Question about Shuttle XPC SN25P Barebone
Shuttle XPC SN25P locks
Hi - my Shuttle XPC SN25P locks, usually when I'm trying to transferring data with a device contected to a USB port. I see the text below on a website "There is an issue that causes a conflict between the X2 CPU and the USB 2.0 ports that can cause the system to lock up. It has been corrected by Shuttle in a new BIOS but most shipping systems will be using an older BIOS." I wonder if there is any workaround for this?
http://compreviews.about.com/od/motherboards/gr/ShuttleSN25P.htm
5 Suggested Answers
WhoDoctorK9
  • 41 Answers
SOURCE: need to enable audio device on Shuttle sn25p
Follow this link to the drivers for your computer.
http://global.shuttle.com/download03.jsp?PI=89
Posted on Mar 29, 2009
info2u
  • 596 Answers
SOURCE: Integrated ethernet not recognized by XP after fresh install.
Realtek 8201BL chipset is the network drivers you will need. You should be able to find this online. When you do download the drivers, be sure to download the 64 bit drivers for your systems or you will run into further problems.
Good Luck
Franklin
Posted on Jul 21, 2009
  • 5 Answers
SOURCE: shuttle xpc suddenly turns itself off
Could be overheating.
Suggest you check the Processor Fan is working, usually you can hear it.
If it stays on longer when starting from cold then that could indicate fan trouble.
Most PCs have onboard sensors which can be monitored by programs like Speedfan see http://www.almico.com/sfdownload.php then click on SpeedFan 4.39
Good Luck
Posted on Aug 14, 2009
zabrinaliang
  • 15 Answers
SOURCE: I have a Shuttle SS56 XPC KTS24.5G1e at X5 misssing.
Check with your local computer store.
Posted on Dec 08, 2009
Shuttle computer will not finish boot up process
This is usually because the operating system is corrupt. Try to start the computer with the OS disk in the drive. This may work, if it doesn't I would suggest getting a new copy of the OS.
Jun 24, 2012 | Shuttle Computer Shuttle Xpc X27d-bk-v1...
Hi - I have a shuttle xpc sxh57 core i7 model. A couple of days ago - it stopped sending a dvi signal to the monitors. I have replaced the video card, tried clearing the CMOS and cleaned dust. The fans and...
I suggest try the HDMI connection on your machine and see if its able to give display, since you purchase a new Video Card I assume it have a HDMI port. Or try different monitor with a DVI port if you really want a DVI connection, If it works it means the DVI port on your monitor is faulty.
Hope it helps.
Apr 20, 2011 | Shuttle Computers & Internet
My pc is bieng attacked by viruses..what should i do?
Check with your local computer store. Get a virus protection program.
Nov 14, 2009 | Shuttle SN25P XPC nForce4 Socket 939 Small...
Shuttle xpc suddenly turns itself off
Good Luck
Jul 28, 2009 | Shuttle SG33G5 (XPC-SG33G5) Barebone
Factory restore
You can export address book:
click File -> Export -> Address Book -> Seleck "Text file(comma separeted values)" -> select folder on your usb drive you want to save address book, click next, select what info about your contacts you want to export.
Apr 26, 2009 | Shuttle XPC SD32G2 Barebone
Need to enable audio device on Shuttle sn25p
Mar 29, 2009 | Shuttle SN25P XPC nForce4 Socket 939 Small...
KVM not switching
Hello!
From my experience I can say that such switches are very buggy, and don't function correctly most of the time.
I suggest you check that you have drivers for the USB keyboard installed on the Windows 98 machine.
Try by plugging the keyboard directly into the windows 98 machine and see if it works.
Hope this helps!
May 02, 2008 | Shuttle XPC SN25P Barebone
SAMSUNG SGH A-707 USB CONNECTION
Yes it might be the problem..First try a different cable..Also check the data transfer port(wher you connect the cable)on your phone for bent/broken pins..If the pins aredamaged you will have to get a new data port and dont worry its very cheap..usually 5$ or less..
Oct 19, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Shuttle XPC SN25P Barebone Logo
42 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
