My Xerox XC 1045 copier's paper jam indicator is lit, however I have cleaned and searched thoroughly for any jam but cannot find one. The jam indicator states it is coming from the paper supply but after close examination there is no paper jam there....could it be a bad sensor? P.S. - I recently put in a new drum and toner.
  • McLlinus Djata Atieku Nov 04, 2008
    my xerox 5328 indicates paper jam but for sure theres no paper hidden there. how can i clear the paper jam from memory or otherwise
Hi
Replace or clean paper eject sensor and chek
Dileep
Posted on Nov 05, 2008
Symbol lit up but don't know what symbol means, I don't have manuel - begins with 2 dots :
The symbol with the 2 dots and what looks like a jagged line is the paper jam indicator. Open the paper tray and or front and back access doors to find and remove the paper jam. I the light still does not clear try turning the printer off then on to reset the jam indication.
Aug 20, 2010 | Lexmark E260 Laser Printer
Xc 1040 xerox Red light is flashing and the copier will not
On a XC 1040 machine either there is a jam on the fuser, the fuser switch fell out of place, or the sensor swich arm fell off the registration sensor.
Since we cannot see the machine we might understand what is taking place.
If the machine is turned off and back on and there is no red light, then the machine must be able to attempt to make a copy. If a copy does not come out, then there is problely some worn feed rolls.
If when the machine is turned on and there is a red light then th There can be some bad paper feed cluthes as well.There might be a paper stuck at either fuser assemly or paper feed roller areas.
Provide more description about the visuals on the machine.
Good luck.
Jul 15, 2009 | Xerox WorkCentre 4118 Network Kit...
It is constantly jamming when we try to do a duplex print
Since duplex doesn't get used a lot, much dust collects in the duplex unit. Remove it and thoroughly clean it by blowing dust off. Look for scraps of paper that might have settled in there.
Jul 14, 2009 | Xerox Phaser 4510/B Laser Printer
Xerox XC 1045 has a flashing H 4 error.
elem_1_spacer.gif Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Jul 01, 2009 | Xerox Office Equipment & Supplies
Paper jam
I would make sure you opened and closed EVERY section of the machine that was indicated on the op panel.... even if you found the paper already..
Apr 11, 2009 | Office Equipment & Supplies
Xerox XC820 Copy Machine
three lights are for paper jam, replace toner cartridge and replace dru, cartridge. If there is zigzag line it is paper jam if there are six small dots it is for toner cartridge and if it is one circle it is for copy cartdisge. You can contact me for mfurther support at jagpal_65@yahoo.com
Dec 25, 2008 | Xerox XDL-33D Black and White Copier
Xerox xc 1045
H3 is a fuser problem, check lamp or thermofuse
Oct 31, 2008 | Office Equipment & Supplies
Paper jam in xerox copier 5328
Specify the area of paper jam or the code on display that cud help isolate the problem quicker, it cud be a C or E code. Try to clear it with code 20 subcode 03, but state code on display
Oct 30, 2008 | Office Equipment & Supplies
Xerox xc830
it does sound like the toner cartridge is empty or bad.
Apr 18, 2008 | Xerox 8830 Copier
388 people viewed this question
jasbo
jasbo
