The computer was going really slow so i decided to restart it but when it was suppose to come back on the screen only goes to a black screen with a white dash blinking in the left corner. The fans are going on but just not the screen how do i fix this?! please help!
SOURCE: hp vs15, black screen, power light goes on and off like it is in sleep mode
Monitor is dead. The LCD inverter board probably went out and needs replacing. More than likely, it will cost you over $100 to get it fixed. It's better to spend the money on a new monitor.
SOURCE: Start up problem
probably u deleted some files from windows ...
after booting press F8, (or F5 ..i donlt rememdber) and then select go to safe mode! If it works than try and see what is missing, and back up u;re data.
If it doesn't work than u;ll have to reinstall u;re windows ...
SOURCE: HP Compaq FS7600 - won't boot -
It sounds like the update screwed up Windows. Have you tried all the "last known good configuration" option? That sometimes gets the system going.
If safe mode and the other choices all are failing, you can try the recovery console if you have a Windows CD. Boot from the CD, let it do its thing, and choose the "R" option to repair an installation from the menu that you'll get. Once you're in the recovery console, the chkdsk command will scan the disk and try to repair corrupted files, and this will sometimes work.
If all else fails and you have the recovery CD's for the system you can restore the original software. If you're comfortable switching out a hard drive, you can buy a replacement drive (they're pretty cheap now) and restore the system on that, and you'll still have all your personal data intact on the original. (Just because Windows won't start, it doesn't mean you've lost anything like music or pictures.) After you get the system running again, you can install the original drive as a second drive and copy what you want to keep, then reformat that drive and use it for extra storage.
SOURCE: HP monitor vs17 goes black with power light flashing
I have repaired an HP 1702 monitor that had similar symptoms by replacing the capacitors on the power supply board but you have to have some electronic knowledge and do some soldering if you can buy the replacement capacitors($10+/-) from a supply store. They (at least 1) will be swollen up on the ends and may have a tar-like substance leaking from them. It is best to replace them all (may be 4 depending on the model).
SOURCE: hp f2105 only stays of for 2 seconds
Hi there mate i have a hp f2105 with the benq power supply in it which as gone faulty could u look at your power supply and tell me the numbers on the power ic which is ic651 thanks.
