Question about Maytag SkyBox MBV1976A Beverage Dispenser
Installing overload relay kit 4387535
Im very confused about this kit install...any chance you chould take a pic. My pins seem to be in a different location.
  • 1 more comment
  • msj2222 Nov 03, 2008
    THKS... I figured it out. Worked great!!!!
  • gbeaver8574 Nov 15, 2008
    WONT GET COLOD
  • titan2110 Dec 24, 2008
    yeah i need that picture to thanks
Your solution did not help. when going to appliancezone it does not give any directions to help figure out how to hook up the wires
Posted on Jul 24, 2012
  • 90 Answers
Go to appliancezone.com
part # 4387835
it goes on the same way it comes off
if you hafe the MBV1976AA -- they use the same part
item is marked 307071
but is listed by maytag # 4387835
Posted on Dec 30, 2008
How to install a COMP ELECTRICAL KIT for GE model GTR12HBXRWW fridge
With unit unplugged, the relay is removed by pulling it straight off the compressor electrical pins. The overload is usually held on the side of the compressor with a wire bale.
Jan 29, 2015 | GE Refrigerators
Install whirlpool starter/relay kit
you should of ordered part number 8201786 and this is the whole start device that slides onto the compressor,this replaces the overload and relay and it's around 60 dollars. http://www.searspartsdirect.com/partsdirect/part-number/8201786/0046/106?pathTaken=directMatch&filterPart=&pop=flush&prst=0&shdPart=8201786 unplug it,pop the clip off and remove the cover,slide off the device,read instructions, wire it,slide the device onto the three pins on the compressor,put the cover and clip back on and you're done.hope this helps and good luck with your machine
Nov 16, 2011 | Refrigerators
Fridge stopped working both freezer and fridge, Here clicking at compressor, compressor not starting, cooling fan and everything else OK, could it be the compressor or is there a chance the thermal switch...
This is a bad compressor, or overload-relay kit. Disconnect the power, remove the overload-relay from the compressor, and test the three compressor terminals for continuity . You should have continuity between each terminal, and you should not have continuity between any terminal and ground. If this tests ok, then replace the overload-relay kit. This is a common repair for me, and it is very rare for us to find a bad compressor, so you should be ok. If it is a bad compressor, and it is less than five years old, you have a five year sealed system warrantee, that will cover the repair cost. If it is over five years old, it is not worth repair. When you are done with the repair, make sure you install a 2000 joule or higher, surge protector to protect your refrigerator from this type of repair in the future. Good Luck, Appliance Specialists
Mar 14, 2011 | KitchenAid Superba KSRG25FK Side by Side...
Maytag admiral side by side fan running on compressor but compressor not coming on 26 cu in model lsd26u15hew
Welcome to FixYa.
I suspect by your description the fridge either has a faulty overload protector or the compressor itself is seized. Hence when the overload reset's the fan starts ( as it should when the compressor runs ) however the overload then trips and the fan stops while the compressor never starts, thus not cooling.
If you feel like you can trouble shoot further I`ll try to assist you or you may decide to call a professional appliance technician.
I don`t know the age of your fridge, but I should mention...
** Most of the Whirlpool fridges have 5 to 10 years sealed system warranty which would include the compressor but not the electrical starting devices i.e., the overload & relay. Check your owners manual, it is the ultimate authority on warranty no matter what anyone else tells you according to Whirlpool/Maytag/Amana.**
If you have a multi- meter you can check the compressor to see if the windings are ok.
**First, Unplug the fridge**
Remove the panel at the back down at the bottom. This should gain you access to the compressor.
On the side of the compressor will be the start relay/overload assembly such as this image...it may be enclosed in a black plastic cover as well.
Pull off the relay & overload and you'll see 3 pins in the form of a triangle...
With a meter measure between any 2 pins at one time, going between each pin with one remaining on a "common" pin.
You'll want 3 measurement's, similar to this example- 6ohms, 3ohms, and 9ohms.
On some meters you may simply get a reading of "0" ohms, as long as the needle moves off of "infinity" which would indicate an "open" winding=not good !
If following that, the readings are good, purchase a hard start kit. Part # HS410 also known as a 3in1 starter kit.
i.e.
The above package contains info and hardware on how to connect it.
