posted by Lydia on Sep 13, 2006
I was wondering how to get the fax machine off of sleep mode. It also rings, and says recieve, but no fax comes through.
Thank you, Lydia
Best Solution
posted on Aug 14, 2007
Press Menu/Set, 1, 6, 2
(2. Sleep Time should be displayed)
Simultaneously press Start and Options at the same time
Press Menu/Set
Press Stop Exit
This will turn the sleep mode off. The new setting will apply after the next time the machine copies, prints or is turned off and on.
Press Menu/Set
Press Stop Exit
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Brother IntelliFax-2820 Plain Paper
Email this problem
Email this problem
Can you Help with these Fax Machines problems?
Brother IntelliFax-2820 Plain Paper Laser Fax
Paper jam will not go
Paper jam will not go away Answer This...
INTELLIFAX 2820--PAPER/SCANNER...
thx for prompt reply... Answer This...
not connecting to fax out
The fax machine recieves faxes... Answer This...
Won't print
Won't print
Nothing happens or it will say... Answer This...
Repair Service
Find Fax Machine Repairman Near You:
