Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Beeping noise - letters appear fc
This only happens when the stove or oven are in operation. After some time, the front panel (usually shows them temp of oven, time, etc.) will flash "fc" and will continue to beep. Pressing "cancel off" does not help.
  • 1 more comment
  • TobyJohn Feb 14, 2008
    I have the same problem. I have no fear of pulling out the stove an diving into it. I'm ususally pretty good with this sort of thing. How do I get to the J2 wiring harness? If the problem is the power relay board, how do I replace that? Where can I get one and about how much should I expect to spend? I'll be glad to share my solution with everyone.
  • wolala1 Jan 12, 2009
    HELP
    got F9 and beeping and it feels like the Oven's heating up.....
  • arcticscrap Feb 10, 2009
    i have a jenn air sve47600 range that beeps and shows error code fc, what is it, is there a reset, what do i do to fix problem? i shut the breaker off hoping to reset with no luck, so now the power is off to the unit.
    President:
  • 878 Answers
Christina, FC means there is a communication error between your main power board and keyboard. There is a J2 harness that runs between them. You might try to reseat this harness. If that doesn't work the main board will have to be replaced. Catriver..post back.
Posted on Sep 14, 2006
How to stop beeping noise on my stove? Can I use the top of my stove?
Try turning breaker off for 2 minutes then back on. That may clear the code. Top elements should work independently of oven control
Sep 20, 2018 | Frigidaire Kitchen Ranges
Was low temp roasting of ribs in Jenn Air JMW9530AAB convection oven. Heat webt ofand stove started to beep and displayed "-F7-". Cancel failed to do anything. Shut power off and when turned...
The electronic control may not be set correctly. If the control is not programmed correctly the oven will not start and you will usually hear a series of beeps instead of the microwave starting. See your Use & Care Guide
Aug 09, 2008 | Jenn-Air Kitchen Ranges
Ge true temp oven
I think the problem stems from working on the board with the power on. MicroProcessors don't like that. If by "popped" you mean made a frying noise, you are going to have to replace the board.
Nov 27, 2013 | Ovens
Beeping and FC code
check to see if you have a fuse blown to your stove and replace it
Oct 03, 2012 | Jenn-Air Ovens
I had the oven on and I heard a loud popping noise, now the stove doesn't work (eg. the letter Fy1 comes up , the stove makes beeping noises, the stove door locks and unlocks etc.) The model # is...
rwere
Hello, and sorry to read about your problem.
Sounds like you have a general main board failure,
I suggest you call a service company
I tried to help you. Please help me and vote/rate my response thanks.
Dec 24, 2010 | Frigidaire Ovens
Beeping with 'f2' & 'f3' message when cleaning but did not finish cleaning. Oven now cooled but still locked.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@#
May 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Jenn air range model SCE30600B error code FC blinks with beeping noise. After resetting the temp down to 350 to keep from burning a pizza error code FC started blinking along with continual beeping. I have...
replace the entire range: Jennair does not know how to design, make, or program electronics. It makes steel boxes that provide heat but electronics - that's not within their ability. Buy a Kenmore or a GE and your beeping problem will go away.
Feb 03, 2009 | Jenn-Air SCE30600 Slide-In Electric...
Cannot reset clock on my electric stove after a power failure!
Unplug the stove for 10 minutes, then plug it back in.
This should resolve your problem...
Nov 20, 2008 | General Electric Stove/Oven/Range Chrome...
Since Jenn-Airs codes are F1-F9, the cicuit board may be on the way out since the code resets after you turn it off for a while.
Sep 14, 2006 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
466 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
