Every day the computer stops for about half minute then come back again says at the bottom local connection now connected and usually occurs after switching on after half hour then so okmodel dsl504t 4 outlets on modem hope able to help me
  • coljan Oct 31, 2008
    not on wireless broad band put on month ago is better than was cut off twice today seems happen about 20 mins after starting of the puter then no do again for thef day says at botom when comes back on after about 15 seconds local connection now connected telkstra must have improved it a lots better than it was thanks hope able suggest a solution coljan
  • coljan Nov 01, 2008
    have told you not got wirless connection broad band , only connected a month and was worse when first got connected the problem is that internet is connected after about 20 minutes all stops for about 20 seconds then connect back up again and is ok for rest of the day thanks hope is clear now
  • 33 Answers
Are you saying your computer stops responding while you are on the internet? If you loose your local connection to your network, you loose your connection to the internet. Do you have a wireless connection?
Posted on Oct 31, 2008
  • TF Oct 31, 2008
    No offense, but I'm having difficulty understanding your problem. Please be more concise with your wording.
  • TF Nov 01, 2008
    In the early days of DSL, many USB DSL modems distributed by several US ISPs were plagued with connectivity problems. For no reason, the modem would simply loose its connection. The only way to reestablish the connection was to reboot the computer. On the other hand, some internal DSL modems were plagued with driver problems. DSL modems have definitely seen more than their share of quirks.
    Make sure you are using the latest drivers for your modem and operating system. However, I would not recommend updating the firmware without positive confirmation that the firmware is the problem.
    Unfortunately, without a more detailed explaination of your situation, its hard to determine the source of your problem.
    I've looked around the internet, and some people seem to be having problems simliar to yours.
    Here is a link by Swiftinter.net for trouble shooting this modem.
    http://www.swiftinter.net/troubleshootin...
    Hope this helps! Good luck!
Error code 800233EF
The error code 800233EF indicates a connection error occurred during your download.
This may be caused by a local connection issue. Please stop the download then restart your it. If this fails, the server or network may be temporarily busy. In this case, please try your download again later.
You can also try resetting your network equipment by turning it off for around 5 minutes.
Dec 26, 2015 | Sony Playstation 3 (PS3) Console
2003 Ford Expedition intermittent engine/ignition failures
this could be because of the fuel pump not functioning properly.
Oct 11, 2008 | 2003 Ford Expedition
I have a D-link DIR-655 wireless router . I have two computers wired to the router and I run a wireless laptop. A couple time a day I lose connection and get a message thay says "local connection...
Make sure the power setting does not allow the ethernet card to be shut off. Also look through the other settings on the ethernet card properties menu. Some of those affect the stability of the connection. You access the setting through device manager.
Aug 04, 2017 | D-Link Xtreme N DIR-655 Wireless Router
MONITOR DISPLAY PROBLEMS
the display has a loose connection in every side. try pressing the both side by hand.
Jun 14, 2009 | Computers & Internet
WIreless router - internet connection cuts out
there might be a signal problem repair the connection to change its ip address by right clicking on the connection icon which is found at the bottom left beside the clock if the problem still persists, check the cables of the router
Feb 10, 2009 | Acer Aspire 5100 Notebook
Could be a little thing's, security system issue, fuel issue or a EGR or Throttle senser issue.
Mar 15, 2017 | 2003 Ford Expedition
Black on bottom of screen
do me a fovor, i need your firmware version? to do this, press Input 619. in the center of the bottom of the screen, is three digits 5?.? please provide me with these numbers. you may just need firmware updates.
Sep 28, 2008 | Dell W5001C 50 in. Plasma HDTV
1999 Toyota Camry Idle Problems on Hot days
Clean the IAC. Disconnect throttle body air hose and you will see a hole on the bottom of the throttle body just before the butterfly valve. Spray throttle body cleaner down the IAC hole and then let it soak about 1/2 hour. Reconnect hose and run engine about a minute and then repeat this process 2 or more times. Toyota engines from 1997-2005 commonly have the IAC get cruded up with carbon as early as 35,000 miles. This is a sImple and cheap repair that many repair shops don't want you to know.
Jun 25, 2008 | 1999 Toyota Camry
Temporary connection loss
The issue is now resolved. I found the solution by trawling through the 2wire troubleshooting website articles...
Here's how I fixed mine:
1) open the Management and Diagnostic Console by entering 192.168.1.254/mdc in the address line in your web browser.
2) click on 'Configure' under the heading 'Local Network' on the left column.
3) change the 'set DHCP lease time' to 999hours (instead of 24hours) - this stops the router from resetting itself every day.
4) click on 'wireless' under 'Local Network' in the left column again.
5) change the 'power setting' to 10 - ie maximum - this boosts the wireless signal, which means it's less likely to be dropped.
& that did the trick. Been working continuously now for the last month and a half! :))
Nov 03, 2007 | 2wire HomePortal 1800HG Router...
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
