My HomeBest digital thermometer says "E" and won't take my temp anymore. How do I reset it or make the E (for error I assume) go away?
3 Suggested Answers
raegirl186
  • 25 Answers
SOURCE: The digital thermometer was flashing
there should be a setting on it that changes the temp from Celsius or "c" to ferinheight and lo means that it currently isn't reading a temperature in the normal range. try running it under hot water and see if it says error or high.
Posted on Jul 15, 2011
  • 158 Answers
SOURCE: I have an oxo digital thermometer. The readout says 888. I assume that is an error code. What should I do?
Try removing the battery and let it sit for a minute or two. Maybe that will reset the thermometer.
Posted on Dec 02, 2016
Dec 02, 2016 | Hardware & Accessories
It says LL under current temp. What does that mean
That means that sensor believes the temp to be LOWER than it can read. Could be a bad sensor. If there is a reset button on the sensor use that to reset the device.
Sep 23, 2013 | Taylor 1479-21 Digital Thermometer
Instructions for springfield precise temp model 91455
I also reset my 91455 today. Go online to Springfield precise temp manual 91455
May 29, 2012 | Springfield 91455 Wireless Digital Outdoor...
I have a 2002 Saturn L200. The service light has gone on, How do i reset the service light? I recently added a fuel cleaner with the last gas fill up and now the gas float sticks.
there is an oil change light, if that is what you are talking about the instructions to re-set it are in the owners manual. Two folks required as i recall, one pushing a button in the underhood fuse panel while the other holds the ignition switch in a certain position for a certain number of seconds.
If you are talking about the service engine soon "SES" light on the other hand; say you had a kid with a high temperature, would you throw away the thermometer and think the sickness was cured because you could not see a high temp anymore? no, and that light works the same way, if it gets cleared by a diagnostic, the error it senses will just turn it back on because that is the way it is supposed to work. so you need to find out what the problem is and fix it, then the light will go off as the error will not be sensed anymore.
Jul 21, 2011 | 2002 Saturn L-Series
The digital thermometer was flashing "lo". I assumed it needed new batteries and then replaced them. It is still flashing lo, but also showing a C reading. What do I need to do to reset it?
Jul 15, 2011 | Prestige Medical Infrared Ear Thermometer
We replaced the toner cartridge and the waste receptical and the little red light "Add Toner:" is still on and the machine won't copy. We have removed the cartridge and did the dance...
If it is a Kyocera toner than that is the problem. The key to turn the toner is different for the Kyocera toner cart. It will fit and appear to work but won't. Also turn the unit off and unplug for 15 sec. will reset and perform boot up procedures might help.
Jul 07, 2011 | Copystar CS-1810 Copier
I need to reset the service engine soon light
it will just come right back on unless the error is fixed. if you do not want to pay to get it fixed pound an ice pick through the light and knock it out forever. it is telling you something is wrong.
if you run a very high temperature, do not contact a medical professional, just throw away the thermometer so you won't know your termperature and you can't be sick anymore. same thinking.
Jan 07, 2011 | 2001 Ford Escort ZX2
In "Heat" mode, the displayed
You have something else going on. The tstat is probably sensing a remote temp. Is it hanging on the wall next to the furnace? Maybe warm air is coming from the furnace closet and fooling the tstat? Or an appliance or TV located too close to is, and heating it? If its quickly increasing the temp during unit operation only, it may be sensing air through the hole in the wall, directly being the tstat, where the wires come though to connect to the tstat. Try plugging that hole and test it. Or possibly the ceiling register that supplies air is facing the tstat, warming it by blowing hot air directly at it. If that's it, remove the grille and face it away. Not sure what else it may be. Hope this helps!
Mar 25, 2017 | EdgeStar Portable Air Conditioner ...
G E oven temp fluctuation
No, that is just fine. As a matter of fact, older ranges often had 50 to 60 degree swings in temp. Your oven temp (assuming your thermometer is dead on accurate) is 347 + 365 / 2 = 356 degrees when set at 350. I never mess with ovens which are within 10 degrees of set temp. (when checking the temps, make sure to take the readings after the oven has cycled on and off at least three times, and use a good digital oven calibration thermometer)
Mar 18, 2009 | Kitchen Ranges
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
