Question about Fedders A6X08F2BCOM Thru-Wall/Window Air Conditioner
Air Conditioner won't work after resetting and testing
My airconditioner suddenly went off, and after which I followed the directions to unplug reset then replug in and push the test button then reset button again and all that is displayed in the digital window atop is "EE"... 2 E's. Have no idea what this means. So does the "EE" represent something? Like the plug needs to be replaced or any other ideas would be welcomed. Thxs, Drilla
  • madmissileer Jun 13, 2008
    I have a Q chassis Fedders with the same issue. Found c/b fuse blown and replaced it. Now display says EE.
  • Fedders Master
  • 2,162 Answers
What kind of a.c. and what is the model number
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Jun 18, 2017
  • 9 Answers
SOURCE: fedders room air conditioner
Look for a red reset button on the plug.
Posted on Aug 16, 2007
chillmaster
  • 104 Answers
SOURCE: Fedders window model A6Y12F2B "New Unit",,only
Take it back to the store. Manufacture defect if it died after only 10 days. Attempting repair or disassembly will probably void warranty.
Posted on Jun 23, 2008
  • 5 Answers
SOURCE: AC stuck on cold, compressor still hums after power off. Tried up and back down temp settings, tried ac reset switch, unplugged 15 min. It is still stuck on after I plug in again.
sounds like your switch is bad still allows power to compressor when it shuts down the blower,,.....
Posted on May 31, 2009
lambocar
  • 31 Answers
SOURCE: air condition wont turn on
Do you have enough power to unit? Check plug for any loose wires on unit, with unit unplugged of course.
Posted on Jul 07, 2010
  • 12 Answers
SOURCE: reset button
Unplug it for a few minutes and see if this resets the unit and cures the problem. If the unit was running when you did this, you cut power to the compressor and it will lock out for awhile until pressures equalise. This is normal and is meant to protect the compressor from being short cycled.
Posted on Jul 21, 2010
Why no response to test power and reset buttons?
sounds like reset on line cord did not reset.
Aug 15, 2015 | Continental Heating & Cooling
Frigidaire airconditioner compressor keeps running after turning the unit off
Thanks for the post, friend!
I understand that the compressor continues to run after your Frigidaire air conditioner has turned off. From that information it sounds like there could be a possible issue within your control panel or relay. I would recommend a reset on the appliance, to perform a reset unplug the power cord you will see a test button, push that button and you will hear a click. You would then press the reset button you will hear a click again signifying that the appliance has been reset. Then plug your air conditioner back in. If you continue to have an issue with your compressor I would seek assistance from a professional. Hope this is helpful. -Matt
Aug 12, 2014 | Frigidaire 18,500 BTU Window-Mounted...
Water got into the plug. Unscrewed, drained as much as I could and set down on paper towels for a few days. Plugged back in & worked. Moved the cord while plugged in & the ac blew out and will...
Hello, most likly you will have to replace the whole cord assembly, here is a link to parts for you AC http://www.appliancefactoryparts.com/airconditioners/goldstar/m1003r.html
Jun 08, 2011 | Goldstar M1003R Air Conditioner
MY AC SHUTS OFF AND CODE E1 COMES UP
This is a reminder to clean the air filter. It happens every 720 hours of operation. Here are the steps to get it back up and running:1. Power down the air conditioner using the "power" button on the front panel.2. Unplug the air conditioner from the wall socket.3. Hold the front panel "power" button down and plug the airconditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button.4. Unplug the air conditioner.5. Plug the air conditioner back in.6. Congratulations! You should now be able to operate the airconditioner normally for another 720 hours, but only if you followed the instructions above EXACTLY.
Jul 22, 2010 | Sharp AF-S120FX Air Conditioner
We have a portable air conditioner. It keeps
Follow the steps below....
panel.
button.
Jun 26, 2010 | Heating & Cooling
My error code E1 won't clear after draining the water resevoir.
I offer the
following procedure to clear the nefarious E1 indication, and obtain
another 720 hours of cooling bliss:
panel.
button.
If you doubt the veracity of this information, or it does not work as
expected, you can get it directly from the source at:
1-800-237-4277
which is the Sharp customer service line. But, you'll need to call
between 7 AM and 7 PM US Central time, and have your model number and
serial number ready.
May 16, 2010 | Heating & Cooling
How do I reset the e1 on the A/C
I have a sharp and I don't know what model you have but you may check the manufacturers web site for a instruction book
but on my unit you have to do the following
panel.
button.
after following this procedure to clear the nefarious E1 indication, you should obtain
Jul 20, 2009 | Sharp AFR120FX Air Conditioner
Can i reset the remote for my air conditioner? it
they are not resetable. did it get wet? Good luck Tom
Jun 28, 2009 | Heating & Cooling
Will not work
is the control battery operated?? if so the batterys may need replaced
Apr 20, 2008 | Kenmore 72056 Air Conditioner
Mitisubishi Ducted Reverse Cycle AirConditioner
1.check blower fan motor.if blower fan motor donot work then compressure trip after 5 to 10 minitue.
2.make switch of airconditioner n reset again.
Feb 11, 2008 | Mitsubishi MS12TN Air Conditioner
Fedders A6X08F2BCOM Thru-Wall/Window Air Conditioner Logo
151 people viewed this question
Top Fedders Heating & Cooling Experts
Donni Steen
Sheldon Dedek
Mike
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
