Question about Cisco (UBR904) Router
Where is the EEPROM located on a Cisco uBR7114 and is it replaceable?
Customer is receiving the following:
*Jun 13 04:56:14.286: %TLV-3-UPDATE: Unable to write type 199
-Traceback= 608462F0 60840404 60840C54
*Jun 13 06:15:32.926: %TLV-3-UPDATE: Unable to write type 199
*Jun 13 07:53:09.701: %TLV-3-UPDATE: Unable to write type 199
-Traceback= 608462F0 60840404 60840C54Cisco's site says:%TLV-3-UPDATE : Unable to write type [dec]Explanation An attempt to update an EEPROM entry has failed.Recommended Action If this message recurs, copy the message exactly as it appears on the console or in the system log, contact your Cisco technical support representative, and provide the representative with the gathered information.
  • Anonymous Jan 23, 2009
    adsda
  • Anonymous Mar 15, 2014
    unable to access the site to update the cisco
    Volet Plus
Test c7100 mpeeprom read will indicate the problem with 00 fields in the data output.
rewrite to fix this issue.
You can reprogram mpeeprom by the following commands:
test c7100 mpeeprom write 34 FF
test c7100 mpeeprom write 35 FF
test c7100 mpeeprom write 36 FF
test c7100 mpeeprom write 37 FF
test c7100 mpeeprom write 7F FF
Posted on Jan 05, 2010
    Scholar:
  • 65 Answers
Then i would suggest contacting your Cisco Rep.
Posted on Oct 31, 2008
Cisco Dig-73082 Server Usb Dvd/cd-rom driver download from where?
Cisco doesnt have any file aside from the ISO file that you can download on their website .
2 ways to download and install the driver
1 Download and install an ISO converter software and use or click the link for the driver software
https://software.cisco.com/download/release.html?mdfid=283862063&softwareid=283853158&release=3.0(2h)&relind=AVAILABLE&rellifecycle=&reltype=latest
and use this site to download and install the ISO converter https://www.crystalidea.com/zip-to-iso-converter-convert-zip-archives-to-iso
2. USE window update
Updating the Windows Driver
Perform the following steps to update the LSI MegaSR driver for Windows or to install this driver on an
existing system booted from a standard IDE drive
Step 1 Click Start, point to Settings, and then click Control Panel
Double-click System, click the Hardware tab, and then click Device Manager. Device Manager starts.
Step 2
In Device Manager, double-click SCSI and RAID Controllers, right-click the device for which you are
Step 3
installing the driver, and then click Properties.
On the Driver tab, click Update Driver to open the Update Device Driver wizard, and then follow the
Step 4
wizard instructions to update the driver
Feb 05, 2017 | Cisco Computers & Internet
Unable to browse to cisco access point
'192.168.0.116' is the wrong range for the router. The Cisco manager allocates the ranges the router will use.
See this page on the setup.
Getting Started Guide Cisco 3700 Series Access Points
May 28, 2014 | Cisco Computers & Internet
Port getting flaps
sounds like some sort of keep-alive problem.
Try using
switch(config)# debug snmp packets
this will show you what is causing the line protocol to drop. you need to be connected to the console to see the output for this and turn it off when your done.
un debug all
good luck.
Jun 06, 2012 | Cisco Catalyst 4948
After 3 years with the Linksys wireless G broadband router and excellent strength, the last 3 days my wireless router is producing a very low signal....why?
Sometimes, new interference from devices unknown to you cause the problem. Additions of a new microwave, cell phone or even faulty wiring in the house can output electrical interference.
But it is not uncommon for the Linksys routers radio to fail as well.
Consider replacing it with a newer Linksys router that will be compatible with docsis3 speeds and above.
Jun 17, 2011 | Linksys Wireless-G Broadband Router
I am trying to set a password for my linksys wireless router. Everytime I enter a password, and click save changes, it locks up and I have to reboot the router. Please help!
Your router may need a firmware update. Got to this link http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G?referrer=www.linksysbycisco.com at the bottom, follow the instructions to enter your version. Follow the instructions. You will be able to download a flash utility that will fix you problem. Factory reset your router before you flash the eeprom.
Jan 11, 2011 | Linksys Wireless-G WRT54G Router
MobilePro 900 turn on during the night and not shut back off
Devices running Windows CE 3.0 turn on at midnight to search for appointments for the coming day. Reminders are set and the Today view is updated with the day's events. The device is supposed to turn off after three minutes of inactivity. If a program is running the unit may not turn off because there is activity. The following applications are known to cause problems: * Windows Media player for Pocket PC. * Active Sync * Wireless LAN adaptors NEC has developed a registry patch that has been tested on the following LAN cards. Device Vendor Driver Cisco Aironet 340 Cisco 2.30.11 Cisco Aironet 350 Cisco 2.30.11 Linksys WPC11 Ver 3 Linksys 1.07.29 Orinoco Orinoco 1.02 3CRWE737A 3 Com 2.2.5.0 LA4137 Wireless Network Symbol N/A For additional information see Microsoft Knowledge Base Article – 263719 Click here to download the Power Management update utility. Installation procedure. Note: Anytime a “hard reset” is performed on the MobilePro 900 the Power Management update utility needs to be re-applied. 1. Download the Power Management update utility to local system. 2. Copy the Pwr_Mgt.exe file to the MobilePro 900 desktop. 3. Double tap the NEC Icon. 4. Click OK. 5. With power on momentary depress the “soft reset” on the bottom using the stylus. 6. Delete the NEC Icon on the desktop.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Cisco (UBR904) Router Logo
605 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
