Question about Sony KV-35V35 TV
Tv flashing When tv is turned on there is sound but the picture takes about20 to 40 minutes to come on and when it does it just keepes on flashing and wont stop.Also the picture is not as bright as before is there any thing i can do about any of these two problems.also how easy is it to fix.
  • Clive Marzouca Sep 26, 2006
    Thank you for responding to my problem i did as you suggested and the problem was still there but whle the back was opened i noticed a black knob on the power supplie so i turned it to the right a little and the problem stoped. Thank you verry much.
    Scholar:
  • 39 Answers
Well nice solution, but i don't think it's right at all. The problem is your CRT that is shorted. You probably have a H-K short (heater to cathode). It's pretty common with these sony models.. Try tapping lightly on the CRT neck, picture might come back on. You've got a short there. Thanks, cheebster.
Posted on Aug 22, 2007
    President:
  • 3,130 Answers
The picture tube is intermittant and one day will not stop flashing,This is a very very common problems with sony picture tubes. A tempoary fix is to lower the G2 or the screen control on the flyback transformer. Good Luck
Posted on May 02, 2007
I also have the same problem. Thanks for posting the problem and thank you for the informative solution!
    Novelist:
    Champion:
  • 275 Answers
I could be wrong, but, from your description it looks like a cold solder, most probably in the Filament Heater circuit. If you are well versed in Solid State Electronics, I suggest you look for a loose solder or joint. Shut OFF the TV, Open the rear cover and chech for any dry dolder or loose coonections. Start with the CRT Neck PCB. Follow the tracks from the two Heater Pins (Marked H H) on the base). Also, gently remove the Neck PCB gently from the Picture tube, and (very carefully, mind you!) clean the Picture tube Contact Pins. Again, very slowly and gently, replace the PCB. Try your TV again. Let me know if the problem is solved. As for the second problem, ( less brightness) how old is your TV? Over time the emission from the Picture tube Electrodes becomes less, and picture quality detoriates. If set is over 6-7 yrs old, or if you are a heavy user - that is, you have your TV switched on for 6-8 hours a day, it is time to go for a trade-in. But, if you are very attached to the TV, you can always take it to a service shop, where they will re-condition the Picture Tube for a modest amount. It's life will get extended by a couple of years.
Posted on Sep 14, 2006
Why doesn't it turn on?
Probably the failing power supply finally failed completely.
Mar 07, 2016 | Samsung Pn64d8000 64-inch 1080p 600hz 3d...
PANASONIC PT-61LCZ70 when the set is turned on it takes a minute to power up then its on for a few minutes then the picture and sound turn off and the green power light flashes 25 times and the set turns...
Hello, have you replaced the lamp, it sound like the lamp is failing, it may also need the fans cleaned (the main reason for pre-mature lamp failure). Replace the lamp with a genuine Panasonis or Osram lamp only....tks
May 26, 2014 | Televison & Video
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Have picture lose picture tv turns off and on
the lamp has a life cicle. if yours is been used a lot. then the lamp has to be changed. when the tv cannot turn on steady and gets off imm. the computer inside the tv tries to turn off the set but the lamp charges again and the micro tends to keep working. the first step to take in this tv is to change the lamp to eliminate this common source of problems
Jan 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by...
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by light (red) flashes on/off until just before picture first appears .if your tv is very old than it might be due to crt getting weak crt base loose loose contact in power supply thanks
Sep 09, 2007 | Sony KV-32S12 32" TV
Tv Flashes
key2life316,
Your TV has a bad picture tube = no reasonable repair possible......time to go shopping!....................T.
Guest,
Your TV has a bad pix tube + a blown power supply!!
Time to move on ........T.
Aug 25, 2007 | Sony KV-35S42 35" TV
Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Apr 07, 2007 | Sony KV-27FV16 TV
Sony 27"TV will not turn on
The picture tube on your tv is dead, you need to replace it. It probably will be worthing just purchasing a new set, because the cost of repairing it will be close to the purchase of a new one.
No picture just clicking sound
with your model number manny have a defective flyback part number is 1-453-310-11
regards,
daniel.
Mar 31, 2007 | Sony KV-27FV16 TV
Picture Flashes off and on
probably the tv has a loose solder in the board. this is normal especially when tv is aging. most of the components inside are emitting heat resulting to loose the solder. try to inspect and resolder if possible. but if you dont have the proper tools and equipment and you're not inclined with this kind of job, better bring it to a qualified tv technician. good luck!
Jan 31, 2007 | Sony KV-32S45 32" TV
Televison & Video Logo
98 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
