975NW Monitor
Just look for the newest driver there is for your graphics card. Try here
If you still can't set the resolution to match the optimum for your new monitor then the graphics card isn't capable of matching it. You could add a new graphics card.
Feb 26, 2008 | Westinghouse L1975NW Monitor
Westinghouse L1975NW Monitor Logo
211 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
