Hi, i use msn hotmail for receiving my emails. before printing i select a4 size paper and press ok. when the printed message appears it is in a5 size with text around sides cut off. i can print anything else in a4 and prints ok.but not emails. can you help please?
    Master:
    Sergeant:
  • 449 Answers
Hi!!!!
may be there is a settings in your printer that can only print a5
try to check settings first before you print
or try to copy and paste in the ms word
Posted on Oct 31, 2008
How do I reset my SX215 to factory settings
When you are in the application that you are going to print from. Go to the menu bar, click on File - Page Setup. Here you should be able to change the paper size you wish to print out in. If you want to set the paper size by default to A4, then you will need to (Windows7) click on the Start button - Devices and Printers, select the printer that you want to change the paper size, right click on the printer - Printer Preferences, a dialog box appears, select the paper size you want in the paper size drop down list, click - Apply - OK. This should then have set the paper size to A4 by default.
Feb 26, 2015 | Office Equipment & Supplies
Oki - how to print booklet?
The paper you have inserted into the printer, and your page size settings have to match. You can't load A4 paper and tell it to print A5 size. This is why it is printing so small on the A4 paper. It assumes you need to trim it down to A5 size after printing.
Jul 15, 2012 | Office Equipment & Supplies
Mx 320 fax showed me memory full, How can I delete the memory? I need to send a fax but I can't.
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will automatically store it in its memory.Ink has run out while receiving a fax.Paper has run out while receiving a fax.
  • Paper other than A4, Letter, or Legal-sized papers are loaded.
  • OFF is selected for Auto Print in User Settings.
  • You pressed the Stop button to cancel printing of a fax.
1. Make sure that the plain paper is loaded in the Rear Tray.
2. Display the Memory reference screen.
(1) Press the FAX button, and press the Menu button.
(2) Use the left.gif(-) or (+) right.gif button to select Memory reference, and press the OK button.
3. Print all the received documents in the memory.
(1) Use the left.gif(-) or (+) right.gif button to select Print all RX docs.
  • To print the list of documents in the memory, select Print memory list.
  • To print a specified document, select Print specified doc..
  • To delete a specified document, select Delete specified doc..
  • To delete all documents in the memory at the same time, select Delete all documents.
(2) Press the OK button.
(3) Use the left.gif(-) or (+) right.gif button to select Yes, and press the OK button.
The machine starts printing documents in the memory one by one.
(4) Use the left.gif(-) or (+) right.gif button to select Yes
To keep the document in the memory, select No.
(5) Press the OK button.
  • The deletion confirmation screen will appear each time after one document is printed. Repeat the same procedure until all documents are printed.
Sep 21, 2011 | Canon Office Equipment & Supplies
My canon pixma 480 has thin horizontal lines. tried cleaning and deep cleaning where is the head alignment tool?
The instructions as copied from the Pixma 480 "onscreen manual." (Only the text -- not the images -- could be pasted into the solution. Hope you can follow the text.) Steve G.
Prepare 2 sheets of A4 or Letter-sized plain paper
1. Make sure that the power is turned on, and load 2 sheets of A4 or Letter-sized plain paper in the Rear Tray.
2. Open the Paper Output Tray gently, and open the Output Tray Extension.
3. Print the print head alignment pattern.
- Press the Menu button.
- Select Maintenance, and press the OK button.
- Select Print head alignment, and press the OK button.
Note: To print the current head position adjustment values, select Head alignment print in the Maintenance menu and press the OK button. See Selecting Menus on the Top Menu Screen.)
- Select Yes, and press the OK button to print alignment sheet.
- Check the pattern is printed correctly, select Yes and press OK button.
- Confirm the displayed message and press the OK button.
The Print head alignment screen appears.
4. Adjust the print head position.
- Check the printed patterns, and use the (Left) or (Right) button to select the number of the pattern that has the least noticeable streaks for column A.
Note: If it is difficult to select the best pattern, select the pattern that has the least noticeable white streaks.
(A) Less noticeable vertical white streaks
(B) Noticeable vertical white streaks
(C) Less noticeable horizontal white streaks
(D) Noticeable horizontal white streaks
- Repeat the same procedure to input the pattern number for each column from B to L, then press the OK button.
- Select Yes to continue printing, and press the OK button.
- The second page of print head alignment sheet will be printed.
- Confirm the message for print head alignment, and press the OK button.
- Check the printed patterns and use the (Left) or (Right) button to input the number of the pattern that has the least noticeable horizontal streaks for column M.
- Repeat the same procedure to input the pattern number for each column from N to R, and press the OK button.
Jan 12, 2011 | Canon Pixma MP480 All-In-One InkJet...
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
HP 4L when printing an internet page, print size is for
Under print preferences set the paper size to A4.
Start > Printers and Faxes > (Right-click printer and select properties) > (select printing preferences) > (set paper size)
Aug 25, 2009 | HP LaserJet 4 plus Printer
Problem printing on matte photo paper
no thats why it is not working the right way you have to use the semi gloss paper thats what it requiers
Jan 03, 2009 | Brother MFC-3240C All-In-One InkJet...
How do I reduce A4 printed notes to A5 size ?
Click on the File tab which is present in top left corner of the file, Click on Page Setup, a separate window appears, there on paper menu you can see a Size which is a drop down box. Drop down the size and select A5 and press ok. Now onwards it prints in A5 size. Later you can change it any size. Thank you........
Sep 13, 2008 | HP Office Equipment & Supplies
Manual Feed Issue
will not pick up envelopes to print
Feb 09, 2008 | Lexmark C530dn Laser Printer
Card making
This machine will only print certain sizes as borderless. A5 is not one of them. You can use the following media with this feature: Matte Paper - Heavyweight: A4, Letter Premium Glossy Photo Paper:A4, Letter, 5 x 7", 10 x 15 cm/4 x 6", 8 x 10" Photo Paper:A4 Premium Semigloss Photo Paper:A4, Letter, 10 x 15 cm/4 x 6" Glossy Photo Paper:Letter, 10 x 15 cm/4 x 6" As you can see A5 is not in the list, therefor you will not be able to print A5 borderless via the normal means.
Aug 21, 2007 | Epson RX620 All-In-One InkJet Photo...
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
