Question about Canon BJC 2100 InkJet Printer
Problems with color prining
My printer had been printing color but then ran out of ink. I changed the color ink and now the printer will only print lines of color rather than the actual image. It prints blue, red, and yellow but doesn't mix colors and, again, only prints lines.
  • kelli187 Oct 31, 2008
    I tried cleaning everything. It didn't work...
    Master:
    Sergeant:
  • 449 Answers
Hi!!!!
perform maintenance and
try to clean up nozzles may be the ink
clog
or removed the cartriged and clean with alcohol
use cotton buds then placed it back properly
Posted on Oct 31, 2008
Canon 5750 Won't print the color, although it's set to do that, and cartridges all have ink in it. I deep cleaned and also ran a nozzle check ... but don't know how to interpret that. A = 0 B = -1 C =...
Hi Sue, first tell the exact printer model, because MF5750 is laser printer B&W, lbp5700 is also laser and doesnt have ink.
Wich ink printer do you have like pixma 5300? pixma 4300?
The 5750 doesnt exist in canon range of printers.
But, by your description you have print head problems or clodged inks or purge unit problems.
Aug 28, 2010 | Canon LaserBase MF5750 All-In-One Printer
Kodak esp 3250 won't print black. Changed cartridge and still won't print black. Just installed new printer.
I fixed my ESP 3250 print problems by removing the cartridges and print head. Using a Q-tip and warm water, added drops of water to each of the print head ink wells until the water / ink from the wells bled thru onto a cleanex. Did this several times. Dryed the print head fairly well. Then added a drop of water to each cartridge for each color. Reasembled and ran an alignment and to my surprise, it works! I hadn't used my printer in a while, so the ink had dryed on the felt for both the print head and cartridges.......
May 15, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How to print only with black catridge
go to print then properties then advanced and put a check on the "use black ink only" option
Mar 06, 2010 | Epson Stylus Photo R220 InkJet Printer
ESP9 color prints begin coming out purple like
Use only original ink cartriges, the non original has ink normaly is not for you printer, and you wast your money and damage the printer print-head
Jan 02, 2010 | Office Equipment & Supplies
Changing the black cartridge also require change of color
The printer is very good.I ve been using it for approx 1 year now.The printer works on a combination of both black as well as colour ink cartridges.If any of the cartridge is empty,printer will not print.Kindly call Kodak with your problems at 1800 421 6699 and they will take care of the issue for you.
Oct 04, 2009 | Kodak ESP 5 Printer
I have a epson stylus printer C65 series. I ran out of black ink so i changed the ink cartridge and it will only print colour not black now.
I have an Epson stylus 6000 series, second hand but was working just fine. I changed the ink cartridges and now the color won't print. Utilities shows all cartridges full, but only black and pale green-blue print. While it was printing color it was drinking the ink, but that's another story.
Yvonne
Aug 09, 2008 | Office Equipment & Supplies
HP 5610 Will not print Color documents, only Black and White
Chances are that your print driver is set to print in black and white while the copier side is automatically detecting that your original is in color. To have the printer print in color: Select file print, select your printer and hit preferences. Select the Paper/Quality tab and switch from Black and White to Color.
Henry
Apr 28, 2008 | HP Officejet 5610 All-In-One InkJet...
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Printing in black & white when color cartridge ran out
I had the same problem. Had no choice but to buy the colors I ran out to make the printer work. In order to avoid future problems and save on color inked I attempted to follow the steps of a previous posting, however, that did not work for me. This is what I had did. Print, select properties, advance, continue, check box - Black ink only. Remember when you decide to print in color you must reset your setting and take out the check from the - Black ink only.
Sep 08, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Canon BJC 2100 InkJet Printer Logo
254 people viewed this question
old marine
old marine
