Make sure it is plugged into a GFCI outlet; try adding a surge-protector. The fuse will blow if the power exceeds the rating on the fuse. (If a surge-protector on the GFCI outlet does not prevent this, there will be a problem with the wiring inside the machine.)
Remove the 2 screws which hold the lower front washer panel , lift out from the bottom and remove the panel.You can now run the machine and use a flashlight to see where the leak maybe. Usually the top tub seal under the plastic tub cover will leak. The other possibility is the main tub bearing and seal on the main tub where the transmission goes up through tub. Hope this helps.
You may have blown the internal fuse located in the lid switch. Could be you over loaded the washer and blew the fuse.
Unplug the washer and remove the four screws holding the control panel front in place. Two screws on top and two screws under control panel.
Remove the control panel and tilt forward.
Locate the lid switch assemble and remove glass fuse and inspect.
Door switch assembly should be replaced. When you order the proper fuse it should come with the door switch assembly.
Replace assembly. Reinstall the front control panel and four screws.
Plug machine in and test.
If your washer doesn't seem to work at all, check these:
No power Lid switch No power
Checkto see whether power is getting to the washing machine. Is it pluggedin? Has a fuse blown or is a circuit breaker tripped?
Lid switch
Ifthe lid switch is defective, your washer can't spin and may notfunction at all. The switch is inside the washing machine main housingnear the door frame. Often you have to raise or open the top or frontof the washer to get to the switch. If it's defective, you need toreplace it.
Some machines have a special lid-switch fuse nearthe lid switch, inside the control panel. If this fuse blows, the unitwon't fill with water until you replace the fuse.
Mine the same concern, I took it apart and found the thermo fuse in the motor had a bad terminal. Maytag parts man said you must get a new motor even though the fuse has a part # on it and is easy to change. I made temporary repairs until I find a fuse from a used parts machine. Scott
Yes, it is inside the front washer lower front panel. Turn off poawer to unit and change w/ 1Amp 250V (regular of slow-blow). Then try only opening washer lid door with full dial pushed in (that would be the 'off' position. Only open/close lid w/ dial in off position. If washer works normally, may have a temp solution. Mine started this way, but ultimately the double relayed door lid switch was going bad and I had to replace it. Instructions/pictures below. Good Luck
the power surge probably shorted out something in the main wire harness or fried your motor. remove the screws from the control panel and look for any wires that are discolored, charred or disconnected. in the event you do't find it there trace the wiring thru the cabinet looking for the same thing. if you don't find that, replace the motor