NOTE : the HS410 ( 3 in 1 ) should be considered just a temporary "fix" as opposed to an actual "repair" in should not be relide on for long term reliability or safety, but rather the factory replacemnet part 8201786... i.e. macmarkus_95.jpg The above start device kit contains instructions on "how to" install kit. Hope that help`s move you forward if nothing else. If so please take a second and rate the reply and a testimony to your inquiry you received here at FixYa.
Thank you and good luck.
Regards,
Macmarkus :)
Jan 16, 2011 | Admiral 26 cu. ft. Side-By-Side...
My Fridge is getting clicking sound very offen and lights are on but not getting cold inside.
Welcome to FixYa.
I suspect by your description the fridge either has a faulty overload protector or the compressor itself is seized. Hence when the overload reset's it try's to start, however the overload then trips and the stops while the compressor never starts, thus you hear it "clicking" and not cooling.
If you feel like you can trouble shoot further I`ve provided the following info to assist you or you may decide to call a professional appliance technician as I would suggest.
I don`t know the make or age of your fridge, but I should mention...
** Most of the manufacturers of fridges have 5 to 10 years sealed system warranty which would include the compressor but not the electrical starting devices i.e., the overload & relay. Check your owners manual, it is the ultimate authority on warranty no matter what anyone else tells you according to.**
i.e.
NOTE : the HS410 ( 3 in 1 ) should be considered just a temporary "fix" as opposed to an actual "repair" in should not be relide on for long term reliability or safety, but rather the factory replacemnet part 8201786... i.e. macmarkus_95.jpg The above start device kit contains instructions on "how to" install kit and is for Whirlpool made fridges, it is only an example...double check with your model number. Hope that help`s move you forward if nothing else. If so please take a second and rate the reply and a testimony to your inquiry you received here at FixYa.
Regards,
Macmarkus :)
Jan 08, 2011 | Refrigerators
I can hear the compressor kick on the fan works but it doesent cool like it did. the freezer side is cool but dosent freez the fridge side isnt cool at all.
Welcome to FixYa.
** Most of the Frigidaire fridges have 5 to 10 years sealed system warranty which would include the compressor but not the electrical starting devices i.e., the overload & relay. Check your owners manual, it is the ultimate authority on warranty no matter what anyone else tells you according to Frigidaire/Electrolux/White Westinghouse.**
i.e.
The above package contains info and hardware on how to connect it. HOTE : the HS410 ( 3 in 1 ) should be considered just a temporary "fix" as opposed to an actual "repair" in should not be relide on for long term reliability or safety, but rather the factory replacemnet part 8201786... i.e.
Regards,
Macmarkus :)
Dec 20, 2010 | Frigidaire FRS26R4A Side by Side...
Bad overload relay
The compressor is usually fitted with a thermal overlload switch. It is usually secured to the compressor with some sort of spring mount so it maintains physical contact
The parts guy was probably talking about a hard start kit. They typically are a universal fit, and come with instructions. Be sure to check the electrical supply to the outlet for the fridge. Excessive voltage drop when it tries to start will cause such problems, and will eventually cause damage to the compressor.
Dec 16, 2009 | Maytag MSD2756G Side by Side Refrigerator
Skybox parts # 4387535 installation issues
You don't need to keep the round metal piece or the black wire that you take. The replacement part (flat one) is installed in its place. Put it in first, attach the green wire to it, and then put the two prong piece and install the wires (blue, white and brown) as you took them off the original part.
Apr 17, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Whirlpool start device
k here we go, thinkkn we can get this to work for you.
the difference is going to be the white overloads in the bag9s). depending on size of compressor they will change, as far a s the relay thinkin ther is onl one in that bag'box/ (brown with 3 possible connections..
if this is the cas e ill asume that the old relay/overload was a onepiece white plastic with smaller connectors.. .you will need to cut off and resplice a new spade connector on the wires to fiut the new piece..
the extras are just that extras, its easier for them to stock and store one part number for a multitude of repairs( youll need only one)
Mar 09, 2009 | Kenmore 50522 / 50524 Side by Side...
Installing new over load relay
The line voltage goes to the overload and the neutral(and capacitor lines if it has one) goes to the relay.
Dec 05, 2007 | Whirlpool GS6NBEXR Side by Side...
Maytag SkyBox MBV1976A Beverage Dispenser Logo
1,240 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
