Question about GE GSD2200Z Dishwasher
GE GSD2200G02CC dishwasher
My dishwasher will not clean the dishes. When the dishwasher was run (I was not there) my roommate told me that "stuff" backed up into the sink. Now each time we run the dishwasher, the dishes do not get clean. (I think someone did not rinse the dishes properly and there is a clog somewhere.) I tried to run the dishwasher with out any dishes. I don't think it filled up properly. When I opened the dishwasher door, it was wet but there was not a puddle of water at the bottom. However, there were peices of food inside the dishwasher. I thought I would try to clean the filter out, but then someone told me that there is not a filter for this dishwasher and that I probably need to replace the water valve. Does that sound right? If so, how hard is this to do? thanks, CL
  • kobb Nov 27, 2007
    How do you clean the rotator blades?
  • 94 Answers
Your dishwasher probably has rotating blades on the top and bottom that spray water on the dishes.  Clean these off and make sure the holes are not clogged.
Posted on Oct 21, 2007
Ge profile dishwasher not cleaning
Our GE dishwasher never did clean correctly. Then it died. WE bought a new dishwasher different brand . New dishwasher is cleaning great clean dishes now. GE Dishwashers sucks!
Nov 10, 2013 | GE 24 in. Profile PDW7800 Built-in...
Whirlpool Gold dishwasher not cleaning dishes. It runs through the cycles and rinses, but dishes are not completely clean.
I had a similar problem with my last two dishwashers, with food still left on the dishes at the end of the cycle. What a nightmare. The most recent dishwasher is new, now the problem is solved. Here's what the manufacturer told me. Pour white vinegar (approximately 2 cups) into the dishwasher and run through the cycle. Buy some Cascade Complete and only use this type of soap for the dishwasher. Make sure you run a cup or two of the white vinegar through the dishwasher cycle once a week. My dishes are now clean and clear!!
May 26, 2011 | Whirlpool Dishwashers
Why won't my GE dishwasher get my dishes clean?
IF all appears to be working just leacing film on dishes or if not actually cleaning dishes there could be several things it could be... the basics to start with are first make sure the entering water temperature to dishwasher is a t least 120-140 degrees ... run water at sink prior to starting dishwasher.. next remove drain line from under sink and check for any obstruction where it connects. check the area under lower spray arm for trash/food build up and if you can remove spray arm and clean port out of any calcium build up... make sure the water is filling unit properly run a cycle and when you start unit listen when it stops filling open door and make sure it has enough water in it.
Jan 27, 2011 | GE Dishwashers
The dishwashing liquid has gotten thick in my ge dishwasher. The dishes are not getting clean. How do I clean out the dishwashing liquid resevoir?
Try running the hottest, longest programme WITH detergent but WITHOUT dishes. If you usually wash just a few dishes on a short programme, you might find that the machine never gets hot enough to wash away all the detergent residue.
Oct 09, 2010 | GE Dishwashers
GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Feb 26, 2009 | GE Profile PDW8400J Built-in Dishwasher
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE Monogram ZBD0700K - gel pak detergent not dissolving
Low inlet water Make sure inlet water temperature is at least
120°F (49°C)
Run water at the nearest faucet prior to
starting the dishwasher to insure optimal water
temperature.
Water pressure is low Turn on a faucet. Is water coming out
more slowly than usual? If so, wait until
pressure is normal before using your
dishwasher.
Air gap is clogged • Clean air gap.
Improper rack loading Make sure large dishware does not block the
detergent dispenser or the wash arms.
Jun 20, 2008 | GE Monogram® ZBD6880NSS Stainless Steel...
GE GSD2200Z Dishwasher Logo
358 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
