Question about Dryers
My whirl pool dryer does not dry?
Dryer not heating already trouble shot glow. Dryer runs and glow coil never gets power or call for heat? I confirmed that with a meter. I would like a wiring diagram.
    President:
  • Dryers Master
  • 2,651 Answers
Coil never gets power usually a sign that you have a blown thermal fuse , small white 2in' fuse located behind rear panel, there should be a wire diagram behind the console, few screws acrosss the back
Posted on Oct 31, 2008
GE Profile Harmony Gas Dryer not heating/drying clothes.
let me ask you this does the ignitor glow orange but no flame when you have no heat?usually on a gas dryer if at first you have heat and then after 10 to 30 minutes no heat it's usually the gas coils located on top of the gas valve,common problem,after the coils cool down they will work again,that dryer is kind of complicated to work on seeing how it does have two motors in it but you should be able to get at the gas coils,if you send the model number i can look it up for you.but it sounds like you have bad gas coils,the only way to tell is run the dryer,when the heat stops working look at the ignitor,if it glows orange and the flame doesn't ignite you have bad gas coils.
Feb 14, 2014 | GE Profile Harmony DPGT750GC Gas Dryer
Drying time taking to long
Try putting a vaccume cleaner as far down the vent hose as it will go and suck anythng in there out, , And if you can put a vacume cleaner attachment in the lint trap and suk some stuff out as well ,, other than that i doubth that there is anything else that can cause the problem...
Jan 16, 2008 | Whirlpool CSP2761 Gas Commercial Dryer
May Tag Gas Dryer Model MDG3000AWW - Dry works but no heat, more dry/ less dry lights flashing. Whats wrong? How do I get heat again?
it is either your glow coil or it is your ignitor
open the door and remove the four screws
take the front panel off.
leave the door attached so you can test the dryer
be very careful not to touch any wires while you are doing this
now close the door and turn the dryer on
does the ignitor turn on?
if yes that is good
does the ignitor glow and no flame?
sometimes it will take a minute to show it's problem
if the ignitor glows and no flame replace your ignitor coils
make sure to turn the power off when replaceing the coils
Aug 24, 2010 | Maytag Dryers
Sometimes dryer will heat right, next time it won't
You more than likely have a buildup of lint in the vent hose. Even what looks like not much lint in there can cause the dryer to have issues drying the clothes. Clear the hose out really well, take it outside and shake it all out, then hook it back up and give it a shot. If that doesnt work you may have a bad thermal fuse which regulates the dryer temperature and you will need to have it replaced.
Dec 14, 2009 | Whirlpool Dryers
Gas dryer does not heat GAS DRYER DOES NOT DRY CLOTHES WITH HEAT
check for igniter to be glowing, remove the plastic tab on the front panel an start the dryer
if it glows igniter is ok takes about 30 seconds to glow.if it glows is ok.
then check the thermal fuse for conitnuity an if it checks ok
then you have bad coils. replace the coils an ur done
May 26, 2009 | Frigidaire GSGQ642A Gas Dryer
Dryer does not go past wet cycle
if your vent hose is clogged, your element most likely burnt open
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
HE3 electric dryer only gets warm
your dryer igniter, and or coils are shot.. change the drop in coils first...
Jan 23, 2009 | Dryers
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
By the way your describing the problem the thermostats are getting weak on the elements replace the operating and the high limit t-stats.
Jan 03, 2008 | Dryers
Whirl pool Dryer not staying hot
you need to have your gas valve coils replaced good luck
May 27, 2007 | Whirlpool LGR4634J Gas Dryer
Dryers Logo
59 people viewed this question
Top Dryers Experts
