Question about Asko Washing Machines
Machine wont stop filling with water, it just overflows. Machine is an Asko w6551 front loader
Same thing happened to my ASKO W600.  Sounds like the water inlet valve is blocked or broken so therefore can't stop the flow of water coming into machine.  Check it out and replace if necessary.
Posted on Nov 03, 2008
Asko front loader fills with water when switched off and once turned on will immediately sense it and drain it from the machine. What could be the problem? The machine still washes beautifully, even after...
inlet valves are out of service or malfunctionnign follow the steps .
1. unplug your machine power cord.
2. open the door and also open water supply , if your machine fills the water then 100 % problem is with your inlet valves , replace it , simple
regards
Dec 31, 2014 | Asko W6021 Front Load Washer
Replace drum bearing ... in a ASKO W6551 step by step
you need to remove the drum start at the front remove front panel,four screws 2 under front,1 behind soap drawer and the one near the filter,next take door off 4 spring clips on the next panel plus screw on door lock,remove door lock,then undo clamp band,bolt at bottom and remove counter weight panel (heavy).remove stainless steel inner panel,use a screwdriver to loosen,from the back remove drum pulley.the drum will then pull out.replace vseal and bearings.hope this helps
Jun 05, 2010 | Asko WL6511W Front Load Washer
Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Mar 10, 2009 | Asko W640
Asko 10505 overflow problem
Replace the water valve and your problem is gone.
May 26, 2008 | Washing Machines
Asko Frontload wont stop running water
you need a new inlet valve take off the top panel then you see the inlet valve follow the inlet hose
Mar 17, 2008 | Asko W6441 Front Load Washer
Asko front load washing machine
When u use front loaders you normally don't need a soak. And i don't think you need bleach. Use front loading powders for the machine. The automatic machine is supposed to work for you. The water empties out, so you can open the door.
Rate me pl if helped..............
Jan 24, 2008 | Asko W6221 Front Load Washer
Washing Machines Logo
350 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
