Question about EnGenius EOC-3220 (EOC3220)
I am using a EnGenius Senao 3220 plus bridge radio to pick up the signal from another same brand radio. i am able to connect to the network but i was not able to get in to the internet: "Unable to get a log in page." it works fine when when the bridge is switched off but when it is switched on i have problems on my Vista Laptop but on my Xp laptop it works fine.
  • Anonymous Dec 03, 2008
    I had the same issue, had to put my computer in the same IP subnet as the router and include the local dns servers to get internet. This was a quick fix, but not the one we are looking for.
  • 481 Answers
If you have the radio configured as a bridge (not a bridge-router), you must ensure that your computer is in the same LAN IP subnet as the remote router. If the remote router supplies DHCP, this should happen automatically; if not, you must configure your computer manually.
Once there, you may have to manually define DNS servers on your computer in order to access machines on the internet by name. If you can browse to http://216.239.122.34, but not to http://google.com, your problem is solely lack of defined DNS servers. This is not an artifact of the Engenius units, but the remote server.
Posted on Nov 18, 2009
The bridge locks onto the strongest signal automatically. this is not the network i want to connect to. how can i select the desired access point for the unit to communicate with?
Use "change order of preferred networks" to lower the priority of the "not-wanted" network, to a level below the priority of the "desired" network.
Feb 17, 2011 | SENAO NL2611CB3 PLUS (NL2611CB3PLUSDX)...
My Seneo 3220 has changed its mac and gone to Realtek,can not log on to it any more,think its lost Engenius software. nigel 2205
I have no idea what it means for a Senao to "go to Realtek."
Here is the factory reset procedure for the Senao EOC-3220:
An RS-232 null modem serial cable is required for this procedure.
1. Connect the EOC-3220 to your computer with a null modem serial cable.
2. Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3220.
b. Select correct COM port. Ex:COM1.
c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
Oct 25, 2010 | EnGenius EOC-3220 (EOC3220)
Problem using 2nd hand AP senao EOC3220 EXT
You can use this unit either as an access point, to provide wireless access to a network you already have, or as a bridge, to access a remote wireless network someone else has.
Note that you own the EXT model, meaning that you have to attach your own antenna to the connector before it will function. There is no internal antenna on this model.
Configuration instructions are available at
EOC-3220 Series User Manual
Factory reset instructions are available at:
http://engeniustech.com/datacom/support/general-details.aspx?id=65
May 14, 2009 | EnGenius EOC-3220 (EOC3220)
How do i reset my engenius senao eoc 3220 outdoor radio
back side one reset button is there pull out the power cable then pull in that same time you have to press the reset button for three to five sec then all lied's blink all to gather then your default ip address is came then you again configure at default ip
Apr 15, 2009 | EnGenius EOC-3220 (EOC3220)
Site survey no signal
Site Survey is meaningful only in bridge mode, not access point mode. Assuming you are operating this unit in bridge mode, it could be possible that no signal is being detected because there are no access points nearby for it to detect. If you know that there are, in fact, working access points in the vicinity, then my first suspicion is that you have a faulty unit.
Jul 14, 2008 | EnGenius ECB-3220
Senao 3220 - access configuration info
I do not know what you have for a DHCP server but some DHCP servers will show you what devices have been given IP addresses which you can use that information to find what address it is at now. Other than that you can use the guess and check method just going through IP addresses until the page comes up, you can use network mapping software to scan your network to find it or you can reset the access point to factory defaults where it will have the default IP address that you can then connect to and re configure it the way you want it.
Jul 06, 2008 | Computers & Internet
Engenius
Enter the configuration utility inside the unit and run a signal survey. If the survey does not detect any access points, your radio section has gone bad. If it does detect the appropriate access point, examine the signal and noise numbers associated with the access point. For a reliable connection, there should be a difference of at least 18 between the two figures.
Jun 28, 2008 | SENAO NL-2611CB5 PLUS (NL2611CB5PLUS)
SENAO EOC 3220 CONNECTIVITY PROBLEM
hello!
-- try to change wireless channel on your access point
-- try to enable wireless security on your wireless network
-- try to assign static ip address on your wireless computer
Apr 26, 2008 | EnGenius EOC-3220 (EOC3220)
Resetting the senao eoc-3220 long range wireless access point/bridge
Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal. c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
Feb 21, 2008 | EnGenius EOC-3220 (EOC3220)
I made firmware 1.39 to SENAO ECO3220
hey maick, I have the same proble, but I fix it, try this: 192.168.1.254, for me work fine, after that I reload the new firmware. now is working fine. good luck, jose luis Ogawa
Jan 19, 2008 | EnGenius EOC-3220 (EOC3220)
EnGenius EOC-3220 (EOC3220) Logo
261 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
