Question about Westinghouse Washing Machines
My Westinghouse LT609s washing machine, is saying SF and will not wash. It has filled with water but wont wash and is flashing the letters SF...What does this mean
  • 10 Answers
SOURCE: washing machine no cold water
chnge your water valve or your cold water hose. something could be blocking up your hose. also when you ask machine for cold water does the machine hum? if so check to see if cold water is on. if the water is on then replace your water valve.
Posted on Feb 10, 2007
SOURCE: washing machine wont fill
It could be a bad water valve or it could be the board that controles the valve, I would check first and make sure that the two water hoses where they connect to the washer are not limed up or have some build up of some kind, you can turn the water off and disconect at the washer and visualy ck to see.
Posted on May 10, 2007
  • 641 Answers
SOURCE: Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
Posted on Aug 31, 2007
SOURCE: indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Posted on Feb 27, 2008
  • 1028 Answers
SOURCE: No Drain light flashing on washing machine
ckd for something stuck in pump newer models have a low torque electric pump easily stalled by lint or even tooth pick
Posted on Jun 02, 2008
My usually trustworthy Westinghouse LT609s won't start cause it says the lid is open when it's not. Is it done for?
not necessarily
it could be the out of balance lever on the wrong side of the lid switch
lid switch or program board
before you make a decision to junk it ,have a technician check it out and get a quote to fix
Dec 28, 2015 | Westinghouse Washing Machines
Westinghouse lt609s Washing machine has stopped and will not progress HC error
Possible fault in the main program controller unit. It is important to test the sequence and output of the program , the voltages to the motor during the wash cycle drive motor, the input valve and output valve voltages at the point of cycle to confirm the program controller.
Mar 23, 2011 | Westinghouse Washing Machines
White westinghouse 8cycle washer will not spin or drain now it wont do anything model number WW5833ES1 i thought it might have been circuit related so i reset the fuse box and removed the clothes from the...
does it fill with water yet?if so then its the lid safety switch that gone bad under the top lid,this will kill all cycles other than fill,if it doesn't fill with water either then the timers defective
Jan 01, 2011 | Westinghouse WWS833ES Super Capacity Top...
We cannot get water running into the tub of the machine (WWT61M). How should the water getting in look like? Do we need to remove something inside the water entry?
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
Sep 20, 2010 | Westinghouse Washing Machines
Model LT609S Washing Machine Bad Smell After Washing
A problem like this can be difficult to resolve using cleaning solutions alone.
See this FixYa Tip for some strategies that work well in eradicating mold which is the main cause of this problem.
If you find the solution helpful please leave a vote for it. Thanks.
Apr 06, 2010 | Westinghouse WWS833ES Super Capacity Top...
MAchine fills slowly. Have cleaned the screens.
Check the solenoid. You can swap the hot and cold water hoses and set the wash for hot but cold will come out. Then you can see if the flow is better. If it is the cold valve isn't opening all the way.
Mar 11, 2010 | Washing Machines
Washing machine starts filling then wont go any
there are a lot of questions of a simular nature check the diaphram switch this controls how much water is taken in and wont progress until the switch says so what you dont say is if the machine keeps filling or stops filling and wont progress
Jan 16, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Leaking westinghouse 9.5kg washing machine
a hose has partially come off or a cut in the hose
Sep 06, 2009 | Westinghouse Washing Machines
Westinghouse washer lT609s - tap problem
if I understand you correctly ... your washer keeps filling with water and you must shut them off at the wall to stop the water from coming into it?
this is a stuck water valve .. there may be something in your water valve keeping it open...
unhook your hoses and check them..
hope this helps
Apr 05, 2008 | Washing Machines
Aug 31, 2007 | Washing Machines
Washing Machines Logo
481 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Mack Baxter
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
