Question about Acer Aspire 5500 5570-2609 Laptop
Keyboard i need help fixing my laptop the keyboard it lock on one side of the key pad when typing YIUOPHJKLNM it only giving me # please help
  • hordercas Oct 31, 2008
    Thank you so much it fix you the best
    New Friend:
  • 3 Answers
Easier change the keyboard you can find how do it even here: http://howfixlaptop.blogspot.com
Posted on Dec 15, 2012
    Scholar:
  • 63 Answers
Not a big problem...
You probably have an external keyboard attached to the laptop at some point yes?
Easiest way to fix is attach an external keyboard and disable # lock.
Or on your keyboard.. use the FN key and hold it while you press the key on your laptop that has NUM or # on it. Look at the lights on the laptop to see if NUM LOCK is enable.
best wishes.
Posted on Oct 31, 2008
Streambook 13 keyboard locked up. How to return it to original settings
since the laptop is only a few days old I would recommend performing a factory restore to the "out of box" state.
Jan 05, 2015 | HP Computers & Internet
I am not able to work with my keyboard function keys and num keys and function keys . but the the touch pad key is onlyworking .please send a solution to unlock the keyboard. hp pavilion g6-2102tx
Examine your keyboard to ensure your "Number Lock" key is not activated. This activation is indicated by the key being lit up. If the key is activated, press it to deactivate the lock. The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor. In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon. Hope this helps.
Dec 10, 2012 | Computers & Internet
Keys on "jio" give me
That section of the keyboard doubles as a numeric keypad.
7 8 9 is 7 8 9 u i o is 4 5 6 j k l is 1 2 3 m . is 0 .
CHance are the keyboard is in NUM LOCK or PAD LOCK mode. To fix it, shut off Num Lock, which is usually the blue "Fn" key and the key with the blue Num Lock words on it. It varies by laptop.
Once out of Num Lock mode, the keyboard will behave normally.
Apr 16, 2011 | Sony VAIO GRS150 PC Notebook
Where is the "tm" symbol
There is no "tm" symbol key on a keyboard, you need to enter an ALT key to type the trademark symbol.
Hold down the "ALT" key while typing 0153 and it will enter this: ™ when you release the ALT key
Mar 04, 2011 | ASUS Eee 4G Notebook
The keyboard on my laptop has numbers and keys on it
It sounds like the Num Lock is on.
Depending on the make of the laptop there is a few different ways to turn it off.
Either just hit the Num Lock key and see if it goes off, hold down Fn and hit the Num Lock key or hold down the shift key and hit the Num Lock key.
Regards.
Sep 22, 2009 | Computers & Internet
My asus 1000hp netbook has a locked keyboard, and can't log in .
Keys 7, 8, 9, 0, U, I, O, P, J, K, L, and M are permanently stuck as if Fn is pressed so it is in the number-pad mode. So I can't type the above keys at all. If I want to type 0 I would have to type M. Obviously I am using a different computer now, just in case anyone is wondering. So does anyone have any solution to this? Please help!
Aug 08, 2009 | ASUS Eee PC 1000H Laptop
Certain letters are not working
When keys go faulty the entire keypad needs replacing. You can't replace individual keys. I would suggest contacting dell and ordering a new keyboard, it's an easy fix: http://www.essortment.com/articles/install-replacement-keyboard-dell-inspiron_102151.htm
If you need to purchase one, I did locate: http://yallstore.com/laptop-keyboard-replacement-for-dell-inspiron-1525-p-4228.html For $16
May 23, 2009 | Computers & Internet
Toshiba Laptop Keyboard problem
My Toshiba Satellite A45 S120 keyboard has a problem, some of the keys are not working. When you type it does noting. Sometimes when you start the computer, it continuously types the letter eeeeeeee. You can hit some keys randomly and this will stop, but if you start a program (eg. ms word) the same thing happens.
Sep 05, 2008 | Toshiba Satellite A85-S107 Notebook
I have a hewlett packard laptop and on the right hand side of the keyboard are the keys with a small box with alternative symbols that can be used. I seem to have locked the computer into typing only these...
This feature will be available with Notebooks which are small in form factor and there is no space to provide the Number Pad seperately. So, the Numbers will be integrated on to the Alphabets.
Inorder to switch on the Number Pad, you need to hold the FN key and press the Number Lock. Pressing the Number Lock alone will not disable the integrated Number Pad.
Hope this helps...
Sep 04, 2008 | HP Pavilion dv2000t Notebook
My numbers aren't working and my num loc is on
i got it!! hold down the 2 shift keys for a few seconds then bamm!!
Sep 08, 2007 | Targus USB Ultra Mini Keypad Keyboard...
Acer Aspire 5500 5570-2609 Laptop Logo
215 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
