posted by jwlev on Sep 14, 2006
My kenmore dryer, electric, does not shut off. The timer does not move(dial), it seemed to take longer to dry. I cleaned the vent, which there was a lot of moisture lint in, also took out the lint catcher and shop vac'd all the lint out of there hoping the sensor was just picking up moisture and causing the dial to not advance. It seems to be drying quicker but the timer still does not advance. The dryer is 8 years old and at the time was rated #1 in consumer reports. Any Ideas? Thanks, Jeff
1 Other User Has The Same Problem
Comment by Guest, posted on Apr 13, 2008
dryer takes too long to dry
Best Solution
posted on Sep 14, 2006
Jeff, almost sounds like a timer issue, but I was fooled on this once. Under the consol is a inline resistor from the main plug. If this resistor is bad, dryer keeps running in timed dry. Part number for the resistor is 3401076. Look it up on the web so you know what it looks like. Just splices in.. Catriver..post back.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 01, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
This may not be the solution to your exact problem but for those looking for why there timer will not advance and why it keeps running even when the items are dry: The usual problem is not the timer but the mosture sensor (if your dryer has one).
1: Check the mosture sensor light/indicator. If is still shows some mosture or flashes even when the items are dry, you have a mosture sensor problem, probably not a timer issue - luck you.
2: Check if the timer will advance and the dryer will turn off when you have it in the TIMED mode (i.e. 10mins - NOT the more/less dry modes.) If so, then it is indeed a sensor problem.
2: Check that the wires to the mosture sensor have not fallen off (as in my case - a simple repair). The senor is usually two metal bars somewhere near the front part of the inside of your dryer. You may have to take off the door and the front pannel (be sure to unplug the dryer first) to get at the two wires to clip on to the sensor. Clean any lint and make sure they are conneted. If well connected then replace the sensor ($15-$20 and very easy to do).
Solution #4
posted on Feb 22, 2008
I have a kenmore dryer. I purchased it brand new from sears in August 2001. I have noticed about 3 weeks ago when I went to dry my clothes that the timer does not move. The dryer still heats up, it takes a little longer to dry but it still works. Can you tell me what may be wrong with it. I am wondering if the repair would be cheaper or should I invest in another dryer!
Suggest a new solution for this problem
Post a New problem for Kenmore 62602 Electric Dryer
Email this problem
Email this problem
Can you Help with these Dryers problems?
Kenmore Dryer Model 86873100
All aspects of unit works well... Answer This...
Repair Service
Find Dryer Repairman Near You:
Find Parts
