Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Kodak Quality bad very bad
I thought Kodak meant something I guess not because they sold me with the ink saving feature but it has cost me more in headaches i say no to this beast. It prints pictures that look washed out like cartoon people terrible. Jim
  • Anonymous Nov 18, 2008
    its junk, im pissed
  • billyboy1212 Jan 07, 2009
    wont print color even with new ink cartridges very faint photos
    Problem Solver:
  • 19 Answers
You have a clogged printhead! Call Kodak tech support!
Posted on Jan 14, 2009
How to reset hp C8767WN?
We suggest you go to Inkjet411.com - this site is primarily a self-service sitelet which provides over 80 technical videos and do-it-yourself printer remedies and corrections, including how to reset select HP ink cartridges: http://inkjet411.com/
If you need to purchase a new ink cartridge(s) and are trying to cut costs, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20.
For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
Jun 17, 2014 | Office Equipment & Supplies
Tip
Printer Ink refill ....
Well, in general I recommend not using refills. They are probably OK for printers with ink nozzles that are NOT built into the cartridge (like Canon printers), but I would still be careful. The ink may not be the same quality as what you would get from the manufacturer.
If you are using an HP printer, the ink nozzle is built into the printer cartridge and is not meant to be run for refill after refill. When you replace your ink cartridge, you also replace your old nozzle with a brand new one. Helps keep the print quality good (especially important if you're trying to print out photographs).
Another point to consider is that when you bought your printer, you were probably looking at print quality. Why take a chance on compromising that print quality to save a few bucks?
on Dec 01, 2009 | Office Equipment & Supplies
Ok, ok, I know it's a no-no to buy after-market ink, but Lexmark
Not all aftermarket inks are bad. To clean your nozzles, I would "bite the bullet" and get new OEM cartridges, run the cleaning utility an nmber of times (at least 3) and the alignment procedure. This should put your quality back to factory standards. Be careful in using aftermarket or refilled cartridges. Check suppliers like LDProducts for cartridges that meet OEM specifications.
Apr 05, 2010 | Lexmark X502N All-In-One Laser Printer
Same on kodak...
Just try cleaning the printhead using the AIO home center program and i'm sure you would be able to restore good print quality again
Sep 27, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
The ink cartridges need to be replaced very often epson 810
You can try to change your print quality to a lower setting. This saves a lot on toner. If you are not printing for anything super important you can set some printers to "fast draft" or "draft" quality and that saves a ton. I personally dont usually need to print anything of high quality so I went to my local "Everything" store(not sure if I should use company names) and bought an HP, the cheapest color printer they had which was $30.00 The black and color cartridges together cost about the same as the printer. But I use the lowest setting which is the "fast draft" setting and set it to print in black ink only, and only change that when I NEED something in color and it uses very little and prints very fast.
Aug 10, 2009 | Epson Stylus Photo 810 InkJet Printer
Printing problem
lynchfam3 it is problem with the print head so call you can do is print head cleaning and make sure you are using genuine kodak ink cartridge and if still the same issue then try and use the printer in standalone mode i.e try and copy something and check if the image quality is still the same or not if yes then it is print head issue and you need to contact kodak tech support they will replace it for you without any charge.......
Jul 10, 2009 | Kodak ESP 5 Printer
I have three Kodak printers; 2 - 5300's and 1 - 5100. All three are on the third set of print heads AND THEY ARE STARTING TO FAIL. Is it the print head or ink formulation? I suggest a class action law...
if the print head has been replaced thrice then it could be a ink cartridge problem coz there are number of look alike and refilled ink sold by retailers.......print head comes in contact with paper so make sure if the thickness of the paper is more then it might damage the print head..........always use kodak inkjet paper not any other Hp or anyother daily use paper..........if you are good with both the ink cartridge and paper then contact kodak tech support..........
Apr 26, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
It will not print black print information on paper, bad quality
1.800.421.6699 call that number and select option 01 for prints missing black or color ink
Jan 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
My printer does not print black. It prints color but not black.
This is only a guess but from what I have read I will say you have a bad printhead. You can email or phone Kodak for help.1 800 421 6699. If it is a printhead they will ship you one free of charge and throw in free ink also....They did for me got mine in less than 12 hours. Hope it helps you
Dec 12, 2008 | Kodak 5500 ALL-IN-ONE PRINTER
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
106 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
