Question about CyberPower Office Power 585AVR (obcps585avr_1) UPS System
585avr isn't working w/vista OS,
I'm using a radio shack serial to usb converter. There are a lot of issues w/drivers but I believe I've located and installed the latest, which is supposed to work w/vista (got it from floridaprobe.com). The RS device apprears to be working ok according to the device manager. But the ups does not register any connection via the serial port. Any ideas??
thanks in advance
  • Rich Camlin
    Rich Camlin Nov 22, 2008
    Holy ****! Don't ever click on "More Options" after typing a long response. When I came back it was all gone.
    Anyway, the connection problem is now solved--see below (was a conflict w/com4 usage). I am now trying to get some sort of s/w to control the shutdown process. The PowerChute product does not recognize this particular model at installation (and the installation just quits at that point). Any ideas/suggestions?
    Thanks for your promptness and comprehensive response.
    rc
    Problem Solver:
  • 10 Answers
While the 585AVR is not designed for Vista, it should work. You will need to use the CyberPower serial to USB cable, and the most recent version of PowerPanel Personal Edition software. You can download the latest software @ http://www.cyberpowersystems.com/software/PPPE_V_1.2.2_Setup.exe
If you have any questions, or need the CyberPower serial to USB cable, please contact CyberPower Systems Technical Support at 877-297-6937, M-F, 8-5 Central.
Posted on Nov 18, 2008
Will my PED BASIC work with windows 10
There is a version of the Brother PED-Basic that will work with Windows 10. Go to http://support.brother.com/g/b/downloadtop.aspx?c=us&lang=en&prod=hf_basiceus , and accept the EULA. This is a free update.
However, check if your sewing machine will work with Windows 10. The list is here: http://support.brother.com/g/s/hf/os/windows10/win10_hsm_us.html . With some sewing machines, no USB driver is available for Windows 10. For these, you need to put the designs on a USB flash drive to import them on the sewing machine. For other machines, you may need to add a serial port card to the computer or get a USB to serial port converter to connect the card reader/writer. See https://www.amazon.com/Trendnet-TU-S9-USB-Serial-Converter/dp/B0007T27H8 for one model. (Note: you may need a different converter. The best converters have an option to change the pin assignments. A lot of older serial devices did not use the pin standard that was eventually developed.)
I hope this helps.
Oct 29, 2017 | Sewing Machines
My windows xp computer gives me a message that WASP USB to Serial converter is not compatable. It suggested I try to find a device driver that is compatable with win xp. Please Help. Thanks. Paul
there's a problem with the OS in the registry, the unit itself doesn't need a driver, the OS supports it directly.
OS = Windows Operating System.
Try the unit on a different system. If it works, look to your system registry
if it doesn't , the unit may be defective (most likely is)
Mar 21, 2011 | Wasp USB to Serial Converter...
OCT INC. USB Serial Converter driver Vista
hi
i am techbuddies from fixya group in your issue i would like to say that please try to contact the company techsupport and their number is 886-2-2910-7090
if you get the same problem then please try to get intouch with me on fixya
thanks
techbuddies
Jan 03, 2010 | Computers & Internet
Radio Shack Serial to USB Cable
you'll need vista drivers for that which radio shack didnt make for my cable so i replaced it
Jun 08, 2009 | ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI...
Webcam gigaware 25-234
You need to go on line to the manufacture and download the VISTA driver for your camera and then follow this info to install.
Normal 0
Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Oct 30, 2008 | Radio Shack VGA PC Camera Webcam
SiPix Pocket A6 Printer Windows Vista Driver.
SiPix never had a Vista driver. Most new computers, like mine, do not have serial ports. Here is how I got my A6 working with Vista --
1. Purchase a serial to USB converter cable. (I got mine on Ebay for about $4.00.) Plug one end into the serial cable that came with the A6 and the other end into a USB port on the computer. Vista automatically picked up and installed the converter cable. In Device Manager, it shows up under Ports and gives it a com port number. Right click on the device and click on Properties. Click on the Port Settings tab and change Bits Per Second to 115200, Data Bits to 8, Parity to None, Stop Bits to 2, and Flow Control to Hardware per your A6 Owner's Manual. Click OK.
2. Now go to Printers in the Control Panel. Click to add a printer. Follow on screen prompts. Whe asked what port the printer is on, highlight whatever port the USB converter cable was assigned to. (In my case, Com 4.) When asked for the driver, direct it to the CD Drive where you have the A6 driver disk. Direct it to the Windows 2000 driver. If you try to use the XP driver, it will tell you it is the wrong OS. The 2000 driver will install. Your A6 should now be installed and show up in your list of printers.
My A6 now prints from any program or the internet using Windows Vista.
Aug 17, 2008 | SiPix Pocket Printer Thermal
Gigaware USB to Serial Cable software
No need for disc, don't worry.
Radio Shack/Gigaware 26-949 USB to Serial Cable drivers (32/64bit) can be found at driverupdate us
I hope I have helped you...
Take a look, and enjoy
May 07, 2008 | ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI...
Radio shack Pro-433
Look at www.radioreference.com This is the most complete scanner site on the web. Just register and then search the forums for what you need.
Jan 18, 2008 | Radio Communications
CyberPower Office Power 585AVR (obcps585avr_1) UPS System Logo
160 people viewed this question
Top CyberPower Computers & Internet Experts
George Nalley
Level 1 Expert
Paul Bade
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
