Question about Homelite 'Yard Broom' Leaf Blower
Ard Broom leaf blower, pull rope problem
My pull rope will not pull out each time. It will pull out a couple inches or 6 inches and sometimes all the way. How do I get in to the area where the draw rope is?
Bill
  • Anonymous Dec 06, 2008
    I have the same problem
    Brigadier General:
  • 6,966 Answers
Like most mechanical problems, your concern would require the disassembly for visual inspection. Offhand, the problem could be a loose nut or lock. If you have not performed a similar repair before, then perhaps it is best for you to make use of a repair manual or at least an exploded diagram to give you an idea how the parts are interconnected. If you would be uncomfortable performing a DIY (do-it-yourself), then perhaps your best bet would be to seek the services of a qualified professional.
A simplified repair sheet may be of additional help.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 31, 2008
    Scholar:
  • 62 Answers
You are going to have to take the plastic covering off. But be carefull. Fixing a rope pull can be a tricky job if you have never done it before, as this is a spring loaded pull rope. Once the spring is sprung, you will need to re-spring it, which can be tough. At best, maybe all it needs is a few drops of oil. Past this, you might want to think about taking it to a mechanic.
Hope this helps,
Chad
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
may there is someting stuck
on the rope try to check the rope
might have damaged or replaced it!!!!!!!
  • 88 Answers
Ther should be 4 star heads on the panel that houses the draw rope.assuming you dont have anyother problems like a broken clutch on it that would foul things up a bit.
Need to relace starter rope
Remove the cover from the side of the blower that contains the pull start. This usually involves removing the self-tapping screws that join the two halves of the blower housing together.
  • 2
  • Remove the broken rope from the starter pulley. Usually the rope is attached to the pulley with a simple overhand knot; just grab the knot and pull the rope back through the hole in the pulley. Sometimes the rope is attached to the pulley with a staple or some other fastener, which you'll have to remove first.
  • 3 Remove the handle from the replacement rope, if it's already attached.
  • 4 Thread the end of the rope opposite the handle through the hole in the starter pulley, working from the inside of the pulley (the side facing in toward the engine).
  • 5 Fasten the rope to the pulley. If it attaches with a knot, simply tie an overhand knot, pull it tight and trim off any excess rope sticking out of the knot. If it attaches with a fastener, replace the fastener.
  • 6 Wrap the rope counterclockwise around the pulley until the pulley is full; this usually involves one or two wraps.
  • 7 Thread the free end of the rope through the hole in the blower housing.
  • 8 Replace the blower housing and screw it in place.
  • 9 Trim off excess rope, leaving about 6 inches of rope protruding from the blower housing.
  • 10 Attach the handle to the starter rope. This typically involves threading the rope through one or two holes in the handle and securing with an overhand knot.
  • Read more: How Do I Replace a Pull String on a Hand Held Blower? ' eHow.com http://www.ehow.com/how_6920861_do-string-hand-held-blower_.html#ixzz1DKqEmA1w
    Feb 07, 2011 | Homelite Garden
    My leaf blower string will pull out about six inches then it stops.
    Hi, the problem can be one of two things. One, the rope may simply be jammed at that point and you just need to pull off the recoil housing and free it up with a screw driver. Two, your engine is seized. If this is the case you're better off buying another because the time and effort to fix these things successfully will outweigh the cost of a new one. Good luck.
    Dec 21, 2010 | Homelite 'Yard Broom' Leaf Blower
    Where to get a new pull string for blower?
    Any lawn & garden outdoor power equipment dealer
    Lowes, Home Depot, Menards: get a recoil rope and handle for a Briggs push mower
    Nov 13, 2009 | Homelite 'Yard Broom' Leaf Blower
    Reinstall the starter rope on a Homelite Model UT 08026 J.
    Go to smalleng.com free video for just what you are experiencing.
    Nov 07, 2009 | Homelite 'Yard Broom' Leaf Blower
    We are going to reassemble a strater chord on a Homelite gas leaf blower. What is the proper way to do this properly? We want to make sure the return mechanism works.
    remember to prewind the pulley in the direstion the string pulls it out, then slip the rope inthru the hole in the pulley, tie a not and then release the pulley and let it pull the rope in.if tou do it backwards you will break the recoil spring
    Nov 05, 2009 | Homelite 'Yard Broom' Leaf Blower
    It will not re-coil on a homelite II yard broom (gas)
    sounds like the tension spring has broken. remove the cover on the pull rope and look inside the rope coil, the spring is located under this.
    Nov 04, 2009 | Homelite 'Yard Broom' Leaf Blower
    Starter rope hard to pull
    Usually these motors get tough to pull through when there's moisture (water) somewhere in the fuel system.
    Fuel compresses, but water won't and when you pull a bit of water in the cylinder it will buck back on you.
    Best bet is to drain the carb, fuel lines, and tank and put all fresh fuel/oil in. you can also pull the spark plug and pull the motor through with the plug out to dry the cylinder...
    Oct 31, 2009 | Homelite 'Yard Broom' Leaf Blower
    Cannot open housing on homelite leaf blower, screws are out,
    There should be a latch on the end opposite the hinge on the housing door. Make sure it is free it should open fairly easy but latch is sometimes hard to release.
    Mar 28, 2009 | Homelite 'Yard Broom' Leaf Blower
    When I pull the recoil rope it seems to have lost compression and won't start. Pulls easier but with no compression behind each pull. Any ideas?
    Have you checked the compression? A lot of  two stroke cycle engines are running less lube due to emission which results in far more wear. Sometimes people don't realize that oil has to bve added to the gasoline.thus wearing the engine to the no compression state.
    Nov 11, 2008 | Homelite 'Yard Broom' Leaf Blower
    Adding a pull rope.
    well to msactual your pull cord assembly is not put together, did you wind the recoil spring tight enough? sounds like your "gasket' is a spacer like smith said.
    Sep 13, 2008 | Homelite 'Yard Broom' Leaf Blower
    Homelite 'Yard Broom' Leaf Blower Logo
    1,394 people viewed this question
    Top Homelite Garden Experts
    Jim Parker
    Jim Parker
    roeb
    Mike Squire
    Are you a Homelite Garden Expert? Answer questions, earn points and help others
