Question about Xtreme Sound WMS336 CD Player
Faceplate removal I can't find the switch to remove my faceplate and all the lights stay on after the cars off.... need help fast before it gets stolen. thx
    Problem Solver:
  • 10 Answers
It is at the top if the faceplate when you push the button to flip it down in the middle top on the back is a big button push it down and slide it off.
Posted on Jun 27, 2008
How do i remove faceplate
if it is a model with removable faceplate, there should be a little catch on either or both ends. it should tell you in the manual. if it is a model without a detachable front, then you can not remove it.
Nov 15, 2013 | Sony CDX-GT630UI Car CD/ MP3 Player
95 ram 1500 Headlights will not come on but I can hold the bright switch back to work the bright lights. I didnt see any fuses blown and I did not see any relay's. I noticed a couple of weeks ago that i...
Hello kelly fox: my name is Roger and I will help you. There are only a couple of things most likely to be the problem. I would look at the head lamp bulbs first. I have had the same problem of both lamps suddenly burn out on my dodge ram. The only other component is the multi function switch could have a problem. This could happen but most likely the bulbs are the issue. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
Nov 20, 2010 | 1995 Dodge Ram
The valve you push to turn the shower on is leaking water and will not stay pushed in...HELP?
if you are talking about the type that has a button that sticks through the faceplate so that you can turn the shower on, you need to take the faceplate off, after removing the handle. Make sure you turn the water off to the valve or you will get wet. You see a hex head that the button goes through....you can remove the assembly and replace with a new one. The fall apart occasionally. Make sure you get all the pieces out before reassembly.
Oct 18, 2009 | Delta & Single Handle Shower Faucet
Remove protective film wrap from under water dispenser faceplate
I have this same model and was facing the same issue. I even emailed Whirlpool but that didn't help.
You can remove the faceplate by removing the spill tray and unscrewing the two small screws in the bottom. Be careful not to scratch the finish while removing the screws.
The faceplate is held on by several plastic hooks around all edges. Carefully grip the bottom of the faceplate (I put my thumbs on the inside where the spill tray was and my index finger below the bottom front of the faceplate). Get a good grip by pinching the faceplate and pull down and out to remove the bottom. Then push the faceplate up to unhinge the top.
You can let the faceplate hang by the wires while you remove the plastic. I'd also use a stainless steel cleaner while the faceplate is off to get rid of any fingerprints you may have left behind.
To reinstall, hang the faceplate on the top 3 hooks making sure there is a snug fit. Then pull down on the bottom and push it in. It took me two tries to get it back on.
The plastic is stronger than it looks but you'll still have to go slow and be careful with it. Good luck!
Sep 09, 2009 | Whirlpool Refrigerators
Pioneer deq 7600 display went black today the eq works fine.
the faceplate contacts may need to be cleaned. remove the faceplate, and using an eraser, clean the metal tabs on the main unit and rear of the faceplate.
If this doesnt remedy the problem, service is required. May be the light unit in the faceplate.
Dec 22, 2008 | Car Audio & Video
Unit only has power for a few seconds
Yeah remove the unit from your car,
Go to car audio store and buy Kenwood receiver without the
fancy opening front.
Dec 17, 2008 | Kenwood eXcelon KDC-X879 CD Player
Display issues with Aiwa CDC X207
I had the same problem. There are two small light bulbs that illuminate the digital display, and they are burned out.
You can easily replace them. The Aiwa part number for them is 8Z-KT1-641-010. The bulb is made by Sony, and the Sony part number is U0087654U.
I purchased them from Union Electronic Distributors:
https://www.ued.net/ued/addItems.do?itemCode=SNYU0087654U
Note that the product is not an item they keep in stock, so it may take 1-2 weeks or more before you receive them. Be patient.
Here are the steps to replace the bulbs. You will need a small (#1) Phillips screwdriver and a soldering iron (low heat). A very small flat blade screwdriver (1/8") will also be helpful.
1) Remove the faceplate from the radio and bring it to a well-lit work table.
2) Remove the four Phillips screws on the back on the faceplate.
3) Carefully separate the back half of the faceplate cover from the front half. There are three locking tabs along the top, and three locking tabs along the bottom. I used the small flat blade screwdriver to separate the two halves.
4) Once the back half of the faceplate has been removed, re-install two of the Phillips screws to hold the circuit board in place (one screw on each end). You don't need to screw them down tightly; just screw them in until you begin to feel them stop. These screws will keep the circuit board from separating from the front faceplate and causing the buttons to fall out!
5) Locate the two bulbs. They are labeled PL 901 and PL 902 (may also be labeled PL 1 and PL 2). Carefully unsolder the bulbs and remove them from the circuit board. You may want to do one at a time.
6) Each bulb has a colored cover to change the color of the light (I jokingly refer to them as 'bulb condoms'). Remove the covers and carefully slide them in place on the new bulbs. You may want to slightly dampen the bulbs to aid in sliding the covers on. Be sure to slide them all the way down.
7) Solder the new bulbs in place. They are not polarity sensitive.
8) Trim off the excess wires.
9) If you installed the two screws in Step 4, remove them.
10) Carefully re-attach the rear faceplate cover to the front faceplate cover, making sure that all six locking tabs snap in place.
11) Put the four Phillips screws in the rear faceplate and carefully tighten them.
That's it! Now, put the faceplate back on the radio, turn it on, and enjoy your lighted display!
Hope this helps.
Ron
Dec 13, 2008 | Aiwa CDC-X204 CD Player
Kenwood KDC-X717 - Facplate opens when powered on, stays open. No display.
I've had this problem before. The ribbon cable needs to be replaced. They wear out every few years. Take it in for service. Or do you want to sell it? I need the face plate for mine.
Nov 06, 2008 | Kenwood KDC-X717 CD Player
Xtreme Sound WMS336 CD Player Logo
Top Xtreme Sound Car Audio & Video Experts
Aaron Hackbarth
Level 1 Expert
Are you a Xtreme Sound Car Audio and Video Expert? Answer questions, earn points and help others
