Question about Broan-NuTone Allure III QS330SS Kitchen Hood
NuTune Allure WS1 Series Range Hood
The light bulbs seem to burning the cabinets on top of the range, i used to bulbs recommended in owners manual which are PAR20 50W MAX HALOGEN BULB (2) is this normal, cabinet above range seemed to scotched . thank you
3 Suggested Answers
  • 13 Answers
SOURCE: range hood installation
you can reseal the hole with aluminium tape
you can use screws with metal flat washer that has a rubber backing
Posted on May 28, 2009
localwonder
  • 6784 Answers
SOURCE: noisy fan or motor?
HI. The most common issue here will be with a loose motor shaft. This is the part that the fan blades are mounted on. When this occurs, the looseness will cause the motor, and shaft to wobble, thus, causing this noise you here at high speeds. The wobble is less violent during the slower speeds, so it is not loud, in this case.
The second issue will be a warped fan blade. This will cause the fan to rub against the shroud, thus, creating the noise, as well.
If the shaft is loose, or bent, the entire motor will need to be replaced. Now, if the fan blade is warped, you can, simply, unscrew the blade from the shaft, and replace it(on most model)
Posted on Dec 11, 2009
Fan come on by self
The control knob may have a short that is not good. It needs service to protect you from electrical issues.
Oct 19, 2014 | Broan 36" Under Cabinet Hoods QS3 Series...
Lights quit working on broad range hood
The tiny metal tabs that contact the very end of the light bulb after it is screwed in making a circuit get pushed back too far when you tighten the bulb and with all the steam and muck eventually fail to make contact. shut down the power and use a tiny screwdriver to gently nudge the electrical contacts back up "a little cleaning wouldn't hurt either" look at the very bottom of your bulb, clean that too perhaps with a few strokes of a wire brush, gently put the bulb back in and you are good to go, mine did the same thing.
Mar 29, 2014 | Broan QS130WW Under Cabinet QS1 Series...
Noisy fan or motor?
Dec 11, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Range hood installation
May 28, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
42" Allure II Broan Range Hood I put a new bulb to replace
Get two new bulbs and install them. These bulbs are exposed to a lot of heat above the stove and the filaments get brittle. I suspect that the filament on the bulb that still worked broke when you were screwing it out or back in. good luck. please rate my answer. thanks noreen.
Feb 03, 2009 | Broan-NuTone Broan Range Hoods Allure II...
7" damper
The damper you are looking for is Broan part number 97. It is available online.
Jan 17, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Broan-NuTone Allure III QS330SS Kitchen Hood Logo
580 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
