Clevo model 98 with huge trouble to boot up.
I got an old laptop from a dumpster site a few months ago but I didn't have a power adapter for it. A visiting friend of mine had a fujitsu with an adaptor which was the same model as one listed as compatible on my laptop, I tried it and it seemed to be just fine! So I bought a hard drive for it and order an adapter for it, also listed as compatible in the label under the bottom. Thing is, sometimes it boots up quite fine, goes in windows and I can work as long as I want with it. But if I switch it off and on again either it will but with a lot of distorcional lines on the display ( you can see it running but can't read anything) or the screen stays black with a few horizontal lines droping down all the times. It's not the screen because an external screen connected to it gives me the same results as the screen on the computer.
The computer requires 19v and 2,4A. The charger is 19v 3.16A. Could that be a problem?
Thanks for the help!
    Scholar:
  • 63 Answers
The problem a failing GPU on the motherboard. (Graphics Processor Unit)
These aren't replaceable on most laptops and req. a full motherboard swap out.
You can try.. it's not imposible but its also not really worth the effort.
Best wishes.
www.techvisitor.com
Posted on Oct 31, 2008
Dell 1545 Purple Power Light
From your description, one of two problems - either the power adapter (ie cord) is bad, or the switch inside where you plug in is bad.
Jun 30, 2013 | Dell LATITUDE Computers & Internet
Demolition web-sites services with Dumpsters?
Dumpsters are huge dumpsters from 10-45 cubic yards. They are employed at demolition websites, cleanouts, renovations, building internet sites, factories and massive corporations. 95 gallon dumpsters are utilized by modest companies and houses exactly where a regular bin could be also small, but a common dumpster with Dumpsters.
May 23, 2013 | Audio Players & Recorders
Hi I need the Lan drivers for Croma Netbook Model M810L. Can you suggest where can i get them from
Hi there,You can download the drivers for your Lan adapter at the site below. The Clevo Drivers will work for your laptop as well as they both identical Netbooks just with diffrent Branding names.http://www.clevo.com.tw/en/e-services/download/ftpOut.asp?Lmodel=M810L&ltype=9&submit=+GO+
Hope it helps,
Jul 27, 2011 | Computers & Internet
Will not Power Up. I hit the Power button, green LED lights up for about 3 seconds (cooling fans start), but then shuts down. The battery is 3 months old, and the Power Supply is working.
Remove the battery and the power adapter. Now just plug in the power adapter and boot the laptop. Will it boot and remain on? If so then the battery is faulty. If not try a different power adapter, the worst case is that the system has failed. -Ravi Shanghavi
Aug 18, 2010 | Toshiba Satellite A65-S1762 Notebook
My clevo m120w usb port not working but hardware driver is ok pls halp me
Wich os? If you have Win 98 or older Then the usb drive Doesent work;)
Try the download site for your laptop
Dec 31, 2009 | Clevo 2850 Notebook
Few months ago I started having issues with the ac adapter it did not provided power to the unit, if you unplug and plug it again from the power cable it worked, until one day just stop. I purchased one in...
Apparently, either the AC adapter isn't compatible (check the voltages and power ratings) or you have a battery charger issue. If you're sure the adapter is OK, then the battery might wrongly report a full charge at a higher voltage than the AC adapter.
So when the battery is plugged in, it will always preempt the AC adapter - possibly even shutting it down - except that, having almost no power left, it will also force the computer itself to shut down.
What might have happened is that the faulty AC adapter actually damaged the battery. I'd suggest checking with another battery if any is available, and not to use both together lest the battery now damage the new adapter. But first of all, check the power ratings and polarity on the adapter against the old one and whatever is indicated (usually) on the PC underside, just to be sure.
Oct 27, 2009 | Gateway 6022GZ Notebook
Sony Laptop wont power ON
Try booting it from your CD drive.
Any messages on the screen ? any lights on??
Aug 26, 2009 | Sony VAIO PCG-K35 Notebook
Gateway laptop model W350i will not boot. When power button is pressed, red light flashes four times. Replaced AC power adapter, tried removing battery and power with AC only, still does the same thing. ...
It's a hardware failure like a cpu fan not working or faulty ram.Check the gateway site for an explanation of the lights. It's flashing a trouble code.
Jul 12, 2009 | Computers & Internet
Age of computer
It's a fairly old system, that came installed with Windows 98. Considering it's 2008....yes I would say it's an old computer. That doesn't mean it won't work.
It will be hard to find adapters to work with that system since Microsoft discontinued Windows 98 a few years ago, and all the support for that OS.
You may want to make sure there is enough hard drive space, as well as RAM...and if you do have enough oomph, then format and install Windows XP Home or Pro.
Feb 24, 2008 | HP Pavilion n3290 Notebook
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
