Dryers Logo
Posted on Mar 03, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Neptune dryer makes a lot of noise while running sounds like bearings rattling what do in to do to fix?
Anonymous
Level 3:
Guru:
  • Master 462 Answers
  • Posted on Mar 03, 2012
Anonymous
Master
Level 3:
Guru:
Answers
462
Questions
Helped
252399
Points
1207
The problems could be many. agreed its something that moves from your description.
moving parts are
motor, belt, drum, drum rollers (or glides but they dont move) could make noise if so equipped), fan in housing going to heater.
if helpful please rate me. if not please tell me more.
5 Related Answers
Anonymous
  • 184 Answers
  • Posted on Apr 08, 2008
SOURCE: squeaky dryer
IF THE LINT FILTER IS LOCATED ON TOP OF THE DRYER,
THERE ARE TWO SCREWS UNDER THE LINT FILTER THAT NEED TO BE REMOVED. REMOVE THE LINT FILTER ALSO.
PULL FORWARD AND UP ON THE DRYER TOP( NOT JUST THE CONSOLE) AND DISENGAGE THE TOP FROM THE FRONT. THERE ARE HINGES ON THE BACK OF THE TOP JUST PIVOT IT UP OUT OF THE WAY. NEXT, THERE ARE TWO 5/16 HEX HEAD SCREWS INSIDE THE DRYER NEAR THE TOP IN EACH CORNER THAT HOLD THE FRONT TO THE SIDES. REMOVE THEM AND THE FRONT WILL PULL FORWARD. IT IS HINGED AT THE BOTTOM. LIFT IT OFF THE HINGES AND SET IT ASIDE. YOU CAN NOW UNDO THE BELT FROM THE MOTOR AND IDLER AND USE IT AS A HANDLE TO LIFT THE DRUM OUT OF THE CABINET.
THE DRUM SUPPORT ROLLERS ARE LOCATED AT THE REAR OF THE MACHINE AND CAN BE REPLACED AS A SET. THE NUMBER IS 349241T FOR THE TWO PACK.
CLEAN THE SHAFT WITH SANDPAPER BEFORE INSTALLING THE NEW ROLLERS. THEY ARE HELD ON WITH TWO TRIANGULAR CLIPS. JUST CUT OR BREAK THE OLD ONES. THE NEW ROLLERS COME WITH NEW RETAINING CLIPS.
AFTER REPLACEMENT, REASSEMBLE IN REVERSE ORDER.
tzweeb
Tom Zwiebel
  • 318 Answers
  • Posted on Dec 29, 2008
SOURCE: Kenmore 70 series dryer making loud rattling noise, drying ok
it could be a worn motor bearing, but they usually last for 20 years, i would guess that you have a worn drum roller, the thing that holds up the drum and looks like a wheel.
if your sure the motor has a worn bearing then replacing the motor is not easy as you have to unscrew the blower wheel from the motor shaft.
it also may be that you are talking about the idler pulley being worn. it is the device that holds tension against the belt and they also will wear out and be "wobbly"
kachbibi1
Bill Dickerson
  • 979 Answers
  • Posted on Jan 14, 2009
SOURCE: Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Anonymous
  • 750 Answers
  • Posted on Jan 23, 2009
SOURCE: KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
arikrom
911 SERVICE TODAY
  • 528 Answers
  • Posted on May 02, 2010
SOURCE: The dryer is making a loud noise as it tumbles.
you need to open it most of the dryer need maintanace every 4-5 yars and if you keep runing it you may do more damage.
there are several parts that the drum is turning on them and they get bad after few years. like felts,riders,belt...
2helpful
Dryer makes noise when turning
its a possibility that the drum slides are bad. or there is something wrong with the belt. the tub has to be exposed to check it out, and or fix it. good-day !
Hello, my maytag neptune dryer is making a loud noise while drying. when i turn it off, and turn the drum, i hear a chaffing noise on the left side. i tried to pry the top off, however it doesnt seem to...
Steven your neptune dryer has bearing problems - thats the chaffing noise you hear on the left side - your drum is running off centre , probably pulled that side by the action of the drive belt . Remove back of machine and check out from there . disconnect all power before and during inspection . you may be able to replace bearings on that dryer if you have the tools to do so .
2helpful
2answers
My maytag neptune dryer is making a scratching noise.
If the sound seems to come from the front of the drum it's probably the felt guides. The bottom one will wear first and make a grinding, rattle like sound. You can access it by removing the front panel which includes the door. It fits around the drum at the front. Here's a diagram. Some models have a two piece and some a one piece guide. Part 4 on this diagram is one. It's called a seal here. DIAGRAM
If the sound comes from the rear, there is a nylon bearing and metal socket at the rear center of the drum.
My Maytag Neptune gas dryer is making a very load squealing sound when in use. Is it possible that I need a new motor? I had a repair man come out and his answer was an entire new motor. The cost of the...
You sound just like me and I like that. Of course they want to replace the motor-it's a easy fix for them. It's the bearing going bad that's why it gets worse after it heats up. Try this for a temp fix. If you can get into the dryer spray the pulleys and the motor bearing with a lubricant like WD40. Be cafeful around the motor and anything hot. Use quite a lot but directly where it is needed. Also get the drum roller and support bearings too.
I hope my suggestions helps and all the luck to you.
burdfrenzy
http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
2helpful
Our two year old Maytag gas dryer is making a rattling noise. The noise is intermittent. Also, when the dryer turns off and the drum stops turning something else seems to "run on."
this is most likely a broken wheel which is a wheel that the bearings have worn out on.If it is a wheel you should replace the set because if you replace just the one the others will wear out faster than they should.
Ps if it is only two years old it may still be under warranty!
1helpful
2answers
Why is my dryer is making a lot of noise during drying process?
check to see if it is a belt pulley system if it is its probably those items.
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
1helpful
Electric Maytag Neptune Dryer - rattling noise
Your probably going to have to remove the rear panel and take a look to see what is causing the noise.
Disconnect the power cord and exhaust tube, remove the rear panel and check for anything loose.
You can also pop the lid and fold it back to inspect the top of the tub and belt. Roll the drum all the way around and inspect the belt for "chunks" missing.
If you include your model number, I can send you a web site that will show you an exploded view of the dryer.
Regards,
2helpful
MayTag Neptune MDE6800AYW dryer drum making rumbling knocking noise
Have someone change the bearing, it sounds like it has busted on ya. The rumbling sounds like the ball bearings in the bearing have failed.
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
