Question about Xerox Phaser 8500N Printer
5500 xerox phaser
I have a 5500 xerox phaser that when the first print comes out of any printed job it makes it dogear at the top corner of print, just the first print the rest are fine,i
  • 23 Answers
Check the paper path for any and all debris. Use canned air to remove any debris. Also check the paper tray guides to see if they are matched correctly.
Posted on Feb 27, 2009
Why does my Xerox Phaser 5500 print distorted watermarks?
Click caret ro right of friend's post, click unfollow without unfreinding.
Feb 26, 2015 | Xerox Phaser Office Equipment & Supplies
Re - Phaser 8200DP Solid wax printer; very often doesn't pick up paper from bottom tray, resulting in 'jam' message. Also, tends to fold the top corner of a two-sided (duplex) print job on exiting after...
Clean the pick up rollers with alcohol. They need to be really grippy.
If it's folding the corner of paper I expect there is a bit of torn paper stuck in it.
Oct 29, 2013 | Xerox Phaser 8200 Laser Printer
I have just bought a Xerox Phaser 6500. Prior to this I had a phaser 6125. The problem im having happened with both printers which makes me think somewhere along the line my settings are wrong. If I...
You may have the "separator page" option turned on in your print driver. This option will insert a blank page after each print job to separate one print job from another. Simply uncheck the box by the separator page option and you should be back to normal !
Oct 21, 2013 | Xerox Phaser Office Equipment & Supplies
Xerox Phaser 5500 will only print if started in the manual tray.
Check your printer setup/default settings on the printer. Make sure you are using the right paper in the trays and that they are set properly to the proper paper tray & size. You have to have it right in all locations for it to work right, or it will default to by-pass tray. 1st in the settings, 2nd in the trays, and 3rd in your printer software. Good Luck!!
Jun 07, 2012 | Xerox Phaser 5500 Laser Printer
Phaser 5500 will not duplex
its definitely a driver related issue.....download latest driver from www.xerox.com
Nov 09, 2009 | Xerox Phaser 5500/DN Laser Printer
PRINTING ERROR
> Home > Support & Drivers > Knowledge Base
Solution --> ERROR 0082" name="Note" /> Phaser 790 / DocuColor 2006 Printer's: Cancel print job and cycle the printer's power
  • On the printer's Control Panel, press the Cancel Key (12 KB).
    Note: The READY message may only appear briefly. You may need to keep repeatedly pushing the CANCEL key.
  • If the error message persists, turn the printer off for at least 30 seconds and remove the computer interface to the printer (17 KB) before turning the printer back on.
  • Use the menu keys to perform a front panel reset (under RESETS menu).
  • If the printer redisplays the error message upon reboot, a file is likely STUCK at the front of the print queue. Use the front panel RESETS menu to CLEAR LOGS AND QUEUES, which will delete all print jobs in the printer's disk spool.
    Note: The READY message may only appear briefly. You may need to keep repeatedly pushing the MENU key to gain access to the front panel menu.
  • If the front panel menus can not be accessed turn the printer off for 30 seconds and then turn the printer back on.
  • If it is known which print job was last sent to the printer, try to reprint the last job spooled, which may be the cause of the error. Step 4 on clearing logs and queues may need to be repeated to eliminate the crashing job.
Note: Most XX82 or XX1E front panel error messages are NOT hardware related, but caused by a specific print job or application.
Mar 04, 2008 | Tektronix Phaser 860DP Thermal Printer
Phaser 8560 won't communicate with me or my computer
What you can try is making sure the ink sticks are fully in the loaded position. They may be keeping that cover from closing totally.
The other thing is the actuator on that cover, may have briken off and is not properly actuating the sensor that tells the machine the cover is closed.
Make sure the ink is fully forward, and look at the covers for some area of beoken plastic.
Jan 12, 2008 | Xerox Phaser 8560DN Laser Printer
Will not print multiple collated two sided publications without individually sending each job
I would try changing the driver you are using. There are multiple drivers and it really sounds like that will resolve your problem.
For the drivers go to Xerox.com.
on the tool bar select Support and Drivers.
Then enter your printer number, being phaser enter phaser 7300 in the search .
Select your operating system and there will be PS and PCL drivers.
I am 99.9 percent sure the issue is in the driver.
Dec 26, 2007 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 8500N Printer Logo
164 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
