Question about Sony PFM-50C1 50 in. Plasma HDTV
SONY PFM-50C1 WONT POWER UP, STAND BY LIGHT COMES ON, AND THEN IT SHUTS OFF
I PLUG THE WALL MOUNT IN AND THE STAND BY LIGHT COMES ON THEN IT TURNS OFF LIKE IT WAS UNPLUGGED. IS THERE A "RESET" BUTTON OR ANYTHING SIMILAR THAT WILL HELP ME GET MY DISPLAY UP AND RUNNING?
Sir do a power reset, turn off the tv, unplug the tv from the electrical source, wait for about a minute then turn the tv again, if the problem still exhibit call 1800 222 7669 thats for sony customer service,.
Posted on Nov 07, 2008
I have a problem with my pfm-50ci when i power it up it just clicks will not power up.
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional
2. Open your TV and find PSB. Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
I have a tip/tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem.
Hope this helps and Good luck.
Kaufman605
Dec 11, 2010 | Sony PFM-50C1 50 in. Plasma HDTV
Weird /not the right colors on screen
I had the same problem and found out that my kids had been messing with the remote control and put the screen saver on (not the first screen saver option but the second option which make it look kinda like a photo negative) i disabled it and got my normal picture back.
Dec 18, 2008 | Sony PFM-50C1 50 in. Plasma HDTV
Sony PFM-50C1 50 in. HDTV
Hello MDay02,
Here is how it works. When you finally decide that you want to purchase a board from us, We will send you a Pay pal invoice with the Total cost. We will also give you our contact number after payment is received, which will come in handy if you need assistant in installing the part. Assisting in installing is unlimited to that particular part. You can call us as many times as you want.
Best regards
circuitcity
Apr 09, 2008 | Sony PFM-50C1 50 in. Plasma HDTV
Sony Plasma PFM 50 ci black screen
. Check blink of leds
check the 5 v control voltage.
check Ysus and Zsus board.
check Voltage sc, Vs and Voltage a .
Yareth De Matos - Venezuelan -
Mar 28, 2008 | Sony PFM-50C1 50 in. Plasma HDTV
Sony plasma
SOUNDS LIKE YOU NEED A NEW PDP(PLASMA DISPLAY PANEL) HOPE YOU HAVE WARRANTY$$$
Feb 19, 2008 | Sony PFM-50C1 50 in. Plasma HDTV
TV Flikers and StandBy Light Flickers
Your pdp panel sounds faulty - Count the red flashes this is an error code.
Nov 13, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Sony PFM-50C1 Fuzzy Dim Display
Just want to let you know that the problem you are having is a bad X board. This board may not be available from Sony, because it is sold as part of the panel
Best regards
CircuitCity
Sep 28, 2007 | Sony PFM-50C1 50 in. Plasma HDTV
Vertical Black line on display
Rakesh, You have a "dual scan" panel, this is why the line only decends down the screen half-way. This could be a connection problem on the buffer board which causes loss of the drive signal only to that part of the display which it is connected to. The vertical address buffer will be located on the top rear of the display, use great caution in inspecting these cables and connectors. If the integrity of the cable and connector is good the panel itself may be bad due to the drive IC being located on the ribbon cable attached to the panel body. this is better known as COF or, chip-on-film technology. I hope this helps you. Good luck. Joe Weibel CustomElectronics.Org
Jan 28, 2007 | Sony PFM-50C1 50 in. Plasma HDTV
Sony PFM-50C1 50 in. Plasma HDTV Logo
276 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
