Question about AOC 5 En 15" CRT Monitor
AOC 15" CRT
I keep getting the contrast 100% alarm in mid-screen. I can't shut it off at times and at times it just goes away. I can't seem to re-adjust it to a lower value, it just keeps moving up to 100%? Any tips or others with the same problem?
  • 3 Answers
Just change the botton switch.... with a new one...
Posted on Aug 31, 2009
  • dariel_ph Aug 31, 2009
    just change the botton switch.... with a new one...
    just change the switch botton with a new one...
I in mi aoc tv lcd l22w89 the option picture blocking, contrast and brightness to 100% and I can not change
In the menu system there is a reset (I believe it's all reset, or reset all...something like that) which should fix the issue.If not, leave the TV unplugged for 4 hours and plug it back in then turn it on.
Nov 26, 2011 | AOC L22W898 22 in. LCD TV
Acer crt monitor green light is ok but there is no display. but some time when i start computer it displays xp logo then goes away. i tried monitor with anoter pc but it still the same problem.
sounds like some of the components inside the monitor are becoming defective...the fact that you said some times you get a screen for a while then it goes away indicates a component is changing value when power is applied and shutting down the monitor...probably a capacitor in the power supply...best bet is to get a new monitor, as service rates would exceed the cost of a new or used one
May 19, 2011 | Acer Value V551 (White) 15" CRT Monitor
White horizontal line across screen
Upgrade the refresh rate to 100 Hz and downgrade resolution
Jun 23, 2009 | AOC CT720G 17" CRT Monitor
Monitor control panel keeps popping up on screen
hi..if you soldering iron or do you have a electronic technician you need help him.the defective parts need to replace is Tack switch inside the CRT/Monitor..Thanks and Good Luck...^_^
May 10, 2009 | Dell E551 15" CRT Monitor
Contrast automatically increases to 100%
yes! The same problem in my monitor. The contrast of my PC monitor increases automatically to 100%.If I try to reduce it,it increases again.
Oct 19, 2008 | IBM E54 15" CRT Monitor
Brightness
most monitors get darker with age -- for a while you can counter this by turning up the Brightness and Contrast controls, but this only gives you a little extra time (and probably speeds up the decay process anyway).
Sep 16, 2008 | LG Studioworks 563N 15" CRT Monitor
Having a form of glasshour display
yes i have repaired my AOC 5En 15" CRT monitor diode # Diode 406 or check IC401,Q404,Q405,Q406 or visit my site for symatic diagram
Jul 12, 2008 | AOC 5 En 15" CRT Monitor
Display menu virus? :(
try disconnecting your network cable and adjust the settings again, if you cant, enter safe mode by pressing f8 in the startup and select safemode then adjust the contrast there.
Or is this in the CRT monitor? inside the monitor? there are no viruses ever made for monitors. So its most likely a hardware fault in the crt. Maybe its time to buy a new one. LCD preferably easyer on your eyes.
Apr 28, 2008 | AOC 7F 17" CRT Monitor
Need help with Mitsubishi 15
Try pushing the contrast button, and then some of the other buttons once the contrast menu is up. To control those menus you use the buttons on the front of the monitor, not the keyboard and mouse.
Nov 24, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
IBM MONITOR ON SCREEN DISPLAY
This is a problem in the monitor itself. The computer has absolutely no control over the On Screen Display. Most likely the button that controls contrast is stuck. You might try blasting the button with canned air. Sounds like it might be time to buy a new or used monitor.
Jul 31, 2007 | Samsung SyncMaster 551 15" CRT Monitor
AOC 5 En 15" CRT Monitor Logo
75 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
