Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
After my ciurcut breaker was fliped on and off my samsung 46" 71f has had problems
I am expieriencing what can only be call a "shimmer" which i thought was isolated to plasmas....now after i leave tv off the whole night it will have a green shimmer all over the screen,it looks like there is a bright green glitter moving around the entire picture,even in the black bars on top and bottom of picture, and even if its on a completley all black source. in the morning it will warm up after about 30 mins. and then the picture goes from that bright shimmer to an outstanding picture as it allways is....i dont know what to do.....samsung is just guessing and is having a tech come out next week to replace my panel and what they call a timing board.just so you know the problem started exactly 4 days after the breaker was fliped from on to off then fliped back on again...i do use a very high end surge protector,is this issue the reason for my problem or is it just a faulty part or 2.PLEASE PLEASE HELP!!!!!! MODEL # ln-t4671f SAMSUNG LCD 120 HZ. 1080P
  • 95 Answers
Ive had a element lcd tv that i bought, out of nowhere the power cut off, so i went to flip the breakers, and since i had the Tv still plugged up, after i flipped the breaker to get the power back on. Power came back on, went to go turn on the tv, the light would be on but nothing on the screen no picture. Sometimes it would come on a little bit after awhile but that is it. So yes i do recommend you have there tech come out and fix it. Before you ever flip a breaker off and on, unplug all computers, tv's, anything in that nature before you do it.
Posted on Aug 12, 2009
Kenmore# 665.13552k700 has had a constant blinking geen light on normal wash. I have unsuccessfully tried to shut off the power, alternately press normal wah and heated dry several times, held the heated...
Try unplugging or turning off at ciurcut breaker and make sure someone stayas at the dishwasher to be sure the breaker is corredt . the light should go out when breker is turned off then plug back in that will reset the CPU
Jun 28, 2014 | Kenmore Dishwashers
I have a 93 polaris 350l 4x4 revved engine and lights blew also th cooling fan stopped working around the same time
I have a 2001 polaris scrambler 500 4x4 and it wouldn't charge the battery and my lights wouldn't work and the fan wouldn't come on so it overheated and it was the voltage regulator that was broke and that makes the fan and lights work it might not be a stator hopes this helps
Jan 24, 2013 | Polaris ATV
Samsung monitor shimmer
Hello try to upgade the graphic driver with this tool:
http://www.intel.com/p/en_US/support/detect?iid=dc_iduu
I sometimes help. But the screen/ or cable could have a fault.
Good luck
Nov 01, 2012 | Samsung SyncMaster 245BW LCD Monitor
Jandy hand held just says wait wont connect. I tried reset and fliped circuit breaker
This is a common problem with the communication between the RS Aqualink remotes and power centers. These can be fixed quickly and reliably at www.fixyourboard.com
May 13, 2010 | Jandy Aqualink Rs4 One Touch Control...
Electric Heater won't turn on, thermostat clicks but heater won't blow. Switching fan to On doesn't do anything either. I've fliped circut breakers, pressed reset button on thermostat and replaced...
If you flip the fan to on and it doesn't run then you may have a problem with the fan motor or possibly a capacitor if it has one. I'm not familiar with the Brant heaters. I usually work on Monitor and Toyostove heaters.
Feb 11, 2010 | Heating & Cooling
6500 watt diesil generator /as soon as i put any
if by fliping the breaker it shuts off..that means there is a short circuiting in the breaker..try connecting your house,shop..etc..directly ...
that is if the shut off reason is overloading...if not please explaing with details
Aug 23, 2009 | Electrical Supplies
My clock is running slow no matter how many times its reset. And it sort of shimmers like a florescent bulb thats getting bad. Maytag T2 MES5770AAW
I had the same problem. I turned the breaker off for the stove for 24 hours. (unplugging will do the same thing, I just couldn't get to the back of the stove.)
I turned the breaker back on and it works fine.
Aug 04, 2009 | Maytag 30" Built-In Single Electric Wall...
Screen fliped upside down
Hi there.
Hold down Ctrl and Alt and use the cursor keys (arrow keys) to flip the screen the right way up, usually the cursor up key will do it.
Good luck and thanks for choosing FixYa!!
Jun 05, 2009 | Samsung NC10-14GW Notebook
Samsung LCD TV shimmer problem
Are you sure this is not an LCD screen door effect, It is a normal thing for this to happen to an LCD TV set. They are not made to be watch too close or you will magnafy this normal effect with the screen. If you have a problem with a new set, dont waist any time and get it service right away as it will cost you a small fortune in the future to have it serviced. Good Luck
Mar 24, 2007 | Samsung LN-R409D 40 in. LCD Television
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
88 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
