Question about Sony Walkman D-EJ361 Personal CD Player
Disc will stop after a few seconds when turned on.
After closing the portable CD player, it will not play. The CD is turning but not playing, after a few seconds, it will stop and the display will disapear. I discovered the lens is not moving inside, is there a problem on the discs driver IC?.
  • 163 Answers
SOURCE: Cannot play this disc
remove the cover and see if the dvd run, if not you got a motor problem or a motor drive one,if yes then try cleaning the reading eyes(pickup)by blowing dry air (get a can at radio shack)check for goods, if dosent work, take it to a shop for a repair thats all you can do, is a job for a tech....good luck
Posted on Aug 10, 2006
SOURCE: Moved CD changer with discs inside - won't "reset" / work
CD PLAYER WILL RESET BY ITS SELF WHEN MAINS SWITCH IS PUT ON, SOUNDS LIKE YOUR MECH IS JAMMED TRY TO FIGURE OUT WHICH GEAR UNLOADS THE PLAYER DRIVE AND ALSO UNLOAD MANUALLY
Posted on May 18, 2007
  • 231 Answers
SOURCE: Tray Opens and Closes Repeatedly After Disc Jam
check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Posted on Dec 03, 2007
dankind38
  • 6 Answers
SOURCE: SONY SLV-350P DVD PLAYER/VCR COMBO
I'm afraid you are dealing with a weakened Laser on the unit. The cost vs. benefit ratio of fixing this unit is not worthwhile.
You will find that there are newer versions of this device on the market less expensive than what you paid for the unit you have now.
Posted on Dec 30, 2007
SOURCE: Sony Walkman D-NE004
I assume you've tried batteries, cleaned the laser, etc. If so, then the laser might be knackered!
Posted on Mar 20, 2008
How to turn it on to play CD?
Personal CD Players usually have a on/off button or sometime a play and stop button. links below,
press the helpful button
Playing portable CD player
Rio Portable MP3 CD Player
Sony Portable DVD player teardown repair
Top 10 Portable Cd Player
Feb 04, 2016 | Audio Players & Recorders
The player will read dvd but will not play cd
Richard: This is what EHow.com said: "
  • Turn on the DVD player. It generally takes a few seconds to get going. Take out the DVD if there's one in the drive already.
  • 2 Make sure the disc isn't scratched or dirty. Use a soft rag to clean the disc if you see any smudges. Insert the CD into the DVD player's disc drive and close it.
  • 3 Press the "Play" button on the DVD player or remote control. Some DVD players will begin reading the disc automatically. Pushing the button works just as well.
  • 4 Use the "Scene Selection" buttons on your remote to select a track. Some DVD players have odd ways of ordering the buttons on the remote. You might have to play around a bit before you find all the right buttons to work the CD playing function of your machine.
  • 5 Crank it up and enjoy your music. The DVD player will act just like a CD player and play the tracks of the CD through the TV.
  • Read more : http://www.ehow.com/how_2036285_use-dvd-cd.html
    May 28, 2015 | Televison & Video
    Technics SL-MC60 error message: "Take out"
    Hello
    If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
    Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
    Feb 03, 2012 | Audio Players & Recorders
    Unlock Toshiba DVD player SDP93S bought in America to play Australian DVD's
    Thanks for understanding. Please let me know if you require any clarifications.
    Jul 09, 2011 | Toshiba SDP93S Portable DVD Player
    Disc does not spin and shows on screen that there is no disc
    With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
    Mar 29, 2009 | Mintek MDP-1810 Portable DVD Player
    CANNOT OPEN PLAYER
    To open the drawer, unplug the unit while the power is on (so that the drawer doesn't try to open on its own). Keeping the unit flat on a table, look underneath and find the small hole where you can turn the loading gear. Rotate it until the unit opens, using a standard flat screwdriver. The loading gear is a white plastic part with a slot in it. You should be able to see it rotate if you move the drawer by hand.
    After manually removing the disc, turn the gear with your screwdriver until the drawer is all the way in, The gear should be able to be turned for three or four more turns when the drawer stops loading. If it doesn't, turn it a bit further unit it "pops" past one more gear notch. It should then turn freely for a few more turns, at this point you should stop. Do not force it once it stops the second time. This is the "Disc Loaded" position.
    Power the unit back up and see if it loads a disc and plays correctly.
    Dec 18, 2008 | Sony CDP-C445 5-Disc CD Changer
    Disc Error when I try to play a dvd LG DP781
    Sounds like either a dirty or weak laser/lens. Pls try cleaning with a CD disc cleaner or manually using cotton buds (if the eye is accessible).
    Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
    Nov 17, 2008 | LG Televison & Video
    Cd's wont play
    can you please post here the model and the part # of the cd player.. & please kindly inform me the type of cd she play in the unit, is it a Audio CD..?
    Thanks..
    Apr 16, 2008 | Audio Players & Recorders
    DVD stopped playing all DVDs
    Reset you player by doing the following:
    With the player on, hooked properly to your television, and on the correct station:
    Open the tray
    Close the tray (with no DVD inserted)
    Hold the stop button down for a full 5 seconds
    The CyberHome screen should appear. You should be able to play your dvd's now.
    Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
    Mintek MDP-1815 dose not play disc
    Please supply me with all the types of equipment that you have connected together and the configuration....accordianman
    Jan 13, 2008 | Mintek MDP-1815 Portable DVD Player
    Sony Walkman D-EJ361 Personal CD Player Logo
    Top Sony Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Gyula Lacz
    Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
