Question about Elite Pride Go Go Traveller 3 Wheel
Alarm shutting down scooter
The go go elite has a alarm that sounds and shuts scooter off.I have checked level of charge and it was not full ,but also not at a low level.The scooters alarm goes off at traps the person in their scooter.
  • ndswede1930 Nov 27, 2008
    father in-laws scooter does the same thing. Its not the horn its more of a warning alarm. You have to shut off the key for a couple of seconds then restart it. This is with a full charge. It starts to get very annoying
  • 118 Answers
I have never heard of this, and I just check the manuals to be sure. The only "Alarm" is the horn button. If that is going off while driving, I suspect that a wiring harness is frayed and shorting out.
Posted on Nov 27, 2008
Trouble with new batteries losing charge. I also purchased a new charger. It will run for awhile a couple of weeks then it will just keep losing power and just stop.
Number 1, always charge after every use. You can check if the charger is charging quickly, by turning on the scooter and watching the gauge when you plug the charger in. The gauge should climb up if it does not move then charger is not working. Make sure the charger is plugged into an outlet that is not shut off with a light switch!
Check out my Trouble-Shooting guide at Scooter Doctor App
Jul 31, 2015 | Mega Motion Elite 8
Need a repair shop to fix my gogo elite
This is due to the controller shutting down. Make the brake leverin the on position
Oct 08, 2014 | Pride Mobility Products Go-Go Elite...
Gogo ultra beeps and shuts down. let it sit for a while and it will restart
a couple of things could cause this. A weak battery is one, the other would be excessive load on the motor, operator past the recommended weight limit, thick carpet or grass, gravel ect. can all cause the unit to work and cause a thermal shut down.
So first have the batteries load tested.
Hope this helps.
Feb 05, 2014 | Pride Mobility Products Go-Go Elite...
Electrical shuts off or slows down when riding
You may need to replace the battery even though it is charging. It sounds like a bad battery or the motor may be overloaded.
May 06, 2012 | Pride Mobility Products Legend 3-Wheel...
Battery won't hold a charge - go-go elite travellor scooter battery charged overnight but won't hold charge.
We have had problems with scooter batteries from time to time and the repair man said to take apart the battery case and disconnect the batteries and use a car charger. I put the two battery in parallel and used a amp battery charger. This worked fine.
Don't run your scooter batteries all the way down when using the Go Go as the scooter charger won't always bring them up to full charge and you may have repeat this. Also running the batteries all the way down shortens there life.
Mar 19, 2010 | Pride Mobility Products Go-Go Elite...
Rascal scooter mo 655 motor stops going up hills
the batteries could be the problem, is it possible to try some other batteries, silly question , how steep is this hill ? remember scooters cannot climb steep hills as the motor will shut down due to the increased load.
1 Year old batteries ok ? but if they get used on a non daily basis and are not fully charged after use, I would question the batteries but again the motor could be overloading,
How much do you weight ? sorry for the personal question but it all loads the motor and that increases the current and that will cause the motor controller to shut it down.
Jun 14, 2009 | Pride New Mobility Legend 4 Wheel Scooter
My mom's Pride Go Go is charged but beeps once and shuts off
Sound to me like the batteries are only getting a surface charge. Have the batteries load tested.
Jun 07, 2009 | Pride Mobility Products Go-Go Elite...
Batteries are charged, scooter won't move, no power to display
It is impossible to overcharge with the Pride charger. When the battery is full, it will stop charging and check about oncew a miute to maintain the charge.
Now, when you plug in the key (looks like an audio headset jack) does the battery meter indicate a full charge? Also, the scooter will not move if its in free wheel mode, and it will not move if the charger is plugged in. Beyond these first steps, you will need a voltage meter to troubleshoot.
Jan 18, 2009 | Pride Mobility Products Go-Go Elite...
False battery power alarm shut down
Ive had a look at the manufacturer web site but ther doesn't seem to be any driver for your model. You should be able to turn the battery warning alarm off in the management settings
Feb 03, 2007 | Balance CN6555 Notebook
Elite Pride Go Go Traveller 3 Wheel Logo
312 people viewed this question
Top Elite Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
Jeff Tilburn
Jeff Tilburn
Are you an Elite Health and Beauty Expert? Answer questions, earn points and help others
