Dell 151f lcd monitor lights up to xp start page then disappears and shows like a sceen saver on screen
    Sergeant:
    Champion:
  • 275 Answers
Try going in the safe mode by hitting the f8 when the system is booting ... just passing the bios screen and if that works disable everything in the msconfig in the startup option and than restart the system
Posted on Oct 31, 2008
I have occasionally found the laptop (usually after being turned completely off) will not re-start, instead showing a "fan error" message. This, however, has been succeeded by a new, unsolvable...
To disable hibernation in windows xp:
-Right click on the desktop
-choose properties
-Click the screen saver tab
-Click the power settings button
-in the power options properties dialog box click the hibernate tab
-uncheck enable hibernation
-click OK
Hope this helps!
Apr 15, 2011 | Computers & Internet
Dell E152FP monitor after startup or coming back from standby the screen will show up and 5 seconds later it disappears. I turn off the monitor and turn it back on. The image comes back again but it...
Hello
Probably the monitor. LCD monitors use electrolytic capactors which change value with heat. The power board in yours probably has 6 to 8 caps whic need replacement. Take it to a reputable repair person or check out my websit.
Thanks
Jan 07, 2010 | Dell E153FP 15" LCD Monitor
The light went out on my montitor.Can still see screen no light
You need a new lcd screen & while you're at it replace the inverter. There's no other option. Check ebay for the parts.
Jul 13, 2009 | Dell Computers & Internet
Delll flat screen moniter goes black.
Assuming you are running XP.  Right click on the desktop, select Properties, select the Screen saver tap.
Click on "Power"
See adjust the time out so that it is  "Never"
May 18, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Washed out monitor when viewing most web pages
exchange your dell monitor to gateway monitor.If the monitor from dell showed the same problem when you connect it to gateway. you must install video card driver. and if the monitor from gateway showed the same problem when you connect it to dell adjust your contrast to full and the brightness to 50% and adjust the colors to 100%
May 13, 2009 | Gateway Profile 5 PC Desktop
Hp w2007 blank screen
we have here , like 1000s of black screens posted here now.
all the same all with CCFL lamps. that die. same solution.
older monitors have a power saver mode inside it,
push the front button called menu, then see OSD menu
then find and turn off power saver.
if the OSD fails to show up; the CCFL are dead.
this monitor was made in 2007, and 2010 is the starting year
for ending the usage of CCFL (starting on large screens working to small)
im reading your manual for you now, free.
page 4 tells you it has CCFT (T mean Tube, L means lamp)
same same.
https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=4#manual
now lets look at the page on saver. power
page 7, (its on by default ) oops !
https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=7#manual
turn saver OFF
see next page 8 and turn DDC ON.
see sleep timer and turn that all off.
if you push factory reset, it the problem begins again.
bad. for you.
https://www.manualslib.com/manual/1110533/Hp-https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=8#manual
you can in fact download the whole manual.
for free. here. the site on the internet in this regard.
all old HP monitors are made for old PC 2000 year.
your PC is not 17 years old i bet.
so all this old saver stuff is now WRONG.
(all this is old school Energy Star , malarkey, )
Nov 13, 2017 | HP W2007 LCD Monitor
Dell E178FPf LCD monitor goes to standby and won`t come on again
Check your Power options in Windows.
right click on the desktop. select properties, Gop to the screen saver tab, click on the power button at the bottom right and check to see if its set to turn off or standby the monitor, turn this off.
Keep the screen saver on and set it for like ten minutes.
Also, on the monitor itself, it may have a sleep or power save option set as the default. check all the monitor settings on the actual moniotr itself.
Mar 31, 2008 | Dell E173FP 17" LCD Monitor
Is this a Software/Config/Hardware Problem ?
hmmm..sounds like a sleep or screen saver conflict...try booting up on Safe mode(F8) on turn on, and then see how that works. Set your screen saver for Never, and see what happens.
You may be hitting a thermal issue with your video circuitry.
Feb 18, 2008 | Dell Dimension 4600 PC Desktop
Dell touch screen monitor not lighting
Repairing the Dell E153FP with this complaint is not that hard but one that should be done by a qualified service technician or monitor repair specialist. Usually when you have this type of problem it is because either the inverter board, filter capacitors or the main board has one or more burnt components.
Any TV/LCD repair man can test this out for you if you don't mind paying them to do tht typical charges at our shop for such a diagnosis run around 35-50 dollars... this cost is usually included if you have them repair the item for you.
Jan 01, 2008 | Dell E153FP 15" LCD Monitor
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
