Question about GE Profile JTP18 Electric Single Oven
JTP18 problem Without warning the oven tries to intiate the broil mode. It is unsuccessful but tries anyway. Periodically if refuses input from the keypad. I have tried disconnecting power several time with mixed results. Sometimes it will work fine for a couple of day. Other times if still refuses input.
  • GE Master
  • 4,655 Answers
Oven won't heat past 290 after that we get an error message
Your oven is in celcius mode to change press bake and broil at the same time SF will appear then press broil and cooking time at the same time a C will appear press again to toggle to farenheight then press start to lock it in that mode. Some models when you press the bake and broil the sf will appear if it does press the press the broil button to toggle between C & F then press start.
www.appliancehelponline.com
May 21, 2010 | GE Profile JTP18 Electric Single Oven
After self-clean cycle oven door won't unlock
your lach might have given out on self clean. change it
Feb 12, 2010 | GE Profile JTP18 Electric Single Oven
GE profile lower oven does not turn off...maintains low heat with the convection fan on for several hours.. When i turn oven back on and then off it stops...but the problem continues to happen periodically
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
Sep 12, 2009 | GE Ovens
I have a GE JTP18 Trutemp. It seems to be taking
sounds like a stuck relay on the control board ... can you tell if the bake or broil element is glowing during this time?
Jul 19, 2009 | GE Profile JTP18 Electric Single Oven
My oven shuts off after turning it on makes a clicking noise then shuts off if u mess with it turning it on about 10times it willstay on ge modl jpt 10gp2bg
Do you mean that:
if you program it for bake (or broil) mode it acts like it is working but then shuts off after about 30 seconds?
also, is it actually a jtp10gp?
this is characteristic of a control board failure, I believe it is no-longer-available, good news is that we can fix it for you at www.fixyourboard.com
GE mod.JDS27G0P2BG Oven Wont start
You have a bad electronic control board.
No repair.
It must be replaced.
Feb 21, 2009 | GE Profile JTP18 Electric Single Oven
Oven top element gets SUPER hot without warning
the sensor in your oven is picking up the high heat and posting error message which displays F2 ,at least the sensor is working but lets look at the problem isuspect one of two the first is your control switch needs tested i would say this is the problem and number two the elemant could be on its way out either of these problems are going to need a electrican to fix ,sorry i cant give you a simple answer to your problem.adrian
Jan 24, 2009 | GE Profile JTP18 Electric Single Oven
JTP18WD01WW no broli, no bake panel works
my wife has arthitis in her hands and the touch screen does not work when she touches it . otherwise it works fine when i use it . is this a body temp problem .
Nov 04, 2008 | GE Profile JTP18 Electric Single Oven
Oven door won t open after self clean cycle
Frigidaire CGEB27S7CB built in wall oven. Set to clean oven yesterday and after cycle door stays in locked position. Can not open door. I tried re setting clean cycle and cancelling but will not unlock door.
Dec 22, 2007 | Frigidaire GLEB27S7A Electric Single Oven
Ge oven jtp18 broiler mode
Mine started doing this also. It is the "F7" error reported elsewhere, and it means a bad board or bad connections. I'm in search of a diagram or something to tell me how to open the face up and look at the contacts to the board.
Mar 21, 2007 | GE Profile JTP18 Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
93 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
