My computer won't read disks
My computer seems to be fine, but it doesn't read any CD that I put into the CPU. At first I thought that may be the lens needed to be cleaned, but I worry that it could be much worse than that.
  • Yeli Oct 31, 2008
    Oh, yeah I just remembered that a code pops up when I double click it; (cod 39). Its a Gateway GT5482E, with Window Home Vista.
    Sergeant:
    Champion:
  • 275 Answers
Try to uninstall the ide channels from the device manager and than restart the system
Posted on Oct 31, 2008
Put cd in, says it’s reading disc, after10 seconds it says Not Playable, then ejects disc
hi Nancy.
this could be dust on the lens that reads the disc.
Use a disk-based lens cleaner to remove ground in dust or dirt from the CD player's lens. These lens cleaners look like a regular CDs, but have specially-made bushes on the reverse side that gently remove excess dirt from the CD-reading lens. Simply put the CD in your player, and press the "Play" button to clean the lens. Do not run the cleaner more than once, as excess brushing can cause scratches on the lens.
Polish the lens. Use a glass or eyeglass cleaning solution and a lint-free cloth to gently polish the reading lens. Clean it by using a low amount of pressure and softly polishing the lens and its surrounding area using soft, circular motions. Do this for about a minute or two and then allow the player to sit for a few minutes before trying to play a CD.
read up some more at this link.
How to Fix CD Player When It Won Play Techwalla com
Dec 20, 2017 | Audio Players & Recorders
My dvd drive doesn't work
If it happens for only one particular disk:
Bring that disk to a game store like Gamestop or Rock30 Games and have them professionally clean the disk for a couple bucks.
If it happens for all disks:
Clean the cd/dvd with a laser lens cleaning kit. If that doesn't fix it then the cd/dvd drive will need to be replaced.
Jul 31, 2012 | Acer Aspire 5738Z Drivers Recovery Restore...
PS3 won't accept certain disks. A few disks i have won't play in my ps3. it happens to both blu-ray movies and games, and it seems to only happen with blu ray disks. i'll put the disk in, and...
Hello
The noise is actually a product of dust from a blue ray disc.Over time these discs heat up and leave a residue on the blue ray lens.
Try using a lens cleaner to remove dirt and clean lens.
Also i read an article that using a wireless controler can also cause freezing of the blue ray.
Oct 01, 2011 | Sony Playstation 3 (PS3) Console
Power works; fan spins;light is on; promo screen works; disc won't read; disk won't spin
The most likely situation you have here is that the cd drive lens isn't reading, just because with a gamecube, it relies on that lens to detect if there is a disc inserted. Your best bet is to try and clean the lens with a que tip and some rubbing alcohol. Be gentle, only very gentle wipes back and forth in a circular motion, then dry it the same way. If that doesn't work, I can give you some tips on how to rip the thing apart and see if it is a connection inside somewhere
Sep 09, 2011 | Nintendo GameCube Console
My Toshiba Model L505-S5993 laptop won't read
Hello there,
The problem is that the Drives lens is already bad and cannot read any disc, no matter the type of disc you put into it, it wont read it still. The solution is to replace the drive. Replacing it is the best way to solve the problem. If not trying to replace the lens is going to be futile as the lens for the driver is not available and when you install a new disc drive, it will have to install the drivers software.
If you replace the lens, the laptop wont be able to install the drivers of the lens as it reads it alongside the driver itself and if they are not compatible, it wont install the drivers software. So my best advice is for you to replace the CD drive.
My laptop is a typical example because my disc drive is also bad. And i had to replace the drive and not the lens.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 09, 2011 | Toshiba Satellite L500 Series Notebook
Have disk in drive E but computer says "Please
try to put some cd lens cleaner if you have a previous cd cleaners you can use it
Aug 03, 2011 | Acer (KV.16X04.007) DVD Drive
Why my dvd /cd not work properly , in hardware it show the it is woorking properly , but if i put any cd and insert it then after its not read the data in cd
Does the led on the dvd/cd drive flash after you've put in a disk? Go into "My Computer" and check that the drive is indicated there. If it isn't, then you would need to check the drive connector inside the computer to make sure it is connected properly and that it is not loose. If the drive is indicated in my computer, try another disk, perhaps a music cd, and see if the drive reads the disk. If it does, that tells you that you may have some defective disks. If the drive is detected in my computer, and no disks are read by the drive, then I would assume the drive is defective and replace it. Good luck!
Jan 24, 2011 | Computers & Internet
Cd x-9 teac will load cd spin but not play lcd reading says 'no cd'
If this problem occurs only at this cd/dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alcohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case you can, use a Q-tip with isopropyl alcohol to clean up the cd lens manually. In case this doesn’t solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 14, 2010 | Audio Players & Recorders
Cdrom not reading all disk
Not to worry i was also facing problems like this ...just clean the lens with a len cleaner....and see it will start reading after that
Jun 03, 2008 | Dell (5X840) CD-RW/DVD-ROM (Combo) Burner
My e drive wont start up any product
When you are refering to the E drive, do you mean your dvd/cd drive?. If so 2 things to try, first a lens cleaning cd rom, secondly if still no nada, go to my computer, right click, down to properties>Hardware>Device manager. Click the '+' sign on DVD/CDROM Drives and highlight your drive and right click then Delete. Re-boot you PC and let windows find your drive again automatically, then try playing something again. If still nothing it's time to replace the drive, they are very cheap nowadays.
Dec 08, 2006 | E-Machines T2792 PC Desktop
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
