Problem with Kyocera Copystar CS-1820 Black and White Copier
EVERYTHING IS CONNECTED AND NETWORK LOOKS CONFIGURED CORRECTLY.
PRINTER SCANS AND THEN AFTER AWHILE IT FLASHED ERROR SENDING 2101
12,151 people viewed this problem
This solution has been voted best by the Fixya Commnunity
You have to have a user name and password set up on the computer you are scanning to then you set theat up in the address you set up on the copier.
yassine chaouche Where do you change the Port ?
Nov 14, 2012
My Estudio 350 will not allow printing to it from the network. It will send out scanned documents, etc. but will not...
I am recieving a network error on my Sharp AR-M700 mutil-fucntion copier when trying to scan to email. I can ping it...
I am having an issue with Scan to Email functionality on the Sharp AR-M450N copier/scanner/fax. I am receiving error...
The scan to file is terrible, I have a share on each workstation "\scanner" and each user selectes their workstation to...
hello i have two IR1024i,that are connect to the network ,have email server,email,user,passsword authenticated,but still...
my kyocera also cant print it show always this document failed to print...
Regardless of which I use, doc feeder, directly on the glass it copies only part of the page and then displays jamb. ...
I am able to install the printer, print a test page, and then ping the printer but soon after when trying to print...
JIMMIE839 I have a Kyocera KM-1820,
I know it is nice to give the Product im working with..
Thanks.
Oct 31, 2008
p3s3 I have similar problem on Kyocera KM4050. The solution mentioned for JIMMIE839 has already been during configuration and even then the problem persist. Please suggest some other solutions if you have.
Nov 20, 2008
